Question about Canon S400 InkJet Printer
Printer S400 won't print out blue and pink ink
I'm at a loss. The black and yellow ink prints, but the blue and pink don't. I've gone through all the maintenance steps and have cleaned the metal discs (at the bottom where you snap in the cartridges) with alcohol as well as taken out all the ink cartridges to make sure that the ink is coming through. The blue and pink are new cartridges just purchased and ink is definitely coming through. I've snapped all the cartridges back in place, but over and over again, just the black and yellow print out ... no blue or pink. What is the problem? What else can I do to make the color come through? It's interesting that the color comes through on the cartridges on either end, but the two in the middle are the ones not printing.
    Scholar:
  • 174 Answers
Hi..
The nozzles have gone bad...it needs to be serviced or replaced...i appreciate your efforts yoy put in to fix the problem thats best we can do after all its a machine.if the printer is in warranty contact the manufacturer.
Regards,
debroy
Posted on Nov 25, 2008
Blue colour is missing from colour cartidge
Something may have gotten stuck in the blue ink and clogged it. If the cartridge is new you may be able to send it back and get it replaced, If not you may just be out of blue ink.
Aug 04, 2013 | Lexmark X1270 All-In-One InkJet Printer
My epson DX8400 won't print yellow at all, green prints as blue, red prints pink on certain documents i've created. I have printed an email off today which printed all the colours perfectly??
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Thank you for using Fixya
Aug 22, 2011 | Office Equipment & Supplies
Why does the blue colour turn out red on printing plus the yellow is mainly pink?? I am trying to print out invites for my son's 10th birthday & he is not impressed with the pink!!
See if the ink cartridges are installed correctly. It may be that your Magenta and Yellow ink cartridges need to change places. So, try replacing the cartridges, put the Magenta where the Yellow is, and the Yellow where the Magenta is.
Usually the ink cartridge placement follows this order:
Cyan, Magenta, Yelow, Black, so see if the cartridges on your printer match. Also, check to see if there are color markings on the print-head itself, and make sure the markings match the cartridge inks.
If the ink cartridges are aligned properly and the Black is printing out just fine, you may be looking at a software issue, and you'll need to remove the printer from the Devices list (go to Start -> Control Panel -> System), unplug the printer from the PC and restart. Then, install the drivers first, and after that plug in the printer cable to the PC.
If this was helpful and informative please vote with a Thumb Up. Thank you.
Jan 28, 2011 | HP Office Equipment & Supplies
Replacing Blue Ink cartridge
The nozzle check takes very little ink it sounds as though you need to do a head clen though.
Aug 01, 2009 | Epson Office Equipment & Supplies
Prints all yellow, with some blue and black, no brown
the problem is very simple the magenta ink the cartridge is over or the head is been blocked from where the magenta ink comes out,
because red colour requires ---yellow plus magenta(pink)----to make it red.and ----dark yellow plus magenta(pink) -------- for brown colour.
Nov 22, 2008 | Canon PIXMA MP780 All-In-One InkJet...
CANON S400 PRINTING PROBLEM
What printer do you have? Clean heads, clean heads, clean heads, etc. Then do the test print to see if the heads are open. I had similar problem with an Epson, had to clean the heads often, finally got to where the heads wouldn't clean so threw it away and bought another one (HP this time, the heads are included in the ink carts, haven't had to clean the heads at all.)
Nov 02, 2008 | Canon S400 InkJet Printer
PROBLEMS WITH COLOR NOT PRINTING
pictures are coming out with a green tint
Aug 01, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Pink teal lime
the printer cartridges have the ink Blue (light blue), red (pink) and yellow (lime).I think your printer printing fine do not worry all the printer have same ink........If you have the problem with color on print outs :you this link ::
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:549:0:0&framed=&docid=ENUS25128&relevance=1
Mar 17, 2008 | Lexmark X5470 All-In-One InkJet Printer
Canon iP6700D printer
Browns printing pink suggest the blue/yellow jets are clogged or not functioning. If the uses head in cartridge type[that is with a sheet of contacts on the front of the cartridge- then take then out ,damp a tissue in some warm water an place on a plate or similar - then stand the cartriges in the damp tissue until the tissue turns colour - then replace the cartrdge. If it is head in the printer Then take a look here www,fixyourownprinter.com
May 24, 2007 | Canon Pixma iP6000D InkJet Photo Printer
Canon S400 InkJet Printer Logo
375 people viewed this question
old marine
old marine
