Question about U-Line Wine Captain (2015WC) Wine Cooler
Water seeping out the bottom of my wine cooler
I noticed that the side of my wine cooler was seeping water and lifting up the wooden floor boards.
I checked underneth and saw that the "coil" area had lots of dust.
Also, it appears that the on and off buttons do not seem to work.
Water cumulates at the bottom section of the cooler and also seems to seep out side.
  • Anonymous Mar 30, 2014
    U-line Wine, Cap 183018WCS
    The unit is set at the highest temperatures
    65 degrees for red wine
    50 degrees for sparkling
    55 degrees for white
    When I measure the temperature in the box the reading was 16 degrees.
    three bottles of wine actually froze at the bottom of the cooler.
    As far as I know it has not shut off in the three days I have been watching it.
    I just placed it in energy saver mode.
    It did say that red wine zone T short-what does that mean. Could not find anything in the user guide. Any suggestions?
  • 286 Answers
Your on/off switch operates the light only.Some thermostats you need to turn counterclockwise until it stops then there's a hard turn to off position.U-lines winecaptains needs to be sealed and also in little humidity. Check seales and try to find out where the leak is exactly.
Posted on May 28, 2009
  • 51 Answers
There should be a drain pan that you will periodically remove. Condensate (water) is a normal byproduct of all refrigeration devices. Also look for a drain fitting that you can run to a waste line.
Posted on Nov 25, 2008
Beeping will not stop on wine cooler - red wine side
Beeping usually indicates that something has gone wrong. Probably not cooling properly. The water coming out would indicate that the unit has defrosted. Turn the unit back on again and see if the red side is cooling properly. Some wine fridges have independent evaporators which allows different cooling temps in different parts of the cabinet.
Jun 26, 2014 | Danby DWC2727BLS Silhouette 54-Bottle...
Edgestar wine cooler blowing fuse on the left side circuit board
If you have replaced the circuit boards it's probably associated with a wiring short circuit or compressor failure. Suggest you get a professional technician to further investigate the fault. In the interim check for a short to the frame of the unit, an internal light or for moisture issues or a condensation issue from water.
Mar 25, 2014 | EdgeStar ES TWR325ESS-32 Bottle Dual Zone...
Plugged drain
Need to completely defrost freezer. hot rags, hot water, paper towels, etc. Until you get all the ice out you don't have a chance of unclogging the drain. Could be just ice clogging it too which in that case hot water will solve that as well. If it's something else clogging the drain, I've used a mini bottle brush to unclog them or even a stiff piece of solid wire.
Mar 18, 2013 | KitchenAid KFCS22EVMS Stainless Steel ...
How should I clean my wine cooler?
You should follow my exact instructions in order to clean your wine cooler properly.
1. Unplug your cooler and remove all items from it.
2. Clean the inside surfaces with a mild cleaner (I recommend you to mix water and soda).
3. Clean the wire shelves.
4. Clean the wooden shelves.
5. Wash the outside of the cooler.
6. Dry any wet part with a soft cloth.
Aug 14, 2012 | Furniture
Our kenmore wine cooler started leaking water all over the floor.
I don't know how it is leaking water, it isn't hooked up to a water supply. better start looking for the actual source of the water
Mar 23, 2011 | Kenmore 13485 Wine Cooler
Wine Cooler Temperture Regulation
Replace the circuit board . Please Rate This !!!! Thank You!!
Jun 08, 2008 | Haier HVF042 Wine Cooler
Water leaking from unit
It may be the drain line is not dripping into the catch bucket under the back side, visually check to see if the line is reaching into the bucket and that it's not clogged up on the inside of the unit floor. The back panel being wet may just be condensation in between cooling cycles as the frost melts. If the unit is OK with keeping temps the refrigerant charge is likely OK.
Nov 21, 2006 | Haier HVF060A Wine Cooler
Open Questions:
See all U-Line Wine Captain (2015WC) Wine Cooler Questions
U-Line Wine Captain (2015WC) Wine Cooler Logo
576 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
