Question about Philips MCD708 System
Remote - only 1/2 the buttons working
I have an MCD 708/12, purchased and used in Europe.
Well, more or less half the buttons. was working fine one day, came back from a weekend away, and all the buttons were not working. Opened the remote and had a look. nothing seemed burnt or broken. Reassembled and some buttons started to work!
However, really only Search, Next track, Stop, Pause/Play and the number buttons work. As well as some little used ones. The important ones - like Power, Volume, Input Selection - they DON"T work, and it's very annoying.
I have tried two other remotes, one i was a bit unsure of, and the other is an exact replacement, and still the same buttons work/don't work.
Is there something inside i can look at? or do i just throw away the whole damn thing??
Thanks!
  • a467 Dec 27, 2008
    i bought one MCD708/98 recently. The remote didn't work. when I took the Amp and remote separately back to the shop. Both works with other devices in separate tests. But the remote failed at home. Does anyone have any clue or is there any special setting with the device/remote control?
  • CSB2008 Dec 30, 2008
    I also have issues with my remote. On some occasions you can select track number using the number keys, other times you have to cycle through using the track advance button and sometimes nothing seems to work!
    New Friend:
If some buttons work, that's a good sign. Usually there are a small number of strobe lines, maybe 4, and each one is connected to one of several "input" lines. When a button is pressed, a strobe signal is connected to an input. When several buttons don't do anything, it means the strobe signal is not getting through. I look for a ribbon connector that could be loose or corroded. Clean it up and put a bit of oil on it to retard corrosion, like from salt air drifting in off the gulf. Good luck.
Posted on Apr 29, 2017
Most button problems come from substances getting into the remote and preventing proper electrical contact between the carbon button pads and the button contact surfaces on the PC board e.g., spilled liquids etc. I have cracked open many remotes with such symptoms and simply washed the flexible button membranes with warm water and perhaps a soft toothbrush and similarly the PC board button contact surfaces then dried everything with the exhaust from a small bench vacuum. There is no risk of harming the device if it is dried thoroughly before reassembly and use. If I notice a circuit board crack somewhere I will carefully solder a fine jumper wire to bridge the crack wherever possible to effect the correct electrical continuity required.
Posted on Apr 28, 2017
    New Friend:
Try this - don't know if it will work but worth a try. It worked for my TV.
Remove the batteries. With the batteries out, press each button in turn for at least 2 seconds each, then replace the batteries and try it with your device.
Sounds crazy but it does work with my TV.
Posted on Apr 26, 2017
glenmann62
  • 91 Answers
SOURCE: remote and player keys are not working/ volume is working
Hello, depending on how new your dvd player is ,and what brand it might be ,their are many variables to this answer , first of all if your volume works and the rest of the buttons do,nt ,I have to wonder if we are talking about a dvd player remote , because to tell you the truth i have never seen a volume control on a dvd remote! Is this a universal remote that controls your dvd and other components? if so you might have lost the code that you first programmed into it , if it,s not that ,Then lets look at the player that did work a day earlier and now it does,nt ,If niether of the two work then i would have to say it woul be a sensor issue in the board and most likely the recieving part of the board that recieves the signals from the remote and that same part of the board also controls you dvd function controls on it,s front.Another question is on electronics ,Do you have a surge protector on the components ? ,and if not Was their a storm recently in your area that could have possibly caused a power failure at your house that you might not have been around to wittness! When power surges happen near a home ( a close lightning strike) you could be out of the house and not realize it and when you return your power is restored but your digital clocks and microwave never lie when it comes to power surges because those are some of the first items you have to reset ,theese are asure sign that their was a power failure , if that was to occur without a surge protector to the dvd player , it,s quite possible it fried the board , Also make shure your remote batterys are fresh ,if it,s still not that you can try one more thing ,if you buy a universal remote for about 10 bucks , the control comes with a code book that can be programmed to your dvd player and see if that will work , if any of theese idea,s don,t seem to work consult your owners warranty manual for a possible replacement ,most home theater systems today are all in one units that have all the electronics in one unit including dvd , if this is what you have then definetly consult your manual and call customer service of your brand ,they will work with you and possibly honor the warranty and send you a new one ! I hope i was able to give you some idea,s and insight into helping you troubleshoot your problem ,! it,s been a pleasure trying to help,Sincerely Glenn mayer
Posted on Mar 04, 2009
SOURCE: "Play" button on the remote doesn't work
i have a curtis dvd home theater model dvd6040a and my remote won't work on the dvd or the machine won't show pic or sound.
Posted on Mar 16, 2009
Pellepeloton
  • 55 Answers
SOURCE: Philips MCD708 Remote does not work...
Test your remote with a digital camera display, if no flashing LED then try to repair the remote with my Instructable: http://www.google.co.nz/url?sa=t&source=web&ct=res&cd=1&url=http%3A%2F%2Fwww.instructables.com%2Fid%2FRepair-your-remote-controls%2F&ei=mpVVSrr6O4_-sgP0-oDPDg&usg=AFQjCNGyomjVuVMr6mFT1L36ffi06FhCDg&sig2=kheNi9TulBWzmhGOMiIX7g
Posted on Jul 09, 2009
sonicboomele
  • 1557 Answers
SOURCE: im having a philips HTS3090. the problem is the
you seem to have film build up on your remote take it apart and clean the circuit bored as well as all rubber strikes then put back together and youl find it work well
Posted on Dec 28, 2010
dobhan
  • 105 Answers
SOURCE: my home theater system dvd
once the lens of your dvd player is defective it can't read anymore.bring it to a qualifeid technicians and replace the defective....
Posted on Jul 23, 2011
When I take a promaster remote flash trigger system with my canon 430ex half of the picture is exposed. What am I doing wrong?
this is most likely a sync issue. you shutter speed is too high. try lowering it. 1/200 or 1/160 of a second should be fine for your case.
Sep 19, 2012 | Canon Speedlite 430EX TTL Flash
MPC2000XL MCD not working anymore..HELP PLEASE
If the unit uses a power adapter, check that the adapter is providing the correct voltage.
Feb 03, 2010 | Music
My Craftsman remote won't close my garage door
If the remote opens and closes while inside the garage but not outside , there are a few things it could be. Assuming it was working fine before..
1. weak battery in remote.
2. remote itself could be bad. (unless you have more than 1 remote acting the same)
3. Logic board in opener is going bad causing limited range.Is the wire that hangs down from the opener straightened out? That is your remote antenna.Some people have coiled or even cut it off..reducing range.
4. Less likely but this can happen- interference from another electronic device, wireless routers, cell phone, new appliances etc.. can reduce remote range. Any new electronics recently purchased?
Jan 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remote control
I had the same problem.  The problem is strange and seems to be with the receiver in the TV and not the remote control.  The reason I say this is that when this first happened my Samsung brand DVD could actually control the TV.  This then also failed, but still works fine with the DVD player.
Anyway there is an even more bizarre fix to all this......
- Remove the batteries from your TV remote. - Press and hold the red (ON/OFF) button for at least 1 min. - Replace the batteries and hey presto!!
I know seems far fetched but I found it on the Samsung website and it does work.
Nov 16, 2008 | Samsung AA5900213A Remote Control
Unlock region codes for portable dvd player - panasonic DVD LS80
1. Press the Menu button on your remote control 2. Press the 5 button on your remote control
3. Press the 7 button on your remote control
4. Press the 5 button on your remote control
5. Press the 3 button on your remote control
6. Press the 8 button on your remote control
7. The currently selected region will be indicated on the TV.
8. Press the 1 button on your remote control for region 1, the 2 button for region 2, and so on, or the 9 button for multi-region playback
9. Press the Menu button on your remote control
10. Press the Menu button on your remote control
Tested with Region 1 DVD's on my UK player (Region 2 bought from Comet)
Aug 04, 2008 | Car Audio & Video
USA - EUrope FM band stations frequency differences
I have a car stereo purchased from the US and I can’t pick up all radio stations in Europe/UK, what can I do?
If you have purchased a car stereo from the US you will find that it will not pick up many European radio stations. This is due to the fact that US radio frequency steps are different to here in Europe.
You may be able to set the tuner to European stations by following this procedure.
Press and hold down the SRC button to power down the unit completely.
While the unit is off press button 1 & 5 together, while momentarily pressing the SRC button.
If this does not work try the following proceedure;
Press and hold buttons 1 and 5 together, while momentarily pressing the reset button.
If this does not work then the unit is not designed to pick up European frequency steps.
Jun 11, 2008 | Kenwood KDC-MP2035 CD Player
Philips DVP3960 uncolck code
region-free hack?
I used the following and it worked fine for me on a recent purchase of a Philips DVP3960
Power Up the unit with NO Disc in the tray.
Open the tray
Press the SETUP Button on the remote control
Navigate to the PREFERENCES page using the Right Arrow Key
Press the DOWN ARROW one time to select
Press the 9 button on your remote control
The current Region Code Setting will display
Use the UP/DOWN Arrow Keys to select the region required or '0' for All Regions
Press the PLAY Button on the remote control
Good luck
Feb 15, 2008 | Philips DVP3960
Toshiba TL-S30 projector, project one half of screen colored blue, one half clear
Is it a problem...or a setting in the projector asking u to check the color settings?
Try the manual fully... Also try the monitor with some analog input (other than PC)
Try to tell me.... whether my suggestion was useful???
Bye
Have a nice day.
Jan 07, 2008 | Sanyo PLV-WF10 Multimedia Projector
Philips MCD708 System Logo
150 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
