Monitor clip hello there, i cant seem to turn the stand at the bottom of the monitor to straight'en it up right, in order for the monitor to sit level. many thanks, david mackenzie.
  • 380 Answers
the solution for you is to take your monitor and flip it upside down and re-align the slot on the monitor clip /stand so that it lines up with the front of the monitor. Return the monitor back to its normal position on the desk and it should now behave properly.
Good Luck!
Rich Lilja
Posted on Nov 26, 2008
Can the monitor height be adjusted. It seems to be fixed to the stand with no adjustments?
No but you could always put something under the stand most can only be tilted for lighting reasons.
Jul 04, 2011 | Princeton Digital VL1916 19" LCD Monitor
How to remove the bottom stand of the monitor
You just have to remove the black plastic cover over the stand hinge, then you will see the stand mounting screws.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Sep 24, 2010 | ViewSonic VA1930WM LCD Monitor
I'm attempting to repack my AL2216W LCD Monitor into the original box. When I slide the two foam protectors on the ends, it won't fit into the box. The stand is in the way no matter how I position the foam...
Of course there is a trick to this. Remove the stand by pushing gently on the clip at the bottom. I usually turn it upside down to do this. Then lay the stand on top side of the foam.
Please rate this answer as the only thing I get for answers is a rating.
Apr 11, 2010 | Acer AL2216W LCD Monitor
Microphone stand
this confused me too! if you havn't figured it out already there is an adaptor screwed into the mic clip to work with standard mic stand mounts. in order for it to fit on the desk stand that comes with it, you have to to first unscrew the adaptor sitting inside the barrel of the mic clip. then it will be the right size to screw onto the stand.
Apr 01, 2010 | Samson G-TRACK USB RECORDING MICROPHONE...
The stand of the monitor doesnt push back is there a button to push to make it straight
There may be a bution on the bck of the stand that needs to be puched in then you can slide the manatr up
May 03, 2009 | HP w1907 LCD Monitor
Dell 1907fpf will not power on.
Please search for "Power button stuck on Dell 1907FP" and see the advise from other members. I solved my by following their instructions.
Feb 15, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
How do i open hanns g monitor?
#1 Remove the stand mount off the back of the monitor
#2 Remove the 4 screws in the corners of the monitors
#3 The monitor is now only held together with builtin plastic claw clips. They are connected to the back piece and hook onto the face piece. Use a flat object, I use a small screwdriver, to ress against the clip at the seam of the monitor. There are 3 clips down each short side, and 4 on the top and bottom. You can see a tiny marker showing each clip location at the seam. So press against the clip and gently pry the two pieces open holding it slightly open until you can spring the next clip....and so on, on each clip until it is open.
#4 once open remove the 4 lugs at the video connectors
#5 remove the two sheet metal screws.
#6 sit back realizing those clips hold the plastic together so well that screw are just overkill after that. :P
Jan 02, 2009 | Hanns.G Corporation JW-199DPB 19" LCD...
Disassembly for shipping
As per page 4 of the User's Manual from Acer:
Detaching the Monitor
If you need to repackage the monitor, please separate the monitor and base, and restore them to
the carton. To detach the monitor:
1. Unplug the AC power cord to make sure the power is off.
2. Pull the 4 hooks on bottom side of the base and hold.
3. Separate the monitor and base and put them into carton.
Jun 19, 2008 | Acer AL1716B 17" LCD Monitor
Problem with opening monitor cover
to remove the back cover of samtron 56 v monitor is very simple.
locate the 2 bottom screws of the cover, remove them. pull slightly back the cover holding the bottom and about half an inch gap will be seen. insert a flat screw driver straight down through the upper side hole with your left hand and hit the head of the screw driver with your right hand. a slightly big sound is heard and that side is disengaed. repeat he same with the second hole. and you have done it. try.
Oct 10, 2007 | SAMTRON 55V 15" CRT Monitor
Compaq FP 5315 Monitor Disassembly
This is how I did it.
1- Remove the four screws in the back of the monitor. Two are in the bottom corners and two more near the bottom center ( these hold the stand in place).
2- Remove the stand.
3-The case back is held on by the four screws and a number of plastic pressure clips. After removing the screws: using a fairly wide flat bladed screw driver; insert the blade in either of the two slots on the bottom edge of the case and twist with medium force. This begins the seperation of the back from the rest of the monitor. As the crack widens, begin moving the blade of the screw driver along the widening crack (around the case edge) and twisting gently. This releases each pressure clip in turn. Separate the case back from the rest of the monitor.
I did this this way with my monitor. It works.
Good luck.
Bill
Dec 02, 2006 | Compaq FP 5017 15" Flat Panel LCD Monitor
Computers & Internet Logo
404 people viewed this question
David Payne
David Payne
