Question about HP LaserJet 1300 Printer
Blank paper print always
When the printer on the paper outmatically printed with out ant textt i.e blank paper contineusly
Step #1 Check toner cartradge , if you are not expert read the instruction of installing new one, I mean you have to remove the toner seal. replace it by well known good one (used one). step #2 if above not your prblem, follow the instruction mentioned by tomj23.
Posted on Jan 06, 2007
  • 624 Answers
Hi sema, For this type of problem the first suspect is the toner cartridge: -Make sure it?s seated properly. - Look for the electrical contacts that connect to the toner cartridge. When you find them make sure the spring contacts on the printer are connecting to the cartridge and that they are clean. -Try installing a brand new, preferably genuine (not a refill) Canon cartridge. If none of this works then the next steps involve disassembly. If you are comfortable with this you can try: -testing all connectors to make sure they are plugged in and oriented correctly -check all wires (for damage) and secure connections -If you don?t turn anything up here then you are better off going to an authorized repair shop. Otherwise you?ll wind up buying parts to test with and guessing like that gets expensive unless you luck out and guess right the first time. Let us know how it goes and please don?t forget to rate the posting.
Posted on Jan 05, 2007
SOURCE:
When asked to print my c5180 all in one ejects blank sheet of paper making no attempt to print
Just click below for more information;
s.gif » Macintosh: All-in-One Ejects Blank Page or Pages in Mac OS X V10.4
Mac OS X V10.4: A blank page or pages emerge from the product when it is turned on. s.gif » A Blank Page Prints at the Beginning of Every Print Job ...
A blank sheet of paper prints at the start of every print job. s.gif » Load Paper
Instructions on loading paper and envelopes. s.gif » When I Try Printing in Windows Vista, My Printer Is Not Available in the List of Printers ...
Windows Vista: The product does not appear in the printers folder when attempting to print on a network. s.gif » HP Photosmart C5180 All-in-One Printer: Manuals
... HP Customer Care | HP Photosmart C5180 All-in-One Printer | Product information HP Photosmart ... One Printer | Product information HP Photosmart C5180 All-in-One Printer: Manuals About these files: These
Hope this may help;
Regards,
VOTIT
Aug 23, 2008 | HP Office Equipment & Supplies
PAPER FEEDS INTO PRINTER BUT COMES OUT BLANK
HP DeskJet f4280 Spitting Out Blank Paper. - HP Support ...
h30434.www3.hp.com > Printers & All-In-Ones > Print Issues
Solved: I can hear it printing, but the paper is blank when it's finished. ... Mark as New; Bookmark; Subscribe; Subscribe to RSS Feed · Highlight · Print · Report ... green checks say every thing is good to go, but the test print comes out blank,. ... Reinstall the cartridges into the product, and then gently close the cartridge door.
my printer is printing blank pages, and i just changed ink
Nov 18, 2015 | Office Equipment & Supplies
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
Printing blank pages on Lexmark C510 printer. Throws a 34 Short Paper error first, prints out a blank page. I have replaced the black toner, but problem continues. Demo page printed colors successfully but...
For 34 Short Paper error, reseat the tray guides and make sure it is set properly. Also, set the correct settings in the computer. For blank pages, always double-check the paper settings and again the settings in the computer. For not printing black, print the Print Quality page and see what color is not printed or not showing. If Print Quality shows black, try printing any document from any application in the computer. Check if you still have the problem. If problem is not resolved, leave a comment so I can get back to this.
Apr 09, 2010 | Lexmark C510 Laser Printer
I have an HP C7280 AIO printer. Everytime I print, it always form feeds a blank page bewteen each printed page (print page 1, form feed a blank page, print page 2, form feed a blank page, and so on).
Generally, there are printer set up programs that will let you chose to put a blank sheet or to not do that. If you have a disk or manual, look for the set up utility and go thru the tabs to find paper handling or something similar to that. There should be a check box you can clear to stop the blank page.
I hope that this information was helpful. Have a great day.
Brian
Jan 24, 2010 | HP Photosmart C7280 Printer
When I click "Print" paper feeds through the printer, but nothing prints
try to reload your catridge on the carrier or cartridge holder..
and clean your printer tab circuit and also the cartridge tab circuit and run maintenance page on it..
go to your printer panel and select maintenance ..browse clean printhead..and print maintenance page..to clean the cartridge..
May 18, 2009 | HP Office Equipment & Supplies
HP LaserJet 1300 Printer Logo
50 people viewed this question
Clive
Clive
Thomas F. Schneider
