my camcorder only plays a few seconds then a eject arrow appears on the scene.my camcorder only plays a few seconds then a eject arrow appears on the scene.
i have same problem too dose it always happen? halp plz i have same problem too dose it always happen? halp plz
AnonymousJan 25, 2009
This model doesn't have a disc OR a memory card. The error has nothing to do with this. I'm afraid your recommended fix is completely inappropriate for this model. This model doesn't have a disc OR a memory card. The error has nothing to do with this. I'm afraid your recommended fix is completely inappropriate for this model.
no that u must remove ur camera and try to clean all strip that connect with board and mechanisum and all connectors legs solder then it will work .any doubt call u.a.e no 00971503853766
This behaviour is relaterd to tape reading / tape detection. You may have a dirty or worn-out head on the video heads drum.
You may try to use a cleaning tape in order to retrieve normal perfoming of your camcorder, BUT you should take care, as cleaning tapes are also abrasive tapes, and the amount of cleaning cycles a video head can support is limited.
Then it should be possible that after cleaning the result is nul or worse (I had this lately on an old Sony Camcorder, it was recording with much losses in the film, after using the cleaning tape it doesn't record any more).
All that means you may repair your camcorder with the cleaning tape, but you may finish it too, if the video heads are too old.
In any case take time to read the cleaning tape user manual, cleaning time is very short (10 seconds generally) and must'nt be overtaken.
The C31:22 message indicates that one of the motors inside has failed to turn. This is a safety message and the unit will eject the tape to prevent the tape from getting damaged. Unfortunately, there is little that you can do other than get the unit into a service shop. The repair of this will require dis-assembly of the unit. I would suggest that you either get an estimate for the repair or send the unit to Sony using one of their fixed rate repair options.
If you open the eject thingy like normal then look for a small white plastic tap. its located right underneath the "start/stop" text you see on the back end of the camera (where the record-button is). You´ll need something like a small screwdriver or similar. Press it and and the tape ejects like normal. Worked for me. Saved me the repair bill :)
I had the same problem with my camcorder just awhile ago. This can reflect a low battery. Try plugging in the camcorder for a couple of hours without using it. Then try recording or playing back the tape with it plugged in. Unplug it and check again. If this does not work you may have to replace the tape head.
I have the exact problem. It's so annoying
Every time I try to record, play, fast-forward, or rewind, it does so for about 3 seconds and then gives me an eject sign.
