Question about Smeg F170 Pyrolytic Stainless Steel Electric Single Oven
Smeg oven not working
Hi there, we have a Smeg F170 Pyrolytic Stainless Steel Oven
Last night we used the oven - worked perfectly. Today i wanted to use the oven - nothing worked. I pulled the oven out and looked at the plug. The fuse had blown. So i changed the fuse.
now the fan light comes on and works, but the temperature light doesn't and the element doesn't heat up.
Could you please help?
  • ivor_le_roux Nov 26, 2008
    Is there a way of confirming what part is not working?
    Thanks
  • Smeg Master
  • 3,463 Answers
You have a element and or a faulty thermostat
Posted on Nov 25, 2008
  • Smeg Master
  • 744 Answers
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Posted on Mar 05, 2014
What does error 8 mean?
Same problems, error 4 followed by error 8 on smeg oven SFP496X-1
The cooling fan had stopped working.
I fixed the problem by replacing the 20W ceramic resistor connected to the fan.
The spare parts number maybe 806890480
an image of resistor
Sep 24, 2014 | Smeg SE399X/5 Stainless Steel Electric...
Circuit board failure
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Mar 24, 2011 | Smeg F170 Pyrolytic Stainless Steel...
I have a Smeg SA130P single oven. I have run a self-cleaning cycle. The cycle completed but, some hours later the lock indicator is still on and the door is locked. How do I get it unlocked?
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Dec 13, 2010 | Smeg F170 Pyrolytic Stainless Steel...
Lots of water/condensate ends up on bottom of oven
I have the same problem with my new Smeg oven. I try to avoid using the oven at the moment because of the amount of condensation I have to mop up each time I use it, even the floor get wet!. Smeg have said they will replace it but I am now looking for an oven that will fit into the 'whole' the oven will leave in my newly renovated kitchen. I wish I had never ventured near to SMEG. I would never recomend Smeg to friends, quite the opposite.
Jan 19, 2010 | Smeg F170 Pyrolytic Stainless Steel...
Whirlpool Datid OV D10
i have an ov b 10 whirlpool/ikea oven that i have cleaned the thermostat knob numbers off. can i buy another set of numbers because my guess work is ruining my food!
thanks
Sep 05, 2008 | Smeg F170 Pyrolytic Stainless Steel...
Smeg oven diplaying an "A" in display
I have had the same problem today - trying to change to day light saving time - can you help me too if you find out.
Sep 25, 2007 | Smeg SE399X/5 Stainless Steel Electric...
FAULTY TIMER/CLOCK
I found mine did the same I pusshed the face and it came back on. It appears fault within circuitry of clock and will need to be replaced
Dec 14, 2006 | Smeg F170 Pyrolytic Stainless Steel...
Smeg F170 Pyrolytic Stainless Steel Electric Single Oven Logo
1,908 people viewed this question
Top Smeg Ovens Experts
ashburton
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
