Question about Arris SURFboard SBG900 (49402201900) Modem
Sbg900 won't connect with wep enabled - Arris SURFboard SBG900 (49402201900) Modem
This modem's remote router has a seperate firewall of it's own so what you'll have to do is; go to the to server site @ http//:192.168.100.1 then hit enter. you will go the the Login Site and you login and can reset or retrieve your WEP key.
Posted on Dec 27, 2008
Set up wireless security
1 On a computer wired to the SBG900 USB or Ethernet port, open your web
browser (for example, Microsoft Internet Explorer)
2 Type http//:192.168.100.1 and press ENTER to display the login window:
3 In the User ID field, type admin (case sensitive) and press TAB.
4 In the Password field, type motorola (case sensitive) and click Log In to
display the SBG900 Setup Program main window:
As soon as your network is operational, run the SBG900 Setup Program to:
"Wireless Network Setup"
For a LAN with one or more wireless clients, enable wireless security on the SBG900.
After enabling wireless security on the SBG900, as required on each wireless client:
> If you disabled ESSID broadcasting on the SBG900, set the client Network
Name (ESSID) identical to the ESSID on the SBG900.
> If you enabled WEP on the SBG900, set the client WEP key identical to the
WEP key on the SBG900.
> If you enabled Allow Only Listed Stations Access, be sure the MAC
address for each client is correctly listed on the SBG900.
Dec 22, 2010 | Arris SURFboard SBG900 Wireless Router...
Unable to wireless connect TP-Link TL-WR841ND to Motorola SBG900
DO any of these error conditions show up on the front panel display?
Front-Panel Lights and Error Conditions
Light Turns Off During Startup If:
RECEIVE The downstream receive channel cannot be acquired
SEND The upstream send channel cannot be acquired
ONLINE IP registration is unsuccessful
POWER The SBG900 is not properly plugged into the
power outlet
OR
Light Turns Off During Normal Operation If:
RECEIVE The downstream channel is lost
SEND The upstream channel is lost
ONLINE IP registration is lost
POWER The SBG900 is unplugged
If you rent or lease your SBG900 Contact your cable service provider.
If you own your SBG900 Call 1-877-466-8646 for technical and warranty support. Support is available
24 hours a day, seven days a week.
Feb 28, 2017 | Arris SURFboard SBG900 (49402201900) Modem
How do i secure it
You can secure your wireless network wit WEP or WAP code.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
For belkin router http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on wireless settings then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Thanks for using FixYa.
Dec 10, 2009 | Arris SURFboard SBG900 Wireless Router...
After a period of successful operation followed by a 2 month inactivity my Motorola SBG900 does not allow WEP-encrypted (passphrase) hookup of notebooks to my home network. Wireless light on SBG900 is...
is there wireless MAC filter enabled on the router ?
If enabled then disable the MAC filter.
Check all the wireless settings of the router
Click Here for step by step solution
Oct 31, 2009 | Motorola Computers & Internet
How do you get a Vista 64 machine to connect to a WEP or WPA enabled SBG900?
use the network connection wizard when it ask go into advance mode
Aug 10, 2009 | Motorola Computers & Internet
How do I make a secure wireless network
If you don't have the manual, you can download it here.
Look at the chapter "Setting Up Your Wireless LAN" (page 64).
Then follow the guide for "Configuring WPA on the SBG900" (page 66).
Try to avoid WEP, since it is easily hackable and only gives the sense of false security. As encryption, choose WPA AES, because it is more secure than TKIP. WPA Authentication should be "local", since you don't want to run a dedicated server.
Some older laptops cannot deal with WPA-AES. In that case you have to fall back to WEP, but try WPA first.
Furthermore you should change the ESSID from "Motorola" to something more specific for you, so other clients don't connect accidentally to your network (page 71).
If you want to enable MAC filtering is up to you and only makes sense if you never have friends or colleagues coming over with a laptop. I would leave it off and enable it at a later point, after you see that everything is running fine.
Don't forget to set up your computers as well! You have to provide the passphrase for them, otherwise they can't connect (see page 75). The way I do it is to create a strong (!) passphrase like "V0y6Mmb90y...", copy it into a text document (use notepad), and save it on a USB stick. form there you can copy it to the field, when Windows (or Mac) asks for the network key.
No typos = no headaches.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Jul 11, 2009 | Arris SURFboard SBG900 802.11g/b...
WEP security setup on SBG900
If you set a WEP security connection, of course you will be kicked out of your connection. You have to re configure your laptop to gain access to your WiFi, inserting the new password you set the WEP with... Hope this helps
Jun 02, 2009 | Arris SURFboard SBG900 802.11g/b...
I cant find my wep key for my motorola sbg900 and i need it to get online for my ps3. how do i find it?
Usually to do this, you need to connect to the router with a computer and an ethernet cable.
Start the browser and enter the following:
http://192.168.100.1 or http://192.168.0.1
This should bring you to a configuration screen of the router. Next, go to the configuration tab and head out for the wireless configuration and then the security configuration. In there you should find the location where the WEP keys are stored.
if you can't get connected, yu can look for more help in the manual of the device.
You can download it here:
sbg900 manual
Cheers
Critter
Jan 04, 2009 | Arris SURFboard SBG900 Wireless Router...
Can't connect to the internet wirelessly
Well, to avoid confusion, I'd start by doing a factory reset. Insert the straightened end of a paperclip into the reset hole and power up the device to do this. From there, the device should begin broadcasting the default wireless network with the name (SSID) of "Motorola." The DHCP server should also be enabled and if your computer is configured to receive an automatically assigned IP address your wireless network interface should pick up an IP. The security for the "Motorola" network is disabled by default.
Basic troubleshooting from there would be to try to see if you can connect your wireless computer to another wireless network that is know to be working well. Either buy and return another wireless access point or router from a retailer or head to a Starbucks or other establishment that offers free wireless. If the wireless computer is hooking up nicely with the secondary wireless network, you can refocus on the SBG900 as the likely source of the problem.
If after attempting the aforementioned procedures you find that the wireless computer continues to fail to connect to the SBG900 you might have to consider that you have a faulty device. At that point I would consider consulting the manufacturer's documentation.
Apr 05, 2008 | Arris SURFboard SBG900 802.11g/b...
Motorola modem SBG900
you must define DNS and Gateway!!! Go on My Network Places, right click, again right click on your network, select properties, TCP/IP and in there enter needed IP addresses!!!
Jan 25, 2008 | Arris SURFboard SBG900 (49402201900) Modem
Arris SURFboard SBG900 (49402201900) Modem Logo
480 people viewed this question
Top Arris Computers & Internet Experts
jimmy Leo
Jerry
Jerry
Greg Ulan
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
