Question about Breadman TR4000 Ultimate Dream Bread Maker
Have H:E code on TR441 what does that mean
Need help asap have mix for another loaf already in machine.
4 Suggested Answers
SOURCE: I HAVE A TR441
I NEED A TR441 BREADMAN BREADMAKER MANUAL I HOPE SOMEBOBY CAN HELP ME MY E-MAIL p.alequin@att.net
Posted on Oct 26, 2008
SOURCE: loaf only baked to about 1/3 size it shouldf have been
I had the same problem and tried using slightly less water - it worked. Also, it may be that your yeast is not very good. Larry
Posted on Jan 23, 2009
SOURCE: My Sunbeam Breadmaker 5891 keeps
Throw it away and buy a new one...that's what I do when things are covered by the warranty anymore.
Posted on Feb 15, 2009
  • 433 Answers
SOURCE: bread machine, mechanical problem (American Harvester Classic)
Let's try a few things. First take the bread pan out of the machine and see if you can spin the paddle freely by hand. If you can't, then the sealed bearing in the bottom of the bread pan is frozen and the paddle won't spin during the kneading cycle. Try putting hot water in the pan and let it soak. Try this a few times...If that does not work you will need a new bread pan. If everything is good with the bread pans, then take both pans out of the machine and start a kneading cycle. Look through the top window (if you have one) and see if the motor shafts are spinning. If not, then the belt fell off the pulleys, or has snapped, or the motor is broken. Good Luck..Hank
Posted on Jan 18, 2010
Bread machine code H:E
That is a feature on your bread machine that prevents you from starting a loaf of bread when the oven is too hot fro the last loaf. You need to open the lid, leave it open for 30 minutes then bake your next loaf.
Jan 01, 2013 | Westinghouse New White 1 1/2 lb Fresh Bake...
Bread machine, mechanical problem (American Harvester Classic)
Jan 17, 2010 | Kitchen Appliances - Others
Need programing manual for an Oster bread machine. We've lost the manual and need to know how to "program" it. For today, naturally, since we don't use it much.
Kind of feel around in the dark. The object was to have the machine mix and knead, then actually bake in pans in an oven which was already warm from cooking turkey, etc.
Took some doing without the book, but we figured it out, and just jerked the loaf at the right time, before the baking process began!
Dec 25, 2009 | Oster 5834 ExpressBake Bread Maker
BREADPADDLE
I lost a paddle in a 'gift' loaf of bread and never received it back. I contacted the company directly with an 800 # located in my manual. Problem solved--a replacement could be purchased + shipping. Sunbeam is a supportive company--I bet you can do the same. Good luck.
Apr 14, 2009 | Sunbeam 5891 Bread Maker
Bread is ****.
Try to buy bread mixes that are in proportion to your machine. I had a machine that mads 2-1/2 pound loaves. I could only find mixes for 3/4 pound loaves. I had to buy multiple mixes, put them together and divide them by weight. I gave the machine away.
Jan 12, 2009 | Black & Decker B2300 Bread Machine
HHH Error Code
Generally, an HHH error code means the machine is sitll too hot from making the previous loaf. Keep the door open for a bit and allow it to cool down.
Dec 25, 2008 | Sunbeam 5891 Bread Maker
Black & Decker B2250 - Recipies
Here's a good basic white bread recipe that works great with a BD2550 (and usually doesn't even **** the mixing blade off of the bottom of the machine)
1 cup warm (not hot) water
1/3 cup milk
1 tablespoon sugar
1 teaspoon salt
1 1/4 tablespoons butter/margarine
4 cups flour
1 teaspoon yeast
Heat the water and add the milk to it. Dissolve the sugar and salt into this mix and pour the liquid into the bottom of the bread maker bucket (make sure the mixing blade is already in). Melt and add the butter to this mix. Add the 4 cups of flour directly on top, but do not mix it in. The flour will float on top of the liquid. Make a small dimple in the top of the flour in the middle with your finger and add the yeast into that little crater (at no point while adding ingredients do you let the yeast touch the liquid). Set the bread maker for basic setting 1, light crust, 2lb loaf and let it do it's thing. 3 hours later, you'll have a nice loaf of white bread with good consistency and density, and it usually leaves the mixing blade in the bucket (rather than having to dig it out of the loaf after).
Hope this helps!
Nov 03, 2008 | Black & Decker B2250 Bread Machine
Recipes Are wrong in instruction booklet
I had a similar problem when I switched machines. It seems that most recipes will work in same size machines (1 or 1.5 lb loaf size). My issue was that my old machine had to have liquids in first and then dry ingredients (new machine is the opposite). I ruined several loaves before I figured out the issue. I would have never imagined the order of ingredients would make a big difference.
Oct 16, 2008 | Black & Decker B2250 Bread Machine
Black and Decker Bread Maker B2250
Here's a good basic white bread recipe that works great with a BD2550 (and usually doesn't even **** the mixing blade into the bottom of the machine
1/3 cup milk
1 tablespoon sugar
1 teaspoon salt
4 cups flour
1 teaspoon yeast
Hope this helps!
Aug 12, 2008 | Kitchen Appliances - Others
Regal ware k6751
Look at the box first. Many times it will have instructions on it. However sometimes it may not and have only the the dry ingredients. If the box has no instructions, see how many cups of flour the mix uses. If it uses 3 cups of flour total, the mix is for a 1 1/2 pound loaf. If the mix uses 2 cups of flour it will make a 1 pound loaf. Box missing this info? It's time to take the flour out of the box to measure it with at measuring cup. Mixes sometimes combine all the ingredients together so it will measure bit more than 3 cups for a 1 1/2 pound loaf or 2 cups for 1 pound loaf. After finding out how big the loaf is going to be then get the bread pan and instruction manual and start constructing the dough. I'd find the recipe in the manual that matches the mix the best to find out how much liquid to use. (for a classic whit its 1 cup for 1 1/2 pound leaf and 3/4 cup for 1 pound loaf) Then I put the liquid in the pan first along with butter (if necessary), followed by the dry ingredients in the mix with the yeast at the top. Put the pan into the bread machine and select 1 or 1 1/2 loaf or if it is a french or sweet bread. Press start. Unfortunately I have a different machine than you do, but I think this will help.
Jan 15, 2008 | Regal Ware K6725 Kitchen Pro Bread Maker
Breadman TR4000 Ultimate Dream Bread Maker Logo
223 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Dave Kristol
Level 1 Expert
Irene Tulloch
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
