Question about Lexmark Office Equipment & Supplies
This is the 3rd time I fill this box, it is not my day. Error 0502 It does not print, the paper goes thru as soon as I hit print and of course it tells me I don't have any paper. Please help. MODEL X 6150 Lourdes
Since I did not hear from you I contacted Lexmark directly.
Thanks
Posted on Nov 27, 2008
Printer won't print--error 0502. What is this and how do I fix?
After months of use, your printer might get the habit of stopping in the middle of a page and showing "Hardware Error 0502" on the LCD display. If you leave the printer alone for a while, it might start printing again. Then again, it might not. Pretty annoying.
The Lexmark support site will let you power off, remove the power cord for 30 seconds, take out the cartridges and fiddle with some encoder strip. This whole procedure might take you up to 30 minutes and it will not help (been there, done that).
On the multi function machine seems to be a coating on the metal rod that the cartridges travel on. Just wipe this rod with a kleenex and the problem seems to go away. Somehow it presents a drag on the cartridges and causes an error.
Clean that with a paper towel. The towel will be black from the ink residue, but you will be able to print again.
Feb 09, 2011 | Lexmark X5150 All-In-One InkJet Printer
Get harware error 0502 every time I print.
try this
http://www.fixya.com/support/t114419-error_0502
if that doesnt help
what is the brand and model of your printer lexmark?
May 04, 2008 | Office Equipment & Supplies
Error message hardware 0502 comes up as soon as I turn on printer.
After months of use, your printer might get the habit of stopping in the middle of a page and showing "Hardware Error 0502" on the LCD display. If you leave the printer alone for a while, it might start printing again. Then again, it might not. Very annoying.
The Lexmark support site will tell you to power off, remove the power cord for 30 seconds, take out the cartridges and fiddle with some encoder strip. This whole procedure might take you up to 30 minutes and it will not help (been there, done that).
On the multi function machine seems to be a coating on the metal rod that the cartridges travel on. Just wipe this rod with a Kleenex and the problem seems to go away. Somehow it presents a drag on the cartridges and causes an error.
Clean that with a paper towel. The towel will be black from ink residue, but you will be able to print again.
Feb 01, 2011 | Dell A940 All-In-One InkJet Printer
Printer displays hardware error 0502 wont print " HELP "
The 0502 error can have any of four possible causes:
- A faulty black/photo cartridge
- A faulty color photo cartridge
- A dirty encoder strip
- The encoder strip being out of position
.... most of the time, it's the encoder strip that is giving the problem..
goto
http://support.lexmark.com/index?userlocale=EN_US&locale=EN&page=content&segment=SUPPORT&productCode=LEXMARK_X5150&id=HO2707
May 24, 2010 | Lexmark X5150 All-In-One InkJet Printer
What is a Hardware Error 0502?
There is a shiny steel bar inside the printer, and the ink cartridges move up and down this bar to print on the page. If this bar gets gunked up from stray ink or paper dust, then the motor strains to move the print heads back and forth, and you get this error.
Fixing it is simple. Take some kleenex, and with power unplugged, clean the bar very well. Then Spray some WD-40 on a Kleenex, and lubricate the bar by wiping the WD-40 kleenex on the bar.
If this helps, be sure to hit the "thumbs-up" for me!
Dec 27, 2009 | Dell A960 All-In-One InkJet Printer
Printing error says: Hardware error 0502 (?)
he real answer is given by a person called ‘clem’: 98393885_c4f82c99a9_m.jpgHardware Error: 0502.
Clem
(from fixyourownprinter.com)
This works! Clean the ****** with a paper towel (another page talks about re-lubricating the thing, but that was not necessary in my case). The towel will be black (ink residu, presumably), but there you go printing to your heart’s desire again.
Jul 12, 2009 | Lexmark X5150 All-In-One InkJet Printer
Error 0502 on lexmark 5150
does it happen when you want to print? when you want to print u must choose the long way, then select ure printer on the screen (windows office) and print with that, it can be that someone else used your printer,, and changed the options
Mar 21, 2009 | Lexmark X5150 All-In-One InkJet Printer
X6150 keep showing 0502 error when printing
I fixed my friends printer, Lexmark x6150 which had the same error and symptoms. The registration strip might be out of its so called slot but I doubt it.
Get several cotton balls and a bottle of rubbing alcohol. Turn off the printer. Soak a cotton ball, not dripping or saturated with the alcohol. Clean the paper path ( area underneath where the print cartridge carrier travels back and forth over the paper. ) This area becomes coated with ink and gets sticky, Clean the area until all ink is removed, you will use many cotton balls, continue until clean. Check the carrier parked area. You will note 2 rubber boots, 1 for each ink cartridge, make certain they are clean as well. They seal the cartridges so they don't dry out.
Jan 10, 2009 | Lexmark X6150 All-In-One InkJet Printer
Printer problem
check the type of paper..that type that's for copiers is NOT recommended for printers.
http://tinyurl.com/6qcpgy
Aug 19, 2008 | Epson Stylus CX3810 All-In-One InkJet...
Hp psc 2410 photosmart
marglet, Turn-off and unplug the printer for a couple of minutes...there may be improper setting stuck in the printer memory. then plug it in and try to print the envelopes..if that doesn't work...Make sure there aren't any custom print settings causing this. Lastly...Try updating the drivers. Download the latest drivers from the site. http://www.shopping.hp.com/webapp/shopping/search/search_request.do?pageName=HP+printers_land Good Luck, Tim
Feb 03, 2007 | HP PSC 2410 All-In-One InkJet Printer
27 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
