My iGroove HG no longer "powers-up." It is 14 months old and was working fine. I've tested my outlet noting nothing. I'm not sure if the problem is related to the power supply or the unit itself.
  • Anonymous Dec 21, 2008
    I just discovered the same problem with my IGroove. I used a mulitmeter to troubleshoot the problem and believe it's the power supply (AC Adapter). It's $28 from Klipsch
I had the same problem and it was in fact the adapter, I found a suitable replacement for around $ 42.00 and it works great: Check out " LCDpayless.com ": http://lcdpayless.com/ , write to them and tell them the adapter type including part#: ADP-18V-201-4P
Posted on Apr 21, 2009
Louisann pellet grill series 900 ? model# flips breaker everytime when powered on. Why? Has never done this before.
need to test for short or jamming --with motor and other components - circuits
Jul 25, 2018 | Grilling
Klipsch iGroove HG: Power button blinks red
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Sep 03, 2014 | Televison & Video
Breville 860 - no longer getting constant pressure as the coffee shot is being produced. The pressure gauge fluctuates and the noise is no longer constant while producing the coffee shot. The machine is...
General with machine that the hot water outlet onto the ground coffee is blocked with very fine grounds. You need to clean this hot water outlet. Often there is a philips head screw in the middle of the perforated outlet that has to be undone.
Aug 25, 2013 | Breville Coffee Makers & Espresso Machines
My philips css2123 appears to no longer receive power
I ran into this today. Searched the web and found nothing. I finally decided to do what you did take it apart and see if I could find anything obvious. Nothing visible found. I didn't tear it down 100% like you but while I had it apart I decided to remove one component at a time and test it after each piece was removed of course removing power at each step. I do not have the same model as you but once I disconnected the sub connection to the board I had full power. So I decided just to test this plugged it back in and I still got power. Went through reconnecting everything and testing between and once I had all back together the unit functioned with no issues. So just re-seating everything or clearing out an error by powering on with out that component connected seemed to work. Not sure if this will help with yours but decided to share what I found in hopes it will help.
May 10, 2012 | Philips CSS2123 SoundBar - 2.1-channel...
Model ZHSC02PP-- Mini fridge no longer cooling (18-24 months old)
Has it sat any amount of time without usage? Check and see if any of the 4 walls is cool, it could be that the fan isnt working.
Jan 30, 2012 | Haier Refrigerators
I ve got a sharp aqueos tv i turned oevr channels
Try this: unplug the power cord from the wall, let TV set stand for AT LEAST 30 minutes, then plug back in and and see if the TV operates as normal.
Sometimes this works and sometimes it doesn't.
Good luck !
Jan 09, 2010 | Sharp 25N-M100 25" TV
Brookstone picture frame model 599324 was working fine for several weeks. then we noticed one day it was off and won't come on. we tested outlet - it's good. is there a bulb in it ? burned out? bad...
It is most likely the power 12V supply located behind the lower panel on the back of the frame. Mine went out after about 14 months. I had an old Laptop Power Block I was able to adapt to it & it works perfectly.
Oct 10, 2009 | Electronics - Others
My Acer keeps loosing power
hmm...sounds like you are suffering from a dirty power issue. how old is your house?
Mar 11, 2008 | Acer TravelMate 2300 Notebook
1,082 people viewed this question
 Grubhead
Grubhead
