Question about HP Officejet 4355 All-In-One InkJet Printer
No power supply-supply board burned due to lightning.
I need a supply board to replace.
    Sergeant:
  • 306 Answers
    President:
  • 2,110 Answers
Take it to nearest service center...
Posted on Dec 02, 2008
  • 64 Answers
I found that Spare Parts Warehouse has your powersupply for $30.00. Here is the link to your part: http://www.sparepartswarehouse.com/HP,Printer,Part,Q731060003.aspx
I hope this helps!
Posted on Nov 25, 2008
  • 162 Answers
For hp printers replacement parts : http://www.everprint.com/
  • HP Master
  • 1,879 Answers
Visit http://www.sparepartswarehouse.com/
  • 2,335 Answers
Can you please provide the model number of your printer? or if you have the old or broken power supply, you can gives us the model number as well.
  • HP Master
  • 13,433 Answers
Please send me the model of your HP and do you see a partnumber or anything else on the burned board that might be helpful?
Thank you
JVC LT40A320 turns on but no picture. Replaced Power Supply & Backlight Inverter (TV was hit by a lightning surge, would not do anything at first) now the green light comes on but no picture or sound.
Since your TV was struck by lighting, the power supply is the first board that gets affected by the sudden change in AC power.. The main board is the next board due to the fragile components and the excess of voltage that is supplied to it when the lighting happened. Since you have replaced the power supply already.. I would suggest to replace the main board and that should restore the functionality on your TV.
Sep 04, 2015 | JVC Televison & Video
Repair or Junk my Samsung UN55C6500VF TV?
Hi William,
Not necessary to junk your TV. Damages due to lightning are extensive at times but from what you have mentioned it appears that may be it is only the power supply board which has gone bad and rest of the TV is ok. Replacing power board may restore your TV.
Good Luck.
Aug 24, 2015 | Samsung Televison & Video
How can I fix the error code 019 E on my Eloctrolux washing mashine W355H
You probably need a new board, but why not call the local parts supplier and tell the guy you're getting an 019 and he should be able to get you started. Just every now and then you may get around, but more than likely your will need to replace the board.
Mar 24, 2015 | Electrolux Washing Machines
Did you mean: i have an ONIDA LED TV 32" and last day the power supply board burned (as per technicians information). The TV was under warranty ( 7 months old). Technician saying it will not cover warrant...
critical board failure, if there was a spark from the tv then the transformer has blown, if there was no electrical problems they should replace the board and have it investigated. in some areas of the work lightning strikes are covered in the warranty as safety devices are on all electronic to cut out the voltage, its an in built trip. when the voltage goes back down it resets and lets voltage though again. all electronics have these in them these days that has high voltage use.
Jul 16, 2017 | Televison & Video
Can't find a fuse replacement...
We can't predict which components have been damaged due to lightning. Sometimes, a fuse only, otherwise more other components might have damaged. Anyway, if fuse should blow out, surely there will be any more reason. You should find it out first, before replacing the fuse. If not, more damage can be occur. Check for any shorted components, diodes, capacitors etc: at its main power supply regulator board. Be sure that there is no other defect occurred.
May 02, 2013 | Sanyo DP37647 37 in. LCD TV
Power supply board damaged by lightning would like to purchase another one
Damage due to lightning would not be limited to power board only, in my opinion, other circuit board would have also been damaged so new home theater system would be good choice rather repairing this one.
Thanks.
May 27, 2011 | Oritron DAV3101 PROGRESSIVE SCAN DVD
My desktop board is P5NSLI, suddenly when i'm working with it, a lightning splash because its raining, i turned off my computer 'cause i'm worried if what may happened, after the rain i get back to work...
This may have been due to power surge. Try replacing the power supply. Also, inspect the motherboard and other components for any physical damage. Motherboard may get damaged due to power fluctuations, which requires replacement.
CreativeTECH
Nov 23, 2010 | ASUS P5NSLI (0610839134670) Motherboard
Power surge due to lightning strike today. Comp...
Unplug it and then blow a hairdryer at the power supply for 3 minutes. Leave the lid on, just blow the hairdryer at it from the outside. Craziest trick I ever saw.
After that, turn off hibernation. And eventually, replace your power supply.
May 20, 2010 | HP Compaq Presario SR1300NX (PP195AA) PC...
Power supply not working
Hello my friend, if one of your power supply's part is burned, your power supply won't work else if its work i has a short time to operate and it will be burned the whole board of your supply. Mainly the reason of burning your supply are the following: 1. The Electric supply  from the source is to high or above the limitation of your Power supply. 2. Your power supply is over capacity. 3. You're power supply board develop a liquid moisture inside that is why it shorted and eventually the board is burned.  4. The load of your power supply is overload due to some device you attach that is beyond to the limit of your power supply's wattage capacity.
Note: try to see the wattage or voltage or the capacity of your power supply can supply the electricity within your computer system. To ensure that it does not exceed the limit of your power supply's limitation.  I therefore reccomend that to avoid burning the entire power supply board from short circuit, it is recommended to replace your power supply to avoid incidents may arise.
Hope this advice helps your problem. If you need more assistance just reply to this post.  If this solution or recommendation is able to solve or help your problem then please rate it.  Thanks
Jun 25, 2009 | Office Equipment & Supplies
LIGHTNING HIT IT
This could be bad.. You want to check the fuse in the power supply. If you are lucky that is all that is bad. If the lightning got thought the fuse you could have real problems. You would have to replace at least two boards, one being the power supply board and the other could be the signal board or digital board. Sometimes they unitize the signal and digital boards as one board. Lightning can do strange things. sometimes it will just take out a diode and fuse Sometimes it can trash a set making it cost prohibitive to repair.. Good luck.
Jul 24, 2008 | Televison & Video
HP Officejet 4355 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
