Philips Magnavox PPC936 36" TV Logo
Greg McAtee Posted on Jan 05, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Television when i turn on the tv the screen only works through the center of the tv about two or three inches tall, if i wait a few minutes and tap the tv at the bottom near the buttons with minimal force the screen will spread out and stay sometimes other times the tv will power itself off and the back on with the same screen problem. what can i do to fix this?
Anonymous
Level 2:
Scholar:
  • Expert 168 Answers
  • Posted on Jan 16, 2007
Anonymous
Expert
Level 2:
Scholar:
Answers
168
Questions
Helped
92246
Points
298
Check the whole board for possible cold solder and resoldered it!
KD-34XBR970 CRT HDTV startup problem
This is a failure in the vertical amp section. One way to troubleshoot it is to get a can of freeze spray and use it on the suspect components. The other way is to inspect all the solder joints on the amp. Last would be to check voltages on the board. Since it does change with run time, it is being affected by heat.
52 Inch RCA D52W17 BYX1 projection screen tv cuts off when i TURN ON
The set literally has a 3 strikes and you are out where it will try three times and go to shutdown.
The common issues this set has are bad solder connections under and around the high voltage transformer and also in some cases the High voltage splitter block (located way up front behind lower grill below screen unit and behind a removable inspection plate).
The transformer rarely fails but can--photo of what is general appearance of this type of part is attached.
Tv goes on and off a few times then turns off
Thats a common symptom which is usually caused by the Small signal board. You can get a replacement small signal board from www.tvrepairworld.com
2helpful
42 inch lg tv powers on,goes off after about 30 seconds
hello my friend you have some loose connections on the digital board.this board is located right in the top center of the tv.if you do not have repair skills call the repairman he should not charge you too much for this job. good luck
2helpful
Black box showing up in center of tv
your closed caption feature is turn on and in the text mode. either turn off the closed captions or change it from text to cc1
All color guns out of alignment
Needs convergence amps replaced. Sometimes resistors burn and need to be replaced. This repair requires soldering/desoldering equip. and a trained eye, but usually can be done for 175.00-325.00 at a reputable service center. Good luck, Russmann.
13helpful
2answers
Multi color vertical lines on sony wega LCD tv/42 inch
sir do a power reseet ,turn off the tv then unplug it from the electrical source then wait for 1 minute then plug it in and turn it on if it doesn't work call sony customer serveice at 1800 222 7669
13helpful
2answers
Black box on screen
CTPATS-THATBOX IS MOST LIKELY DUE TO THE TV HAVING THE CLOSED CAPTION TEXT FUNCTION ON,SIMPLY GO INTO YOUR MENU AND TURN THE CLOSED CAPTIONS OFF. JOE TV
Standard CRT Toshiba TV - 4inch tall picture in middle of screen...
Not familiar with your actual model.
But a comon problem with older Tosh sets is the 2.2uf electrolytic caps from memory they are usually red there is 1 next to frame Ic & the second is near Psu.
Allso check frame o/p IC for dry solder joints this is easy to test for.
Tap the tv while it is on if the the frame suddenly pop to full size picture you know its dry joints so resolder frame IC.
http://dysonmanuals.inc.io/
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
