Question about HP Compaq dc7600 PC Desktop
PC automatically shuts down
HP pc's are automatically shutting down displaying message "It's now safe to turn off your computer". All pc's are in domain. We have other company's pc's also but the problem is occuring frequently on hp dc7600 pc's only. Plz help
  • Pankaj Sharma Jan 05, 2007
    We have win 2000 installed on these systems. First the problem came on Quality control deptt's PC's and after that is is beginning to occur on all HP pc's. We have IBM pc's also and they are working absolutely fine.
  • 624 Answers
Hi pank, Take a look at the BIOS setups in these machines. Business HPs and Dells have a setting to allow automatic shutdown and startup based on time. Another explanation is timer software; all of the computers I manage run a software timer that shuts down automatically at night. You might also want to talk to your network administrator since there are lots of management tools that allow remote shutdown of computer. It could be something they?re doing on purpose ?.. There are lots of other possibilities but I would check these out first since they?re more likely. Let us know how things go and please don't forget to rate the posting.
Posted on Jan 05, 2007
SOURCE:
Hp invent repeating startup error
If it is showing a blue scree of death (BSOD) and shuts downbefore you can read the error message try this:
Turn the computer off, then turn it on and immediately start hitting the F8 keyrepeatedly until you see SAFE MODE. Scroll down below Safe Mode and youwill see an option to Disable Automatic Restart. Select it and rebootyour machine. Next time it boots up you will be able to read the errormessage. You'll probably need a system disc or repair disc to fix theblue screen error message.
Mar 26, 2012 | HP xw4600 Workstation - 1 x Intel Core 2...
KDL52EX700 shuts down and restarts
If it is showing a blue scree of death (BSOD) and shuts down before you can read the error message try this:
Turn the computer off, then turn it on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Scroll down below Safe Mode and you will see an option to Disable Automatic Restart. Select it and reboot your machine. Next time it boots up you will be able to read the error message. You'll probably need a system disc or repair disc to fix the blue screen error message.
Mar 26, 2012 | Computers & Internet
Computer turns off by itself
Depending on if you get any error messages at all.. Then do the following. If you get an error message, Post it back here for more specific directions on how to fix this issue.
First, remove all devices attached to the computer except the keyboard, mouse, and monitor.
Then.. Shut the computer down, start it, and press f8 to enter safe mode..
Does the computer randomly shut down in safe mode? If not then your issue is software, and can be fixed without replacing anything.
Aug 17, 2010 | Dell Dimension 4550 PC Desktop
Acer Aspire 5002WLMi PC Notebook Laptop shuts down automatically
  • Start tapping the F8 key. The Windows Advanced Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
  • Ensure that the Safe mode option is selected.
  • Press Enter. The computer then begins to start in Safe mode.
  • When you are finished with all troubleshooting2_bing.gif, close all programs and restart the computer as you normally would.
If this does not work you will probly have to go back to factory settings
May 13, 2010 | Acer Aspire 5002WLMi Notebook
Pavilion dv7 keeps shutting down
  • This may not fix your issue but its worth a try ...let me know how it goes
  • If the computer appears to shutdown and then attempt to restart without displaying an error message, do the following to disable the automatic restart on error setting.
    1. Click Start , right-click Computer , and then select Properties .
    2. Click Advanced system settings , grant permission to continue if prompted, and then click the Advanced tab.
    3. Click Settings in the Startup and Recovery section of the Advanced tab.
    4. Deselect the Automatically restart checkbox under System failure .
    5. Click OK to close the Startup and Recovery window, click OK again to close the System Properties window, and then close the Control Panel window.
    6. Restart the PC.
    Disabling the automatic restart setting allows time to view the error message that displays on the screen. Contact the manufacturer of the program or device that is causing the error for specific information about the error message.
  • Jan 21, 2010 | HP Pavilion DV7-1232nr Notebook
    Computer turns on leaves message and cuts off
    this means that your cpu fan is facing some problems so its better change it or else your pc will encountered on and off. you can use it for 2-5 minutes then turned off automatically and you will notice the the lights is still on.
    Oct 07, 2009 | HP M490N PC Desktop
    When I shut down my computer, I think that it is shutting down completly. All lights are off indicating that it is shut down. Then a small blue window will appear and will say "Entering Power Safe Mode"....
    If you are turning off your computer by pressing the front panel power button, it is probably just putting Windows to sleep but not shutting the computer off. If your computer has Windows Vista, the default is to hibernate and not shut down even if you shut down through Vista. The "power save" message you see is coming from the monitor, which is letting you know it isn't getting a signal from the computer anymore but the power is still on. Windows will start up again from sleep mode if someone or something moves the mouse or presses a key.
    The solution is to make sure the computer is actually shut down. In Vista you can do this by clicking the arrow near the power icon on the Start menu. This gives you the option of shutting down instead of hibernating. In XP, shut the computer down using the start menu shutdown option instead of the computer power button. Then the power will shut down completely.
    Jun 21, 2009 | HP Pavilion a810n (PP164AA) PC Desktop
    How to automatic torn of the computer?
    the bios on you computer has changed get to your bios or setup screen when you turn on your computer hit deleter or F2 key it should promp you what to hit then in there their will be shut down options set it to when i hit button shut down save and exit. be carefull not to adjust any thing else. or you may drastically effect you system unless you know what you are doing.
    Jun 08, 2009 | Medion MD-1704 PC Desktop
    PC SHUTS DOWN ON ITS OWN
    Could be a few different possibilities-
    Power Supply failing
    Overheating Issue
    Virus-
    first thing i would do is to try booting the computer up into safe mode with networking. to do this:
    Shut off your computer and turn it back on- immediately start pressing the F8 key repeatidly until you get an advance boot menu- then go to safe mode with networking and press enter on your keyboard- See if Windows operates normally while in safe mode- If so then issue is probably a Virus.
    Apr 09, 2009 | HP Computers & Internet
    HP Pavillion dv9000 fatal error
    On the windows boot screen you should be getting choices for safe mode, safe mode with networking, etc ...
    Select "Disable automatic restart on system failure'
    And let me know what error message(s) you have ... write it all down
    Jan 14, 2009 | HP Pavilion dv9000z Notebook
    HP Compaq dc7600 PC Desktop Logo
    241 people viewed this question
    Top HP Computers & Internet Experts
    Thomas F. Schneider
    Alun Cox
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
