Question about Sony KP-51HW40 51" Rear Projection Television
Rear projection TV picture problem
Recently our screen is out of focus. You can see green & pink colors. Are the projectors out of alignment? I have made an appointment with a tech in two weeks. What should something like this cost to repair. TV is only 3 1/2 years old. Brand; SONY 57" Rear projection. Thank you!
  • Anonymous Aug 19, 2008
    mvoed the projection tv and the screen went out of place now it is doubleing
  • clintonneel1 May 25, 2009
    the screen has a red hue to it and if the movie or show is dark the screen is almost all red and can't see anything.
Open up the back and look at the top of the glass leans covers if they are dusty clean it
Posted on Jul 14, 2007
I have some picture distortion - pink fuzzy color where white should be (like on hockey ice). I'm trying to determine if the t-con board is to blame and if I might fix it easily
Hi Bill.
I don't see a specific model for your TV, but have owned a rear projector system before. There is usually a sub-menu where you can do fine alignment of the Red, Green, and Blue projectors to get rid of the pink fringe. There is generally a white crosshair at center screen where you can fine align the three colors to get rid of the fringing, and sometimes an advanced menu where there are crosses all over the screen that you can individually select and fine tune, (tweaking the different optical distortions of the individual projectors to overlap).
If the fringe is a big swath instead of a fine edge, or if a color is totally gone, then you may be talking power amp issues. For fine fringes, the adjustments usually work fine.
Hoping that helps!
D
Dec 18, 2015 | Televison & Video
My RCA P52937SG projection tv. Picture distorted. I beleive it has to do with the green circuit / projector. Everything needs to be aligned to green. Green projector is on, but, in alignment screen I get...
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board must have replace the 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 28, 2011 | RCA R52WH73 Projection Television
Picture is bowed inward and looks like a 3d image without the glasses. I also have a green, red, and blue line curving across the top of the picture.
Looks like the focusing lens may have moved a bit or the projector lamp has gone weak. Get a technician to check up the projector.
There's very little you can do here.
Mar 05, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
The picture all of a sudden became blurred , color convergence is not aligned and there is a pink wave at the top left of the screen and a green wave at the bottom of the screen. When the color is adjusted...
Tv have convergence problems,it dead.Colors lines R,G,B don't aligned.The tv convergence board is dead.The 2 STK convergence ICS and some or all it resistors are dead,these parts must be replaced to solved the tv pictures covergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 18, 2010 | Sony KP-43HT20 43" Rear Projection...
My zenith big screen tv is out of focus and we cant find any master focus control. How do we fix the focus?
It is unusual for a rear projection to be out of focus since the projectors are fixed. But, it is common for the projectors to be out of alignment, in which case the picture will look like a bad 3D movie of yesteryear.
Go to the setup options / menu, look for the ALIGN option, follow instructions on screen.
Jun 13, 2010 | Zenith R60V26 60" Rear Projection...
My Tv has red light (color) out of focus..I've tried tuning the lance but it's not the problem in the lance..it's something else..don't know what..do you?
Your TV has three picture tubes which are aligned to properly converge the projected light beams on the screen. Each picture tube projects a single color of Blue Green or Red. During production your TV was carefully adjusted to properly align these colors. As a feature you have the ability to adjust these colors.thats called convergence.If you don't have a manual to show you how to adjust you can find one here http://www.mitsubishi-tv.com/support.html
Mar 03, 2010 | Mitsubishi WT-46809 46" Rear Projection...
Picture is doubled and color has pink tint
The inherent problem with rear projection TV's.
It sounds like the projectors need balanced (or a lamp is failing) and aligned. The alignment can inadvertently be changed when the TV is moved, and seldom "just happens".
Any decent TV repairman can perform the required service. I would shop locally for one.
Dec 27, 2009 | Hitachi 53UWX10B 53" Rear Projection...
No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Apr 17, 2007 | Sony KP-53S65 53" Rear Projection...
Concave Images with pink and green colors
you can get it your tv fix the problem is in the IF amp and video circuit.a convergence will also be neeeded.the tv is old but can give you some more life call a tech they will be your tv doc.
Apr 03, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
954 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
