Question about GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket
Ge model#wpgt9350copl doesn't turn on
I have tried unplugging it to see if it resets but it still won't turn on, the touch screen doesn't activate and I don't think that it is getting power, the outlet is good so is there an internal fuse that can be blown ??? thank you
  • Anonymous Dec 20, 2008
    washer won't turn on, and screen stays blank
MicrowaveSvc
  • 9098 Answers
SOURCE: Counter top microwave GE lost all power
As an owner of a GE WES model might want to look at this blog post.
GE Customer Service is here.
Good luck.
Posted on Dec 16, 2008
  • 47 Answers
SOURCE: I need a owners manual.
CALL GE AND REQUEST A OWNERS MAUAL. GIVE THEM YOUR WASHER MODEL NUMBER AND TYPE OF WASHER IT IS. GOOD LUCK.
RODNEY
Posted on May 15, 2009
hiltonjug
  • 612 Answers
SOURCE: GE model JE2160BF03 no power. Blown fuse.
They are put out when something metal is put inside and cooked for a few min. They are also put out with power surge. It protects your mag tube. Plus they just go bad sometimes. Could be a number of reasons but these are the most common.
Posted on Nov 17, 2009
SOURCE: My GE Profile washer Model number WPGT9350COPL
GE PROFILE HARMONY WASHER MODEL WPGT9350COPL WASHING CYCLE TAKING TO LONG
Posted on Feb 28, 2010
hardrocko
  • 1476 Answers
SOURCE: GE Profile - Fuse blown. Replaced it. Hear click when start
Fuses usually blow for a reason, there is or was a short. I have a tip which may solved your problem at http://www.fixya.com/support/r4265491-replace_bad_magnetron It explains how to check all the components. If only your display is working you know the transformer is ok but your problem addresses a problem that you do not see very often. You may have a bad control panel and that is why the replacement fuse did not blow. Whatever was shorted is now open. If you follow my instructions in the tip and find no problems I would replace the control panel. http://www.repairclinic.com can supply the parts. Let me know if you need more help.
hardrocko
Thanks for using FixYa and for the generous rating.
Posted on Mar 07, 2010
Gas range digital display reading too hot
If you haven't tried to reset (unplugged the electricity) try that, if it doesn't work, check GE's site. have your model number ready
Aug 11, 2012 | GE Kitchen Ranges
How much to fix ipod touch screen and where
Good morning, afternoon, evening or night; whatever time of day you receive this. You want to know how much to fix the touch screen and where to fix it? I want this solution to benefit you as much as possible. Having to pay for someone to fix your iPod touch screen should be your last result. I'm tell you some options you can try that may save you a few dollars and having someone to fix the iPod touch screen. I don't if this is the problem, but the touch screen may be locked. Automatically, the iPod touch locks when there has been no activity for a certain amount of time. To unlock the touch screen, press and hold the Home button or the On/Off/Sleep/Wake button which is located at the top of your device, and then drag the slider. If you want to set the amount of time before Auto-Lock activates, press Settings, General, Auto-Lock; then set your preferred time. If that doesn't fix the problem, you can try a system reset. To do this, press and hold the Home and On/Off/Sleep/Wake buttons together for approximately 10 seconds until the Apple logo appears on your screen. If this doesn't work, you can take your iPod Touch to your local Apple Retail store and have an Apple technician work on it for you. There will be a fee for diagnostic services. You can also contact Apple Technical Support or Online Service Assistant. For more contact information, go to this website (http://www.apple.com/support/contact/). I hope the problem is just a screen lock up and if you have to get a repair or replacement, it won't burn a hole in your pocket. Thank you for choosing FixYa as your one-stop solution spot for your problems and requests. Have a good morning, afternoon, evening or night; whatever time of day you are viewing this solution post.
Apr 26, 2011 | Apple iPod touch
My GE XL44 Gas Range just started beeping and has F-1 on the screen. How do I get it to stop beeping?
Hi ......A f1 code indicate a stuck or faulty touch pad or button?Sometimes moisture or a spill will cause this problem,Unplug 12 -24 hrs and reset.If this does not cure your problem turn off power unplug touch pad from control board and turn back on. F1 still there? If yes replace control board if not replace touch pad.If components are not separate electronic control will have to be replace, Hope this helps .Please rate my answer/response :)
Dec 13, 2009 | GE JGBP24 Gas Kitchen Range
RODNEY
May 12, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
HTC touch HD is completley frozen
If you have all your items saved to your computer with Active Sync, then do a master reset:
HTC Touch hard reset 14 January 2008
  • Power on.
  • Press and hold buttons marked 1.
  • Press and release 2 with stylus.
  • Release buttons marked 1 when menu comes up.
  • Press directly down on center dpad, marked 3.
You can also get tips & tricks from www.htcwiki.com
It has the latest and great updates, software, even known issues if you ever come across this. HTC does recommend that you do a master/hard reset once a quarter to keep it moving smoothly. Also, ensure you don't have a lot of open running programs. Perhaps once a day, clean the cashe and history. Do a soft reset (aka battery pull) once or twice a week. All depends on how hard you play with this lovely PDA device!
Feb 02, 2009 | HTC Touch HD Smartphone
Need Help
Have you tried unplugging it for 3 min? That will reset the computer. If that don't work you might need a new touch screen \ computer
Jun 29, 2008 | GE Profile Harmony DPGT750EC Electric...
Ge harmony top load model wpgt9350copl washing machine
This is a very complicated machine utilizing no transmission, rotor/stator type drive motor, and a locking/unlocking clutch mechanism design to either engage or disengage the wash basket. These machines are tricky even for professionals to properly diagnose.
Jan 19, 2008 | Washing Machines
GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket Logo
80 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
