Question about Canon PC-980 Color Copier
Printing 1 1/2" down right side of paper
We were having lines printing and lighter shades of the ink. We changed out to a new ink cartridge and now it's printing really wide black ink down the right side. Pulled out cartridge and cleaned everything inside cover and looked at the roller on the cartridge and cleaned it. As soon as we closed everything back up it does it again. We put an old cartridge back in and it seemed to do better. HELP!!!!
You have a defective toner cartridge, drum should be clean when you looked at it, the blade is failing. Is the cartridge remanufactured (or compatible)? Although they usually work well (depending on the supplier) there are sometimes defects
Posted on Feb 13, 2009
My printer is printing black horizontal lines down the right side of the paper - what is wrong?
Needs Drum If you pull the drum unit out you will see on the drum different shades of color lighter is wear the lines come from. Buy a rebuilt drum much cheaper and they work, may have to reset the drum count if the change drum lite on...
May 02, 2014 | Brother MFC-8460N All-In-One Printer
My Brother MFC-7420 Printer always prints black lines and splotches down the left side of my paper. This happens whether I'm scanning or printing from my PC. When I looked at my drum, it appears a
If you are seeing vertical streaks/black lines your primary corona wire is dirty and or the fax scanner may be dirty.
1)To clean the corona wire you take the drum unit and toner cartridge and place it on disposable paper to avoid spilling.
2) Clean the primary corona wire inside the drum unit by sliding the blue tab from right to left several times.
3) Return the blue tab and snap it into the home position.
4) Reinstall the drum unit and toner cartridge.
5) Close the front cover.
Caution: if you do not return the blue tab to the home position it may repeat the black lines.
Nov 29, 2012 | Brother MFC 7420 All-In-One Laser Printer
Missing lines of print
hello
You either have to change the ink cartridge or try to clean the ink cartridge nozzles as described in the user manual;
http://support.dell.com/support/edocs/systems/924/en/om_en/om_en.pdf
On page 54 it states the following:
To clean the ink cartridge nozzles:
1 Load plain paper. For more information, see "Loading Paper" on page 19.
2 In Windows XP, click Start-Control Panel-Printers and Other Hardware-Printers and
Faxes.
In Windows 2000, click Start-Settings-Printers.
3 Right-click the Dell Photo AIO Printer 924 icon.
4 Click Printing Preferences.
The Printing Preferences dialog box opens.
5 Click the Maintenance tab.
6 Click Clean Print Cartridges.
7 If the print quality has not improved, click Print Again.
8 Print your document again to verify the improved print quality.
9 If you are not satisfied with the print quality, wipe the ink cartridge nozzles, and then print
your document again.
hope this helps.
Feb 17, 2012 | Dell 924 All-in-One InkJet Printer
Got the C5180 from a relative because it didn't work. I tried a new black ink tank, it doesn't print anything in black. Color print looks weak and washed out without black for shadow, and black...
The printed output is fuzzy, blurry, or grainy, or the edges of objects in the images are jagged. Solution Follow these steps until the issue is resolved. Step one: Check your paper
  • Many papers have printing and non-printing sides. Load the paper with the printing side down.
  • Use the correct paper type for the project. For everyday documents, plain paper works well. For documents with dense printing, such as high-contrast graphics or photographs, use HP Advanced paper for the best results.
  • If these steps do not help, try a different paper. Ink might not bleed as easily on heavier paper. Paper that does not accept ink well is also prone to bleeding and smearing. HP designs its inks and papers to work together.
Step two: Check the settings
  1. In the program being used for printing, click File , and then click Print . The Print window opens.
  2. Make sure the appropriate product is selected, and then click Preferences or Properties . The Preferences/Properties window opens.
  3. Click the Printing Shortcuts tab. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.
    • Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.
    • Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .
    • Paper size : Make sure that this option matches the paper loaded in the product.
    To see additional options, click the Advanced tab, and then click Advanced Features . The Advanced Features window opens. Consider changing the following option: Ink volume : Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
Step three: Check image resolution Make sure that the image file has enough resolution for the size of the printed picture. Although many photo applications can enlarge an image or part of an image to any size, eventually the individual pixels become visible and the whole image looks blurry. Here are some general guidelines for image file resolutions:
  • 94 pixels per cm (240 pixels per inch) for images to print on smaller format photo paper, such as 10 x 15 cm (4 x 6 inch)
  • 117 pixels per cm (300 pixels per inch) or higher for larger format photo papers
  • Lower resolutions might produce acceptable images when printed on rough-textured paper
Step four: Align the cartridges If the previous steps have not improved the appearance of the printout, align the cartridges. See the user guide for alignment instructions.
Jul 02, 2011 | Office Equipment & Supplies
It is printing the wrong colors. My reds are
Step one: Check the ink cartridges HP doesn't guarantee the quality or reliability of non-HP ink. If the ink cartridges have been refilled, try replacing them with genuine HP ink cartridges.If you have checked the ink cartridges and are still experiencing a problem, proceed to Step two. Step two: Print a test page
  1. Verify that there is plain white paper in the input tray.
  2. Press the OK and Help buttons simultaneously. A two-page Extended Self Test Diagnostic Page prints. Figure 1: Extended Self Test Diagnostic Pagec00728269.gif
  3. In the Print Quality Pattern section on the second page of the test page, look at the color blocks for any lines. Figure 2: Print Quality Patternc00728270.gif
  4. If the colors are still wrong in the Print Quality Pattern color blocks, print a document to determine if the issue has been resolved.
If you have completed all of the steps above and are still experiencing a problem, proceed to Step three. Step three: Check the printer settings
  1. In the software application you are trying to print from, click File and then clickPrint . The Print dialog box opens.
  2. Verify that your printer is selected and then click Preferences . The Printing Preferences dialog box opens.
  4. The Printing Shortcuts tab lists most printing needs, but you might need to modify some of the options. Options on the Printing Shortcuts tab include:
    • General Everyday Printing
    • Photo Printing Borderless
    • Photo Printing with white borders
    • Two Sided (Duplex) Printing
    • Presentation Printing
    • Fast/Economical Printing
    • Postcard Printing
    • Hagaki Printing
    NOTE: These are general printing shortcuts with pre-selected settings.
  5. To change the settings from those available on the Printing Shortcuts tab, click the Features or Color tab. Options on the Features or Color tab include:
    • Print quality : If you are unhappy with the quality of your printouts, try increasing the print quality. To print more quickly, try decreasing the print quality.
    • Paper type : If one of the options matches your paper type exactly, choose it rather than Automatic.
    • Paper size : Make sure this matches your paper.
    • Print in Grayscale : Print a document in shades of gray.
    • Orientation : Specify how the document is positioned on the page.
    • Paper Source : Select the tray that you want to use for printing.
    • Two sided printing : Print on both sides of the paper.
    • Color Management : Specify the color space that the printer will use to interpret image data.
    • Pages per Sheet : Specify the number of pages in the document that will be printed on each sheet.
If you have completed all of the steps above and are still experiencing a problem, proceed to Step four.
Nov 07, 2009 | HP Photosmart C6280 Printer
I changed the black ink cartridge and the printer
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate.
Have some test on it at Printer Maintenance.
I'm sure 100% works on it.
Sep 23, 2009 | Office Equipment & Supplies
Printing with double lines and blurry on left side of the page
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth. Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Aug 19, 2009 | HP DeskJet 1220c InkJet Printer
My 8x10 photos have half a blue tint and half a yellow tint. I cleaned the heads and aligned the print cartridges and that didn't make a difference. Working with a HP2610. Thanks! Leslie
Step 1 - Check the ink levels
  1. Open the Printer Toolbox . There are two ways to do this:Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox
    • Open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click Printing Preferences . Click the Services tab, then the Service This Device icon.The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink. Step 2 - Check the printer settings
      1. In the program being used for printing, click File , and then click Print The Print window opens.Make sure the appropriate product is selected, and then click Preferences or Properties .The Preferences/Properties window opens.Click the Printing Shortcuts tab.
      2. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .Paper size : Make sure that this option matches the paper loaded in the product.To see additional options, click the Advanced tab, and then click Advanced Features .The Advanced Features window opens. Consider changing the following option:Ink volume : Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
      Step 3 - Run the clean print cartridges utility
      1. Press the Setup button.Use the arrow keys to select Tools and then press the OK button.Select Clean Print Cartridge and then press OK . The device prints a test page.Examine the test page. If the print quality of the page is good, stop here. If the print quality is bad, go on to the next step for further cleaning.Open the Printer Toolbox . There are two ways to do this:
        • Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
        • If the HP Director method does not work, open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click on Printing Preferences . Click the Services tab, then the Service This Device icon.
      2. The Printer Toolbox opens. On the Device Services tab, click Clean the Print Cartridges , then follow the on-screen instructions. Up to three levels of cleaning are available. Discard or recycle the page that prints.
      Step 4 - Print a diagnostic page
      1. From the product control panel, press * and # simultaneously, and then release both buttons.
      2. Press 1 , 2 , and then 3 . The Service menu appears.
      3. Press the right arrow button (c01150415.jpg ) twice. The Special Reports menu opens.
      4. Press OK .
      5. Press the right arrow button (c01150415.jpg ) once. The Print Cartridge menu opens.
      6. Press OK . The diagnostic page prints.
Jun 23, 2009 | HP Photosmart 2610 All-In-One InkJet...
Canon Pixma MP 800 printing Issue (heavy black line on opposite side of print page
problem is when the printer does a head clean dumps large amount of black ink on to rollers. Replacement head is almost £100 and not certain to fix fault
Apr 12, 2008 | Canon Pixma MP800 All-In-One InkJet...
Balck ink not working
This is what worked (so far) with my Dell1.gif AIO A940 printer1.gif that wouldn't print black ink.
It worked for awhile when I chose photo/glossy paper, but then it quit printing again (see below).
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
I got it to print, again, by putting SEVERAL papers in the feeder (instead of just 1) - there is a sensor that is supposed to automatically detect paper type, and it might not be working right, especially with one or only a couple of sheets.
Mar 16, 2007 | Canon S 330 InkJet Printer
Canon PC-980 Color Copier Logo
107 people viewed this question
old marine
old marine
