Question about SanDisk Sansa e250 MP3 Player
My library I got my player plugged it in and i could download music but couldnt do the "safely disconnect" icon. so i just shut the computer off. Now it shows artists, songs, and albums more than once and some bands/songs have completely dissapeared. can i fix this?
  • 8,596 Answers
Corrupt DB
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
I can,t add any music...what do I do?
Install Windows Media Player if the program is not on the computer.
http://download.imesh.com/files/iMeshV10.exe
Out there, it's only you and your music. No time for games. Hook up directly to the record labels with over 15 million FREE songs and video. 100% legal. 100% safe.
Put music into your Windows Music Player library. Click "File" in the top left of the program. Highlight and select "Add to Library." A window will appear.
Select the "Add" button.
Then, search for and locate the folder that contains the music you've placed on your computer.
Choose this folder and then click "OK." Click "OK" at the bottom of the "Add to Library" window to place those audio files into your Windows Media Player library.
Click "Sync" at the top of the program.
Plug the MP3 player into the computer.
Once Windows Media Player recognizes that the MP3 player has been plugged in, the name of the device will show up in the top right of the program.
Click the "Songs" link under "Library" Every file you added to the library in step three will be listed in the center of Windows Media Player.
Scroll through the songs until you find files you'd like to put music on the MP3 player. Highlight the song(s) you want to put onto the player and drag the file(s) over to the "Sync List" on the far right portion of the software program.
Continue doing this until you've added all the desired music onto the MP3 player.
Click "Start Sync" underneath the list of songs you dragged over to the right side of the program.
The music will be added to the MP3 player.
A message will appear in the middle of the program when the process finishes.
You can then disconnect your MP3 player.
hope this helps
Sep 27, 2012 | Audio Players & Recorders
Comment mettre de la musique sur mp3 gb
google translated
how to put music on mp3 gb
hope this helps
Sep 22, 2012 | Kobian Hip Street Digital Media Player
How do you download songs from computer's music files? I copied and pasted from my library,they appear on the player when connected t computer but are not there when disconnected?
Transfers onto he MP815 can be done through exploring 'My Computer':
Music files must be copied into the Media folder of the player.
In this mode, the player shows as a removable disk in the computer folders.
Before disconnecting the player, always go through the safely remove hardware icon in the right corner below on the computer's screen.
When you're using a software program (e.g. Coby Media Manager or Windows Media Player) for transfers, use the help function in the software.
For Windows Media Player 11:
0. The player should be detected when you connect the USB cable.
1. Setup a library in WMP 11 [ Add to Library ], so the player knows the location of your music files.
2. Create playlist: put songs in a list
3. Sync the list onto the player
4. Wait until synchronizing has finished
Do not disconnect while sync is busy: a message appears when you're allowed to disconnect.
May 22, 2010 | Coby MP815 Digital Media Player
Not sure if player is charging
QUESTION ONE:
Can you see it in "My Computer"? It will show under "Removable Drive/Storage"
QUESTION TWO:
Double click the removable drive to open the folders. Can you see your music, photo and movie folders?
QUESTION THREE:
Can you see the player in Coby Manager - under the "DEVICE" tab?
QUESTION FOUR:
When disconnected from the computer, how long can you listen to the Coby player before it goes off?
If not present in My Computer or in Coby Manager/Device Tab, then it is not plugged in correctly.
a. Disconnect the player from the computer.
b. Wait for it to cycle through "Please Wait" and "Updating Library" screens.
c. Make sure the player is TURNED OFF
d. With player TURNED OFF, reconnect wire to the player then to the computer.
e. You will see a USB connector icon on the player screen and the player charging.
It will appear to be charging all the while it is connected to the computer.
After it has been plugged into the computer for an hour, it should be well charged unless the battery is completely run down. In that case, you need to do an initial 8 hour charge - with the coby player OFF - through the computer. (This one got me when I first got my player!)
f. Use the Coby Manager to disconnect the player (Found HERE CobyMedia Manager fix for MP822 (Windows XP/2000/Vista)
1. Open Coby Manager
2. Go to the DEVICE TAB
3. CLICK on EJECT Button in lower right hand corner.
4. It will have a pop-up screen to ask "Do you want to eject?" Click YES.
5. The second pop-up screen will tell you "The device can now be safely removed from the system."
6. Disconnect the player from the computer.
7. The Coby will now show "Please Wait..."
8. It will take the Coby about 10 minutes on the "Please Wait" screen and then on the "UPDATE the Library" screen - Be PATIENT
You should now have enough battery power to use it. To check the battery level,
1. Turn on the player
2. The battery icon is in the upper right hand corner of the screen - it is ALWAYS RED until it starts to go down... I've not had mine down very far, but believe the red line gets shorter as the battery is wearing down.
Hope this helps.
Apr 07, 2010 | Coby MP-610 MP3 Player
I guess I'm a bit technically challenged. I
if the music is downloaded onto your computer it should be able to be imported into the iTunes library. just go to file in the upper left hand corner in the iTunes library and in the down menu go to add file to library, or add folder, whichever your music is in. then if the music shows in the iTunes library plug in your iPod and see if it shows up in the iTunes menu. if it does click on the icon and in the bottom right hand corner click sync. good luck!
Dec 29, 2009 | Apple iPod touch
I have an NWZ-E436F, when I try to start it it stops at the creating library page and shuts back down, already been reset and is fully charged, any thoughts?
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer?s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings. Then If you have a large playlist to transfer, you may prefer to do it from your media player, such as Windows Media Player. Once your MP3 player is connected to the computer, open Windows Media Player. Click on the "Sync Music" tab. Drag songs that you want from your Windows Media Library over to the "Sync Music" column to create a playlist. Click the "Begin Sync" tab at the bottom once you have all of the songs on your playlist. This action will sync all of the songs to your MP3 player with one click. Disconnect your device once songs have been transferred by clicking on the "Safely Remove Hardware" icon in the bottom-right side of the desktop tray.
Oct 26, 2009 | Sony Walkman NWZ-S616F MP3 Player
I can't get the songs downloaded from my Windows Media Center to the sansa m240 MP3
Sep 30, 2009 | SanDisk Sansa m240 MP3 Player
Apple iPod Video 30 GB
iPods always say 'do not disconnect' when you connect it to the computer. That is what they are supposed to do. iTunes should open a short time after that. If i Tunes doesn 't open, then click on it to open it. You should see your iPod on the left side.
I suspect that you are not using iTunes to put music into your iPod. You cannot 'drag' music into your iPod. ITunes has to put it there.
You should have all of your music in your iTunes library that you want to put into your iPod. You have to use iTunes to put music into your iPod. Actually, this is the easiest way.
Once your music is in iTunes, plug your iPod into the computer. When your iPod appears in iTunes on the left side, click on the music tab and tell iTunes what music and play lists you want to put into your iPod.
Then click sync at the bottom. The iPod will go into sync mode until all of your music is loaded. Then it will say sync completed. You can then click the arrow next to your iPod to release it from iTunes.
When you want to release it from your computer, click on the little green icon at the bottom right of your computer screen. If you don't see it, click the white arrow. Click on the green plug icon and wait until you see safely isconnect mass storage device from the computer. Click on that and wait until you see, 'It is now safe to disconnect your mass storage device from the computer". Disconnect your iPod now.
Hope that helps.
Sep 06, 2008 | Apple iPod MA446LL/A MP3 Player
Adding tracks to library
  1. Make sure that your hdd is connected to the power supply with the AC/DC adapter. Launch the Digital Media Manager DMM application on your PC.
  2. Click PREFERENCE to enter the preference menu, click BROWSE to select the folder where you keep all your music files. Click OK and then DONE to get the music into the library.
  3. Click EASY UPDATE at the bottom of the Library/Device view to activate the easy update screen
  4. Click the UPDATE LIBRARY or UPDATE BOTH icon to transfer new content from the music library of your computer to the hdd.
  5. Once the update finish you may click on the removal icon on the task tray to stop and eject the jukebox. When a message saying the USB device can now be safely removed from the system appears click OK.
  6. Unplug the hdd from PC and enjoy your favorite music on the move.
Jan 02, 2008 | Philips HDD120 MP3 Player
No music library content
try downloading the MP3 player recovery tool from Creative's website (the tool contains the latest firmware update available -- 1.15.03). Plug your ZV+ into your PC, run the program and let it update the firmware. Then format, reload your music and try it.
May 13, 2007 | Creative Labs Zen Touch MP3 Player
SanDisk Sansa e250 MP3 Player Logo
32 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
