When turn on tv. there a bright line in the middle of TV. After knocked the Tv. The picture will appear. Low weather is high problem
  • 905 Answers
You have a bad solder connection that will need a new solder job , and it could be on the tuner or on the vertical IC
Posted on Nov 25, 2008
It coming on and after a couple of seconds cut off
Without a brand AND model number or a better description of the problem, any suggestions would be nothing more than a guess.
Unless you are prepared to repair the TV yourself, professionally performed repair, even simplest ones, will probably exceed the cost of a new LCD replacement set.
Due to X-ray and other safety concerns (equipment and/or people), CRT TVs constantly check the voltages and signals required to make a CRT work. A few seconds grace is allowed during start up but after that, any excessive high voltage (real or imagined) or loss of beam deflection circuits will cause the TV to turn off.
Please do the following:
1. Move the TV to a quiet and preferable totally dark room.
Wait until night if necessary.
2. Stand within an inch or closer to the TV screen.
3. Turn on the TV and look and listen for the following:
a. Whoosh sound and/or head hair attracted toward TV screen
Yes. High voltage activated and charged CRT screen.
No. High voltage failed to activate.
b. Hissing or normal sounds from the speaker(s) while set is on.
Low voltage circuits probably okay. Defective low voltage regulator can cause high voltage to exceed limits.
c. Entire screen briefly lit up or single bright spot at center of TV screen
High voltage worked for a moment then the TV shut off due to over voltage or current problems.
d. Brief bright line from top to bottom or single bright dot on TV screen
horizontal deflection circuits bad
vertical deflection circuits ok
TV shut off due to bad deflection/sweep circuit
e. Brief bright line from left to right on TV screen
It would be helpful for you to perform the above "up close and personal turn the TV on test" and report what happened.
Nov 26, 2014 | Televison & Video
Tip
Kitchen table, Screen (G2) voltage adjustment, Course 101
Well, those of you who have no idea why a Screen Voltage (technically known as G2) adjustment may interest you, here is a photo of a bad adjustment (too high).
You may also experience smeared colors… this is caused by a low adjustment. To correct this, we need to get the back off of the TV. It would be a good time to unplug it if you have not already done so. Next we locate the FBT (Fly-Back Transformer).
This is a 20” model and it has 2 knobs. Your FBT may vary, as some slim designs and some large tube models may have 3 knobs.
You will need to look closely at the knobs; they will be labeled “Focus” or “Screen”. On units with 3 knobs, there will be 2 focus knobs and 1 screen. For now, we will be working with at the Screen knob only.
With the adjustments identified, we are ready to plug the TV in (including your standard cable connection) and turn it on… BECARFUL!!! For the rest of this adjustment, we will be working inside of an electrically charged TV. We also need to normalize the picture, so go into your TV menu and adjust the Picture and Brightness settings to the middle or center.
If your TV normally displays a black screen when you do not have a signal connected, ex: Video input 1, then this will be the quickest and easiest setup for you to use. However, if you are not so lucky, you may need to bust through your DVD video collection and find a “between scenes” shot that you can pause on to give you as black of a picture as possible. Eliminate as much light in the room as you can (just remember, you still need to see what your doing)… we want a good view of the screen without the interference of ambient lighting.
Once you have your black screen all set, we are now ready to proceed to the adjustment. If you have lines on the screen, see (HIGH)… if you have color smear, see (LOW).
HIGH: If you have some lines in the picture with a washed out appearance, your Screen voltage is too high. You will need to turn the Screen knob on the FBT counter-clockwise. Do this slowly, until the lines are no longer visible. If you still have a small amount of illumination coming from the screen, back it down a touch further until this just disappears.
LOW: If you have smeared colors in the picture that seem to trail of the edges, your Screen voltage is too low. You will need to turn the Screen knob on the FBT clockwise. Do this slowly, until you just see some lines zigzagging top to bottom on the screen. Now, you will need to turn the Screen knob on the FBT counter-clockwise. Do this slowly, until the lines are no longer visible. If you still have a small amount of illumination coming from the screen, back it down a touch further until this just disappears.
The final set, switch the TV input over to your cable input and check out the picture. Take a good look at some bright scenes and dark scenes. Do they look ok? Adjust the Picture and Brightness in your menu… can you set the picture to your liking? If so, you are all set. If not, double check your work (remember to normalize the Picture and Brightness setting).
If you are unable to adjust the Screen voltage as described above, you may have a High Voltage problem with your TV. This will require a repair and is not covered by this tutorial.
If you are all set and the adjustment is good, we should have a quick look at the focus adjustment. Return the TV to your Black screen setup. Press the TV menu button to give you nice fixed display to focus. Adjust the focus knob(s) until you have the clearest picture. It’s important to balance the center of the picture with the corners of the picture. If the center is too sharp and the edges and corners are blurry, it is not a good adjustment. Do your best, you are the final judge of your work here.
Once you have finished the adjustments and verified the picture with your cable picture, you are ready to close it up and return the TV to normal service. Unplug the TV, replace the back cover… enjoy!
I hope this was helpful. If you benefit from this tutorial, please leave some feedback.
on Mar 21, 2010 | Televison & Video
Some channels on my tv are dark and tinted orange, I used the menu button to display the menue and scrolled down to picture but I did not know how to select picture.
Hello
Adjust colour control to zero, and check for a pure black/white picture. Adjust contrast and brightness control to minimum and check whether the picture goes completly off or a slight picture prevails. If the picture goes out when you turn down brightness control to 1/3 position, that is about 20 points, your TVs screen voltage is very low, and it can be adjustable. If the picture does not go out and more brightness prevails, screen voltage is high. If the screen voltage is high, there will be some fine lines across the screen at about an inch apart; on the whole screen from top to bottom.
Screen voltage adjustment is critical for the clarity of the picture. If it is low, no proper colour will be dispayed. If it is high, it is harmful to both picture tube and your eyes.
Never try to adjust it without proper knowledge about it. The screen control can be located alongwith the LOT [Line Output Transformer], of your tv. There will have two adjustable controls there, one is for Focus, and the other is for Screen. Both are interactive, that is adjusting one will effect an other.
Oct 18, 2010 | Emerson TS2587D 25" TV
I have a sanyo DS35580 and there is a blue line across the middle of the screen
You haven't stated whether there is screen or picture. If you see only a blue line across the screen with high brightness, vertical output Ic of your TV has burned out. Don't switch on the set further or increase its brightness, till the fault is retified. Otherwise there will a phosphur burn occur where the blue line is now, and it is internal, whcih cannot be retified anymore.
Oct 16, 2010 | Sanyo DS31520 31" TV
Mitsubishi VS70707 Has developed subtle lines in picture
If they are faint white lines, they are called re-trace lines. They are caused when the current to the CRTs is too high. One way to check is to turn the brightness down. They should go away, but if the picture is too dark, you will need to turn down the "screen" control. This will take some handy work. If you are handy enough, take the grill off the front. Inside you will see a little black box, about 5 inches wide. there are 6 knobs on it, 2 for each color. One row is for focus (each) the other for screen (brightness). It is written on the part. The trick is to turn each of them down equally or risk having a slight tint of color. Really not hard at all, but requires the TV to be on to see. You shouldn't need to turn it but a fraction. Good luck.
Feb 16, 2009 | Mitsubishi VS-70707 70" Rear Projection...
Green picture
a green screen on power up with retrace lines. At shut down a point appears in the middle of the screen. Sounds like either a shorted G2 grid, or bad flyback. If a phospher flake has shorted the grid in the tube, you can sometimes have luck by using a megger set at 1000VDC, to burn away the short. This is usually caused by the line HV going too high causing the anti-UV protection to kick in so fit a dummy load 40W lamp instead to the line output to allow measurements to be made.
Oct 19, 2008 | RCA 20F512T 20" TV
White horizontal line down middle of TV screen
caution whenever you see horizontal line please reduce brightness of your tv for safety of crt. your problem in vertical section only mostly due to loose contact in connector,print or loose components.
Sep 20, 2007 | Mitsubishi CS-35505 35" TV
Black screen
could be some bad solder connections on the crt socket or around the flyback area dealing with the brightness
May 12, 2007 | Panasonic CT-32G34 34" TV
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
