Question about RCA HD52W59 HDTV Projection Television
TV turns on and off constantly.
This just started happening in the last couple of weeks. You are watching a program and it shuts off for about 5 seconds and then comes back on. It will do this throughout a program staying on for different lengths of time. Eventually, TV shuts off and we are unable to turn it back on. After waiting about 3-5 minutes, we are able to turn it back on. Any guidance?
  • 905 Answers
This is the heat detection circuit that detects to much heat in the set , cleaning the inside of the set of lint , dust , ect may stop it or it has just been dirty to long and that circuit will now have to be replaced
Posted on Nov 25, 2008
What causes my Samsung TV to turn on and off by it self
I was having problem with the TV freezing up vertical lines and shutting off then restarting and doing it all over again over and over and over , I realized that if I took the back off the TV I no longer had this problem?realizing that the processor was overheating...
I installed a tiny computer fan using the USB 5 volts as a power supply, this fix the problem. Good luck
Nov 20, 2015 | Samsung Televison & Video
Swatch diaphane second hand stuck
Hello, a week ago the small second hand (not long chrono second hand) got stucked and my irony swatch just stop moving. Although the chronometer could be running if started... The small hand just didn't move.
I tried different tricks, like removing battery, pull out main wheel and use chrono buttons to reset arms. Etc.
Today I noticed that when turning the wheel backwards a couple of times (one or two hours back) the little hand moved one second back... Pushing wheel back to On possition made the small hand move forward one second and get stucked again.
Then I did this procedure a couple of times, at some point I turned the wheel back for a while (may be 5 full turns) and noticed the small hand moved more than one second (5, 10, 15 seconds backward)... when I noticed it was moving freely I pushed wheel to on position and noticed the small second hand was running normal.. I hope it works for some of you. Greettings from Canada
Nov 06, 2012 | Swatch Diaphane Chronograph Blooded Silver...
Sanyo DP47460 intermittent sound
Check its speaker. If it is found OK, check and replace the damaged component/s in audio output section circuits.
Jul 22, 2012 | Sanyo DP47460 Diagonal HDTV
I have a Vizio 42 in LCD, model VO420E. The TV makes a loud screeching noise, the screen goes crazy and then shuts off and starts again. There sometimes is a pop. Other times the TV just makes the POP...
Hi well what's happening is that the "Protection circuitry" in the SMPSU has/is detecting a potentially catastrophic fault, and to stop a fire AND EXPLOSION OR INDEED BOTH, IS ATTEMPTING TO SHUT THE SET DOWN FOR SAFETY REASONS, HOWEVER AFTER IT SHUTS DOWN, THE "FAULT" APPEARS TO "GO" AND THEN THE SMPSU STARTS UP AGAIN , ONLY TO DETECT THE FAULT AND SO ON... USUALLY ENDLESSLY OR UNTIL COMPLETE FAILURE OCCURS.
What to do, well in all reality DIY is NOT feasible unless one has LOTS of experience, test gear, tools, isolation transformer, and a service manual. So, contact the local or head office from VIZO, ask them for a referral to an authorised service center, hopefully a local one? in any event, make face to face contact here and ONLY ask first for a "Quote" as to prospective costings and go from there, this way at least you can make up your mind as to repair or replace?
Sep 25, 2011 | Vizio VO420E 42 in. LCD TV
My HP G60-235DX laptop is not staying on after I start it up. I have had this laptop for 2 years now. But since the last two weeks, the laptop is not starting up at all. When I start it up on the...
In most cases this problem comes up by Antivirus program. It checkes running files. To identify the problem try disale antivirus program temporary, start your game and see what happens.
Mar 27, 2011 | HP G60-235DX Notebook
My Breville is only a couple weeks old. Over the ...
Try completely unplugging your pot and then plugging it back in. It is possible that this will reset the programming in your coffee pot. If this doesn’t work, I recommend calling Brevell customer service and they will either help you or probably send you another pot.
Nov 05, 2017 | Breville BKC600XL Coffee Maker
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Samsung tv is shutting off all the time.
Do you have enough air flow to cool it?
It may be overheating....add a fan blowing into it and see if that keeps it on.If it does put a strong small computer fan in somewhere to keep it cool.
Aug 16, 2009 | Samsung HCM4215W 42" Rear Projection...
Picture Fades Away
honestly a tv that old, there probly wont be any parts to fix it. New tvs that size are about $999, go look at a new tv you will be suprised.
Jul 16, 2009 | Televison & Video
Tv turns off
sounds like a bad solder connection i usually fix these problems for a very fair price call tv shop but i'm 90% sure dad solder
May 02, 2009 | RCA HD52W58 52" TV
RCA HD52W59 HDTV Projection Television Logo
79 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
