On Skype I get blue screen events all the time. Have updated my QuickCam driver as advised, but it still happens
    Scholar:
  • 135 Answers
Uninstall skype, restart PC, download the newest version of skype, and reinstall... try it out
Posted on Nov 27, 2008
Blue Screen windows 7 PC closes with a Blue Screen and Restarts
There are a lot of possible causes for blue screen errors, but most of them relate to the computer hardware. The cause of a BSOD error can be a temperature problem, a timing error, a resource conflict, hardware failure, a corrupt registry, a virus or simply a device incompatibility or driver error.
How to analyze blue screen errors The first thing to do to analyze a blue screen error is to check the meaning of the STOP error code. You need to stop Windows from rebooting when a STOP error is encountered. Once the blue screen of death is shown, you can check the meaning of the STOP error code. Together with the filename of the driver or module, this will give an indication of the error cause.
Another option to analyze the cause of the blue screen error is to look at the Windows system event log or to debug the memory dump (minidump) that Windows created when the error occurred. The event log can be viewed using the event viewer. Right-click Computer in the Start menu, and then select Manage. In the Computer Management window select Event Viewer. The information in the event log can be of great help to isolate the cause of the blue screen error.
Reading the minidump requires a bit more technical knowledge, but Microsoft has tools to read the minidump.
The most common cause of blue screen errors In reality, the most common cause of blue screen errors is a device driver problem. Outdated, incorrect or corrupt drivers can cause the system to encounter a STOP error, resulting in the BSOD.
So the easiest way to try and fix a blue screen error is to reinstall and update your system's device drivers. This will ensure that all driver bugs are fixed and that all hardware has the correct driver.
If you know which device caused the error, you can update or reinstall that driver first. The file name in the blue screen of death can help identify the driver. Look for a file with the .SYS extension and search for that file name.
If you do not have the drivers for all devices, or are not comfortable updating your PC's drivers manually, you can use a driver update tool to find, download and update all device drivers for you. Such tools will accurately identify your computer hardware, including any device causing an error, and automatically install the latest drivers for it.
In most cases updating or reinstalling drivers will solve your blue screen errors.
Other causes of blue screen errors However, if updating device drivers does not fix the blue screen error, there are a number of additional things to try:
  • Load the default BIOS values - resource conflicts and timing issues can be caused by incorrect BIOS settings.
  • Update the BIOS - especially after adding new hardware or installing a Windows service pack this can help fix issues.
  • Update Windows - missing updates, including service packs can be a source of stop errors.
  • Check your system - run a virus scan and spyware scan after updating your definition files.
  • Driver rollback - if you have recently updated a driver, you can use the driver rollback to revert back to the previous driver version.
List of STOP Errors Causing BSOD:
  • Stop 0×00000003 UNSYNCHRONIZED_ACCESS
  • Stop 0x0000000A IRQL_NOT_LESS_OR_EQUAL
  • Stop 0x0000001E KMODE_EXCEPTION_NOT_HANDLED
  • Stop 0×00000023 FAT_FILE_SYSTEM
  • Stop 0×00000024 NTFS_FILE_SYSTEM
  • Stop 0x0000002E DATA_BUS_ERROR
  • Stop 0x0000003F NO_MORE_SYSTEM_PTES
  • Stop 0×00000044 MULTIPLE_IRP_COMPLETE_REQUESTS
Here are 2 solutions:
Solution #1 Scan your registry for errors.
A Registry Cleaner scans your computer for errors in your PC's registry. Your computer's registry contains information about your Windows XP operating system, including driver, printer, software information. Over time, your computer's registry may start to contain obsolete data. A corrupt registry will easily slow down the speed of your computer because applications and drivers are loaded even though they're not in use. Fixing your registry of errors will not only prevent the Windows XP Blue Screen Of Death, it'll allow your computer to boot faster, open up multiple folders quicker. A listing of registry cleaners can be found here.
Solution #2 Process of Elimination
When the CPU calls certain functions from the RAM, or Random Access Memory, and the data rests in a faulty section of the RAM, this will cause the blue screen to appear. I recall a time whenever my computer booted up and started loading the Norton Anti Virus program, the blue screen error message would appear. This happens because the CPU is accessing data from faulty locations within the RAM when loading the anti virus software.
This method involves having 2 sticks of RAM. Remove 1 stick of RAM and wait to see if the blue screen surfaces, do the same for the other.
Through process of elimination, you'll find the cause of the Windows XP blue screen of death error.
Because getting into the hardware can be a little techy for computer hardware "adverse" readers, a simple 2 step plan is to first clear your PC of any registry errors. Then if the blue screen of death goes away, we would have saved ourselves the trouble of having to open up the PC casing and touching the hardware components
Dec 08, 2010 | Computers & Internet
I have an acer that will go to a blue screen after I type in the password then it restarts itself over again the same thing!
Blue screen errors, or blue screen of death (BSOD) errors, are the most severe errors Windows can encounter. Since Windows can not recover from this kernel level error, a blue screen is displayed with the error details. The error details contain a STOP error code, which indicates the type of error.
hope it helps, if so rate the solution
Nov 29, 2010 | Acer Aspire 3690-2196 Notebook
Every time I download AIM, Skype or Oovoo I begin getting the Blue Screen Of Death. Aim used to work fine with no problem until the newest update. I don't know why this is limited to messaging programs...
The "Blue Screen of Death" is sometimes caused by memory errors. Xp hasn't got the best memory manager in the world so firstly download all of the windows updates including Service Pack 3.
Re boot in safe mode and uninstall the latest updates to your Skype etc programmes.
Re install them one at a time monitoring where and when the problem arrises.
Hopefully with all of the updates from Windows, it won't happen again.
Hope this helps.
Nov 27, 2010 | Acer Aspire One Netbook 8.9" Notebook
Problem with skype and web cam on windows 7
If you just downloaded the drivers, try restarting your computer so that the updates will register.
Apr 14, 2010 | Logitech Quickcam Chat Webcam
I've had no success in getting my logitech web cam to accept Skype. I tried for two hours yesterday. When I reboot, I'm back to square one: Skype telling me that it doesn't recognize my Logitech quickcam....
This reminds me when I had the same problem when Skype version 4 came out and it loaded so fast the webcam software was not in place and Skype could not detect the webacam.
The workaround was to right click and exit Skype and restart it but others on the Skype community chose to go back to an older version of Skype.
I'm surprised if its the same problem still as several updates have been made since then I thought it would have been patched - I am now on the latest version
http://www.filehippo.com/download_skype/
You can check out the skype community for similar problems
http://forum.skype.com/index.php?showtopic=334991
Oct 05, 2009 | Logitech Quickcam Chat Webcam
Skype web cam tries to erase my memory!!!
You should install the latest camera driver. Update the software. and reconfigure the camera.
Here is a link to help you configure your Communicate STX with Skype.
I sincerely hope it helps.
Sep 25, 2009 | Logitech QuickCam Communicate STX Personal...
Microphone problem
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You may have to install or update drivers Most of the drivers/software I get are from a web site driverguide.com you need to fill out a free registration then search for the driver you need download it in a format you can use install it and then most times reboot the computer
Please leave Comment or Rate answer for me to improve in the future
Jan 25, 2009 | Logitech Quickcam Chat Webcam
Logitech quickcam 8.3.0 is not working when I use skype.
update drivers:
http://www.logitech.com/index.cfm/405/&cl=us,en?prodcrid=405
and go into setup in skype and setup the video chat to use your camra. if that doesnt work.. try uninstalling the camera and software and starting over with new updated drivers.. be sure to load the drivers before you plug in the camera.
Dec 16, 2007 | Logitech QuickCam Messenger Web Camera
Resolution change on my lap top screen when I load my webcam
I had this problem on my PC and I tried everything from updating drivers to re installing the software and updating my graphics card but nothing seemed to work.
And then as a last resort I right clicked on the icon on my desktop and chose properties and clicked on the Compatability tab and unchecked on display settings Run in 640x480 screen resolution.
This worked and did not affect the webcam in anyway.
Feb 16, 2007 | Acer TravelMate 4672WLMi Notebook
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
