Question about HP LaserJet 1320 Printer
HP 1320 will not print
Yellow light is blinking. I removed a paperjam, Turned off pinter, Turned off Computer to reset both. The yellow light still blinks and will not work.
    Scholar:
  • 174 Answers
Hi..
what about the ink levels...open the backdoor of the machine and check for any obstacle....disconnect all the cables..press and hold down the power button for 30 sec..reconnect all cables..try again...try connecting the machine directly to the walljack.
Posted on Nov 25, 2008
Yellow light is blinking?
If the bottom amber colored light is blinking, the imaging drum needs replaced.
If the yellow print cartridge light is blinking, then replace the print cartridge (yellow toner).
Mar 24, 2014 | HP c9705a - Color Laser Jet 2500l Printer
Hp Besiness inkjet 1100 fault codes cayan maginta ink and paper lights come on dead
HP Business Inkjet 1100 stops everytime after the first line stars to print. The power is one, the ink drop light is lit, the "yellow" indicator light also on, and the paper light all on. None of them blinking. We replaced the yellow cartridge with a brand new HP 11 yellow cartridge. Turned the printer off and on to reset. Printer comes on everything looks good till you try to print anything, even a on line word doc? Then it happens again, so we replaced the yellow again...same thing. We ever cleaned print heads, Any assistance would be welcomed?
Jan 12, 2010 | HP Business Inkjet 1100dtn Printer
Printing problem
Turn off printer
Hold down green button
Power on printer. (cold reset)
In printer properties choose print directly to printer, then choose print test page.
Weird problem
Feb 06, 2009 | HP LaserJet 1320 Printer
The yellow light blinks and it won't print
I also started having problems with my HP 870Cse when I began using refilled cartridges and had ink leakage (cartridge contacts corrupted). Check for this problem. If so, remove cartridges and gently clean the spillage. Then try using HP brand cartridges and see if this doesn't remedy the problem.
Jan 21, 2009 | HP Deskjet 870cse Printer
HP 1320 will not power up
There actually was a misfed sheet, hidden at the very bottom of the lower hinged back panel. The reason it was misfed was that this panel had somehow gone off one of its hinges. Ironically I did not discover the misfed sheet until I had taken the printer down from its shelf and turned it over to read the serial number to the extended warranty tech support guy.
Moral: Open every panel carefully, check for misalignment. These printers have flimsy plastic parts.
Dec 13, 2008 | HP LaserJet 1320 Printer
1320 not printing all the time
Your USB cord may be too long, or you have too many USB devices running. Try removing any other USB device, except the printer and do a test print.
Nov 17, 2008 | HP LaserJet 1320 Printer
Hp desktop 1320 printer has yellow light on - it the icon symbol
The symbol for toner low is a box, without a top, with an arrow made of dots pointing up. Insert an new print cartriage.
Nov 12, 2008 | HP LaserJet 1320 Printer
I ahve the same problem and HP is absolutely NO HELP!! I'm ready to trash a printer that has hardly ever been used.
Sep 14, 2008 | HP LaserJet 1320 Printer
Will not print at all
You can try restoring the printer to factory settings..and try agian it has worked most of the times for me..Let the catridge be in the printer when you do this..
Oct 27, 2007 | HP DeskJet 960c InkJet Printer
HP LaserJet 1320 Printer Logo
326 people viewed this question
Ben Johnson
