Do you mean it cranks but won't start?
Check for spark at a spark plug wire. If you have spark, it's probably not the ignition, but a fuel issue. Do you hear the pump come on briefly when key is turned to on? You may need to stand by the gas tank with the cap off, while someone turns the key on. The pump should hum or whirr for about 2 seconds to prime the fuel system. Then it will shut off until car is cranked over. If the pump and the ignition is working, check fuel pressure.
If you had no spark, it could be the coil, or crank position sensor, or...well, you would have to diagnose the ignition system.
If the problem is not cranking over, check all connections at starter and battery for a clean tight connection. Check for power at the starter solenoid when key is held in crank position. If power there, the solenoid must be bad. If no power the circuit from ignition switch to the starter solenoid has a problem ( like the starter relay or the neutral safety switch).
Good luck.
SOURCE: My 2005 jeep liberty will not start. Starter is
Check the battery for bad connections..take off the cables and clean both the battery posts and the cable connectors and then try...if no start, then see if you can check the battery voltage with a voltmeter...at stand still(engine not running) the battery should read 12.5 volts...if battery is ok, then there is the possibility that the starter solenoid, the starter relay, or (in rare cases) the ignition switch is bad
CAR NO START PROBLEMS:-----
It
can be the issue with weak battery or faulty battery or if battery is ok,then
its faulty starter causing the issue.
From
start to end troubleshooting these problem i suggest you to click the link
below and follow its procedure:-----
What to Do When Car Turns Over But
Won't Start?
http://technoanswers.blogspot.com/2012/11/what-to-do-when-car-turns-over-but-wont.html
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
http://whoisbyme.blogspot.in/2012/06/car-starting-problems.html
http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
http://whatisbyme.blogspot.in/2012/06/1999-chrysler-cirrus-8-ign-fuel-starter.html
http://whatisbyme.blogspot.in/2012/05/2001-toyota-camry-no-start-after.html
http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html
http://www.howtorepairguide.com
These will help.
Thanks.
It
From
Won't Start?
Car starting issues?
Car Starting Problems
1991 Toyota Trecel: Engine Starts fine but
dies when gets Warm?
1994 Toyota Pickup: Starts fine but dies in
few seconds?
1999 Chrysler Cirrus: 8 IGN Fuel Starter Fuse
Blows?
2001 Toyota Camry: No start After replacing Battery?
1989 Toyota Pickup Truck: Turns over but not
start?
http://whatisbyme.blogspot.in/2012/05/1989-toyota-pickup-truck-turns-over-but.html
Car dead and will not Start?
http://whatisbyme.blogspot.in/2012/05/car-dead-and-will-not-start.html
1995 Lexus LS400: Running Hot?
2001 Toyota Prius will not start?
http://whatisbyme.blogspot.in/2012/05/2001-toyota-prius-will-not-start.html
1996 Jeep Grand Cherokee: Engine will not start?
http://repairhelpcenter.blogspot.in/2012/06/1996-jeep-grand-cherokee-engine-will.html
Mitsubishi will not start
These will help.
Thanks.
It
From
Won't Start?
few seconds?
Blows?
start?
These will help.
Thanks.
It
From
Won't Start?
few seconds?
Blows?
start?
These will help.
Thanks.
What to Do When Car Turns Over But Won't Start?
Car Starting Problemshttp://whoisbyme.blogspot.in/2012/06/car-starting-problems.html
1991 Toyota Trecel: Engine Starts fine but dies when gets Warm?http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
1994 Toyota Pickup: Starts fine but dies in few seconds?http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
1999 Chrysler Cirrus: 8 IGN Fuel Starter Fuse Blows?http://whatisbyme.blogspot.in/2012/06/1999-chrysler-cirrus-8-ign-fuel-starter.html
2001 Toyota Camry: No start After replacing Battery?http://whatisbyme.blogspot.in/2012/05/2001-toyota-camry-no-start-after.html
1989 Toyota Pickup Truck: Turns over but not start?http://whatisbyme.blogspot.in/2012/05/1989-toyota-pickup-truck-turns-over-but.html--------------
Car dead and will not Start?http://whatisbyme.blogspot.in/2012/05/car-dead-and-will-not-start.html
--------1995 Lexus LS400: Running Hot?http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html
2001 Toyota Prius will not start?http://whatisbyme.blogspot.in/2012/05/2001-toyota-prius-will-not-start.html
---------1996 Jeep Grand Cherokee: Engine will not start?http://repairhelpcenter.blogspot.in/2012/06/1996-jeep-grand-cherokee-engine-will.html-------------Mitsubishi will not starthttp://www.howtorepairguide.com
These will help.
Thanks.
