Question about Rangemaster 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range
Need to change grill elements.
How? I have new elements so can see 2 spade connectors on each but do you have to do anything other than unscrew one crosshead screw, remove and refit?
  • moulesi Apr 08, 2009
    mine had twin elements, first one changed no problem, when fitting 2nd one one of the spade connecters disappeared back through the whole and i cannot retrieve it, looked behind cooker and cannot remove plate to get to wires, can anyone help?
    Habit-Forming:
  • 171 Answers
Yes, just like that,but make sure there is no electricity, unplug the stove.
Posted on Dec 12, 2008
My ovena akl887/701 element has gone how do i change it
you should get 18 ohms across an element if its ok swich off cooker remove shelf's normally 4 screws holding on back panel inside oven you can now see element 2 screws hold element in position you may see them inside oven or failing that remove rear panel of oven and undo screws pull off spade connectors refit new element it dose not mater witch way arond the cables go as long as the earth is in the right place if fitted
Dec 09, 2016 | Ovens
How do I hgain access in order to replace the heater element on my Zanussi dw 905 dishwasher?
www.zanussi.co.uk/Support/
You can get details from the manufacturer .
Jun 23, 2014 | Dishwashers
When I turn my dyson DC25 while vacuuming, it shorts out and comes back on again when I straighten out. Is this something I can fix myself?
Common problem is a break in the wire where it enters machine, caused by accidently stepping on cable when using vacuum. Unplug appliance from mains then you need to gain access to where on/off switch is (normally one star/Torx screw to remove cover) pull spade connectors from switch then cut about 3-4 inches from cable, strip wires and re-attach to spades then reassemble. A bit of a fiddly task but won't cost you much. Tools required: Torx size 6 and a small crosshead screw driver, wire cutters/strippers, insulation tape, it may be easier to buy new spade connectors as it's difficult to pry them open to re-use. Basic electrical experience (if you can wire a plug correctly you can do this!)
Jun 02, 2014 | Dyson DC25 Vacuum
How to replace fuse in a waring pro waffle maker
The fuse is inside, clamped to the bottom iron.
Swing the top open. There are 4 small screws, two metric M3 flatheads in the front pivot, two self tapping near the hinge, that hold the bottom iron in place.
Often the M3 screws will become fused to the captive nuts. Using the correct size cross-point screwdriver, position it in one of the pivot end screws, and while holding it firmly directly in line with the screw, give the screwdriver a sharp tap on the end of the handle, as if it were a chisel. Repeat with the other front pivot screw.
If the screw does not unscrew with a minimum of force, repeat the tapping procedure. If this does not work, use a 1/8" metal bit to drill through the screw heads. Remove the rear screws.
There is a spring-loaded pin running through the front pivot halves. Press it in and carefully swing the bottom grid upward. Turn the iron upside down. At the rear of the irons, you'll see where the wires enter from the rear support. Find the metal clip holding down a piece of white rubbery tubing. Remove the screw and clip. The temperature-limiting fusible link is inside the tubing.
Push the tubing toward one side until the wire crimp is seen. On the fuse side of each crimp,AS CLOSE AS POSSIBLE TO THE CRIMP, clip the lead. Remove the tubing and clip the other lead.
Take two uninsulated crimp-style spade lugs for 20 ga wire, and clip off the spade ends. The crimp ends will be your new crimp connector.
From the iron's leds, remove the old crimps. Strip just enough jacket for the exposed wire ends to match the length of the new crimp connectors.
Take the stripped lead that is toward the iron's terminal, insert into a crimp connector. Insert one end of the new fuse in the other end so the overlapping leads each just reach the opposite end of the connector. Crimp in place.
Slide the tubing over the fuse and push it toward the iron. (The loom tubing on the other wires will compress to permit this).
Connect the other end of the new fuse to the remaining stripped wire with the second crimp connector.
If you had to drill out the M3 screws (I did), use a vice grip wrench to grasp the remaining shaft with as little compression as possible and remove. The threads of the captive nuts should be ok. Replace the screws with M3 flat head crosshead screws and antiseize compound of the threads.
Notes:
1. The most common reason for thermal fuse failure is running the iron empty with the top raised.
2. I got replacement fuses via ebay 4/$2, M3 screws at Ace Hardware @$0.19.
3. All the wires inside the iron are insulated with high temperature silicone or non-melting jackets. Stripping requires an electricians stripper/crimper with a 20-22 ga cutter. More force is needed to strip these wires than you might expect. You'll find it much easier if you hold the wire being stripped with a pliers while stripping.
Feb 17, 2014 | Waring WMK300 Professional Belgian Waffle...
'grill element wont heat'
Assuming you have power to the cooker, its easy to change out the element (make sure when you are doing the job that you dont touch it with your skin due to oils on hands decreasing the new elements life).
Firstly isolate the power to your cooker
assuming its a built in unit have a look at how it is secured (is there 2 screws holding the unit at the back? if so all you need to do is remove the screws and the holding bar at the middle (again its either held on with screws or just clicks in to place) and gently pull the broken element out, take a photo or write down the sequence from left to right of the colours of the spade connectors, then remove the connections and simply install the new for old making sure you remember the sequence of the wiring. If you do not see any screws holding the element at the back you need to open the oven door and remove the four screws holding the unit to the frame and pull it out on to the floor.
Then you remove the back panel and you will see 2 screws holding the element in place with the wiring exposed (spade connections/take photo) pop off the connections remove the screws and exchange the damaged element over, taking care to rewire like for like, put the back panel on push the unit in and fix it back in place with the four screws. Switch on and enjoy.
If you had the cookers id i could have given you a link to get a new element (cost20-30 pounds).
Just do a google search the item number should be seen when you open the door.
Oct 05, 2011 | Ovens
The grill (Upper Oven Grill Element) in the oven is not working, I realized the 4 wires at the back that connect to it are all loose. Can i fix it by connecting them myself? is it something dangerous or...
With 4 terminals, it sounds like a double grill element. But it could also be a single grill element with a second oven element. If the spade connecters are loose they need to be tightened first. Get a pair of pliers and gently squeeze the terminals until the gap reduces so when it slides on it will be tight. Do you know what wires go where? If so reconnect them. If you don't do the following;
As you look at the element terminals they should run horizontally. Look at the element inside the grill compartment. From left to right, the no. 1 and no. 4 terminals should be the same element and the no. 2 and no. 3 terminals should be the other element. If this is correct put the 2 neutral wires, in any order, on terminals 1 and 2 and the active terminals on 3 and 4. This should work. You just have to check the correct element comes on when you operate the grill/oven controls.
Feb 18, 2011 | Smeg Ovens
How do i replace the heating element in a diplomat aca3200 oven?
make sure the oven is switched off.remove all trays etc from oven,remove 2 posidrive screws from bottom of fan plate,remove fan plate,the element is around the fan,remove 2 posi screws from where the element goes through the side of oven and the one screw that holds the top of the element to the back of the oven.slowly pull the element out and remove the 2 poz and neg spade connectors.refit as removed.
Dec 30, 2010 | Ovens
Had foolishly tried to remove baking element w/ oven turned off but still plugged in / breakers still on (all to make cleaning easier-ha!) unscrewed element beleiving it was modular like stovetop elements....
Some times s**t happens. The most likely situation is the wire connections that connect the heater have burnt off, or simply just become disconnected.
the normal repair or replacement to the lower heater element would be to disconnect the wires from the heating element by sliding the wire off of the spade connector. Some times they are connected by a screw and nut terminal. Next to remove the screws from inside the oven, and then pull the element out from the back wall. I can see how you could easily interpret that they would slide out like many stove top elements.
In your situation confirm that power is off.
Remove back panel and check terminal' connections to the heating element. repair.
Model ra520w3 HOTPOINT ELECTRIC RANGE Parts
maxresdefault-es3dyrcoa4nhevk3e5ork442-3-5.jpg Hope this helps?
Jun 21, 2017 | Hotpoint RA520 Electric Kitchen Range
Zanussi built in oven and grill the element has gone but dont know how to get element out to replace any ideas thanks
If you mean the fan element then take all the racks out of oven and at the back is a panel with 4 screws remove may need a tap with hammer and screwdriver to shock rust etc. then undo screws on element maybe 3 screws pull gently forward(electric off).Try to pull the spade connectors off without losing them into back of oven if you lose them then you will have to take out oven and remove back plate. refit new element.If it was the grill element just follow above and find behind back plate.Hope I helped.
Apr 11, 2010 | Zanussi ZBF360X Electric Single Oven
How to replace the grill element in a Stoves 720EF double oven?
1) Isolate the unit by turning the power off at the main switch.
2) Remove appliance from housing unit.
a) When handling the appliance care should be taken to ensure the outer frame trim is not damaged.
b) The appliance is secured into the housing unit by 2 screws through the top corners of the front frame, open the doors and unscrew the 2 corner screws.
c) Grasp the bottom of the frame, pull forward and out onto a suitable surface.
3) Unscrew the top and rear panel securing screws and lift the panels clear.
4) From the rear of the appliance, pull off the 4 (top) grill element leads and the earth lead.
5) From inside the oven unscrew the 2 screws from the grill mounting plate.
The above is from the Handbook. I assume from point 5 the element is then free to be removed. reverse the procedure to fit the new element.
If you want a copy of the Handbook, then I will need an email address for you.
Mar 11, 2010 | Stoves 720EF Electric Double Oven
Rangemaster 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range Logo
343 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
