Default Scan Resolution on Canon iR C3220
I want to decrease the default scan resolution on my copier, but find nothing in the guides that came with the copier that indicates I can change the default. We want to change it so it can only scan to PDF files as well.
  • 168 Answers
Imm assumiing your using the send feature to scan to sett it up different ways in this order add functions communication settings this should bring up a screen with left and right colomns.. the left one should have a tx setting touch that and scroll till you find custom send settimgs
Posted on Dec 18, 2008
How to repair canon ir C3220 Error Code E602-0003
This is just a shot in the dark, but if there is no "reset" button, you might try unplugging it for a couple of minutes and it should reset itself to factory default settings. Just a guess. If you have an owners manual, I would check there to find how to solve the problem. You might want to enter the "menu" if there is one, and discover whether you can solve the problem there. If you don't have an owner's manual, you might be able to find one at the printer manufacturer's website in the support section.
Nov 11, 2013 | Canon Color C3220 Copier - Color...
My Lexmark X6170 scans but the scanned document is not clear or visible , the words are very light .
You could try to increase the Scan Resolution to improve scan quality using the Lexmark All-In-One Center application on your computer.
  1. Go to Start menu > Programs or All Programs > Lexmark 6100 Series > Lexmark All-In-One Center.
  2. Click Scan menu.
  3. Click See more scan settings.
  4. From the scan resolution dropdown, select a higher resolution value. 300 dpi is the default setting. Note: Increasing the resolution value also increase the scan file size.
  5. Try to scan again.
Jun 22, 2011 | Lexmark X6170 All-In-One InkJet Printer
I want to increase the size of the small drawings i do from my epson 1250 scanner to my canon 1800ip to a4 printout size is this possible.
You have to scan the pictures with a higher resolution to be able to print them in a larger format with acceptable quality.
If your default scanning setting is, say, 150dpi resolution, and you want the picture to be enlarged twofold, then you have to increase the resolution to 300dpi. If you have 300dpi now, increase it to 600dpi.
Some scanner utilities do a fully automatic scan - then you have to find the automatic scan settings and change the default resolution. Or better yet, find an option for a non-automatic scan, where you are presented with various options after the preview scan has been done. There you can usually set the desired size, resolution, improve contrast, sharpness etc.
Generally, the higher the scanning resolution, the more detail you have on the picture, and the higher magnification you can obtain when printing without quality loss.
But there's a catch - a picture in higher resolution produces a bigger file on disk - the file size grows faster then the resolution - a two times bigger picture will be four times bigger on disk. So you have to make sensible choice.
Nov 06, 2009 | Canon Office Equipment & Supplies
Canon ir C3200 Print Resolution
Print out a Fiery config page ....there may be something in the fiery settings on the actual Fiery box, you'd have to reboot and run setup when it prompts you.
Jul 12, 2009 | Canon Office Equipment & Supplies
How to change the default scan resolution on M20i?
You need to go to the printers webpage from your Web Browser or something like that. Then, go into Properties tab, and then the Services Dropdown. Under that, go into Email Settings and then Email Setup. Change your DPI to as high as 600dpi, then scroll to the bottom and hit save. You'll be prompted for a password which is either Admin / 1111 or 11111 / x-admin
May 01, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Scan to pdf on imagerunner 5075
Unfortunately, you can't do it remotely. You have to do it at the machine. Just hit the "additional functions" button, go into "communication settings", then "TX settings" on the left, then "edit standard send settings". This is where you would set your default resolution and file type.
Mar 11, 2009 | Canon imageRUNNER 5000 Copier
We need to set the default resoultion on our Canon IR 3170C printer as it is set at the highest setting which creates massive file sizes. We can set it up at each individual scan to a lower resolution but...
try to set from Start-> Control Panel-> Scanners -> Properties.
Then set the values and select ok/Apply to save the value.
  • Pleae close if any window open for scan before making the above changes.
Post your feed-back.
May 06, 2008 | Office Equipment & Supplies
Scanner resolution
resolution is scan density x dpi; dot per inch. contrast is the control that you seem to be looking for.
Tip: before you send them, look at what you have.
Apr 24, 2008 | Sharp AR-M207 All-In-One Laser Printer
Canon ScanGear Ir - how to set defaults?
ScanGear won't run under Vista. The scanner works with other programs. (Twain works) ScanGear fails and Vista closes it.
Sep 21, 2007 | Canon imageRUNNER 1023N Black and White...
1,083 people viewed this question
