Question about Midland 75-822 40-Channels Handheld CB Radio
Midland 75-822 Son't Transmit
I can hear some radio chatter (receive) but cannot reply (transmit). It's like the PTT (push to talk) button isn't working or something. Same problem with rubber on-radio antenna as with it attached to my vehicle antenna. Any ideas?
  • jwdicus Dec 07, 2008
    Is that something I can repair myself? If so where would I get the part? Thanks. I am already looking into returning the radio since it is defective. But the return policy is so convoluted with so much fine print, I'm pretty sure the retailer will find a way to screw me out of a return or will not repair or replace it for me, as they should.
Cannot transmit, getting a constant tone while holding talk button and transmit light not coming on, any help?
Check the headset jack. There may be something inside causing a short. also, the CLS has an audio tone out button. Be certain you are not pressing it as you push the PTT button. The PTT is odd on this radio, it is the top BIG rubber button on top FRONT. Many customers get this confused with the tone transmit button.
Nov 13, 2015 | Motorola CLS1110 Professional 2-Way Radio...
Can't transmit signal. Only get a 2 second beep when I push the transmit button
You have a poorly charged or bad battery. It takes more power to transmit than to receive. Usually the first thing you lose with a low, bad or poorly charged battery is transmit.
Try a known good battery in the radio. This should solve the problem. If not, check your battery contacts, as you may have one which is bad or not making good contact.
Clean your contacts with a pencil eraser to assure good connection with the charger.
Best regards.
Mar 18, 2014 | Kenwood Radio TK 260 360 270 370 2100 3100...
My Midland walkie talkie quits transmitting about 3 seconds after I start transmitting
It is more likely a power issue. PTT switches do not normally cause a short circuit. Check the batteries, swap the batteries and see if that helps. Radios take a great deal more power to transmit than turn on or receive. If not the battery, try a low voltage battery, such as a cordless phone battery. If it still occurs, check your warrany and send it back to the factory.
Nov 10, 2013 | Midland Radio Midland X-tra Talk Frs/grms...
My walkie talkies arent communicating when i press the ppt button. it transmits too fast before i get a chance to talk into it. what can i do to fix them? is there a reset button? they are the motorola...
The ACTUAL problem is your rechargeable batteries have most likely depleted over time, and since it takes more batterie power to transmit than to receive it can appear that your batteries are fully charged and you can be receiving but due to the batterie it will be unable to transmit
Jul 26, 2011 | Radio Communications
I have a problem with radio gxt1050, it was functioning correctly, but now I turn on it and the keys not response, no PTT button, but I can hear calls from other radios... tanks
  • It takes a lot more power to transmit than it does to receive. So it is possible to listen but not be able to talk. Make sure that the batteries are charged and that the batteries are holding a charge. When batteries begin to fail they won't hold a charge for long at all.
Regard, Tony
May 06, 2011 | Midland Two Way Radio
I recieved a talkabout 250 and i have no clue how to use it please help
You would need two or more radios to be able to communicate with others. Then you simply press the push-to-talk (PTT) button when you want to talk (transmit) and release it so others can reply (receive). The radios must be set to the same settings to be able to communicate.
Apr 11, 2009 | Motorola Talkabout FRS 250 (14 Channels)...
Midland GTX800 "X-Tra Talk" 2-way radios will not transmit
Are you sure that the batteries are running well?
Try using alkaline batteries just for testing.
Jan 17, 2009 | Midland 20-Mile, 22-Channel FRS/GMRS 2-Way...
Keewood Protalk 2 way radio xls receives , but doesn't transmit
Hello jf1111,
It could be a low battery. Does the screen go completely blank when you attempt to transmit? Two way radios draw a lot more power when transmitting then when receiving so a low battery might cause the radio to cut out when you press the Push-to-Talk and then the radios might appear to turn back on when you release the PTT. If this behavior persists even after charging the battery then the battery or charger (or both) might be defective.
If the battery isn't the issue then the radio could be programmed incorrectly. Does the problem occur on all channels or just one? The Kenwood ProTalk requires dealer programming with a software kit to set the frequencies for each channel. A channel that is programmed for an out of bounds frequencies would generate an error when the PTT is pressed. You might need to have the programming checked out by your local Kenwood Two-Way radio shop.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 20, 2008 | Kenwood ProTalk XLS TK-3131 (15 Channels)...
One radio continually transmits
Hello
This could be the Ptt Switch , Midland is 3 Years warranty try to claim the warranty, this is a Factory fault.
Oct 25, 2007 | Midland LXT303-A 2-Way Radio
Midland 75-822 40-Channels Handheld CB Radio Logo
310 people viewed this question
Top Midland Radio Communications Experts
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
