Question about PANDIGITAL 7" Digital Photo Frame With Interchangeable Frames
Trying to move photos from Apple Mac to Pandigital frame
The Mac does not seem to recognize the Pandigital picture frame when I connect it through the USB port.  I tried rebooting the computer while the frame is on.  The Pandigital says !USB Connected! but there is no icon on the Mac.
Do I need a driver?
  • 4 more comments
  • Anonymous Dec 25, 2008
    I wish someone had an answer to this. I have the same problem. Could it be that I don't have a new enough system? (im on 10.4.11)
  • Anonymous Dec 26, 2008
    help!!
  • hack5 Dec 27, 2008
    I have the pandigital photo frame and when I try to connect it to my PC, my computer won't acknowedge it or show it on my control panel.
  • nielb Dec 31, 2008
    Me too. It will not show up on OpenSUSE Linux either, although a compact flash card works fine when plugged directly into the frame.
  • ldeaner3 Jan 02, 2009
    I have the same problem and my Mac is brand new
  • tonyorru May 03, 2009
    same problem
Its easiest to transfer the pictures to a usb drive or sd card and insert them into frame and copy them to the internal hard drive. Using Mac OS X Snow Leopard v10.6.2
Posted on Dec 28, 2009
  • 600 Answers
Yes, has the frame got a card slot? if so use your camera as a (expensive) card reader. We brought a cheap keyring thing and found a driver by searching on line
Posted on Aug 13, 2009
Pandigital Photo Frame will not read MMC card
The new card is not compatible with your photo frame. Only thing you can do is to make sure that what you use is compatible. Your manual or website will tell you the largest memory card you can use.
Aug 27, 2016 | PANDIGITAL 7" Digital Photo Frame With...
Tip
Pandigital digital Picture frame PC Recognizing Tip
Hi I just got this frame for Xmas ,,, I tried it my 1st Time it worked perfectly ... I then had other pics I wanted to have on my new frame ,,, Unfortunately I had no success getting the pc to recognize the frame ,, after a quick internet search I found out that I wasn't the only one this was happening to ...
Long story short ,, I figured it out ,, just make sure the power supply is plugged in when you are connecting the frame to a pc via usb ..
Thanks hope this helped .
BORNINDAFIRE
on Dec 28, 2008 | PANDIGITAL 7" Digital Photo Frame With...
Picture frame will not power on
seems to be a problem
http://www.fixya.com/support/t4207203-dpfmate_wont_charge_tried_turn
Try connecting a USB cable and see if you can suck your pictures back. Weren't they on your computer anyway?
http://www.cnet.com/products/pandigital-digital-photo-frame/#!
Oct 23, 2015 | PANDIGITAL (DPF802) Digital Picture Frame
How do i upload pics from my pc
I have a Mac and tried to drag and drop my photos as mentioned above. The results?
- Wiped all pictures off of the frame.
- When I tried to reload from my laptop it shows "format not supported" as a placeholder for the pictures. The images are in jpg format.
How can I fix this problem?
Mar 18, 2010 | PANDIGITAL 7-Inch Digital Photo Frame with...
Pics from Computer to Pandigital
If you use iPhoto to put photos on the frame, you'll end up with a bunch of extra files on the frame that say "Unsupported Format". This is file management data added by iPhoto.
When you connect the frame via the USB cable, it should just appear as an icon labeled "Pandigital" on the desktop. You can just drag and drop your photos onto this icon.
Jan 19, 2010 | PANDIGITAL 7" Digital Photo Frame With...
Can't seem to stop the device to safely remove hardware
if you know it is done transfering the data you should be able to remove it safely even if that message pops up.
Jun 13, 2009 | PANDIGITAL 7-Inch Digital Photo Frame with...
Wanted to erase a single picture, accidentally erased all. Now, computer not recognizing frame, asking me to format removable disk before I can use it. Unable to reinstall. Before, computer recognized...
Yes, that's because you have deleted the files. The frame will work just fine. You can can rename 'removable disk' to PANDIGITAL but it doesnt really matter.
All you need to do is copy the images and it will show up on the frame.
Jun 09, 2009 | PANDIGITAL 7" Digital Photo Frame With...
USB Connection
Hi Amanda and Lisa. Are you making sure the picture frame is off BEFORE you plug it in to your computers? Make sure you:
Turn it off before pluging it in, then plug in the USB cable. Now you can turn on the picture frame and you should see the frame's memory and any SD cards you have plugged into it in the removable drives section.
Let me know if that helps. If not let me know, and thanks for coming to FixYa. If you're happy with my answer then don't forget to rate it appropriately.
Rob
Dec 23, 2008 | PANDIGITAL 8.0" Digital Photo Frame...
PANDIGITAL 7" Digital Photo Frame With Interchangeable Frames Logo
4,181 people viewed this question
Top PANDIGITAL Audio Players & Recorders Experts
Tom Chichester
Greg Ulan
Jose Pino
Are you a PANDIGITAL Audio Player and Recorder Expert? Answer questions, earn points and help others
