Question about Marantz SR-19 Receiver
Unit will power up but no sound
Hi i have an sr-19. usually when i power it up it will click once, wait a second or two then click again and the sound will start. now it clicks once and the second click never happens. no sound comes out. there is a display and i can switch between sources but no sound. does this sound like a faulty power supply? what do these things cost to fix? (usually)
  • myencorehome Oct 05, 2008
    I have a SR-19 EX, same problem as of yesterday eve... any help would be
    appreciated
  • Allen Walker
    Allen Walker Apr 04, 2009
    me too
5 Suggested Answers
SOURCE: Marantz SR 7200
It is likely that the PA stage has developed an offset voltage in the output stage. The faulty amplifier channel can be found by progressively disconnecting the collectors of the of the power transistors until the protection fault disappears. Once the faulty channel is found the the cause of the offset has to be traced to the faulty transistor or resistor. Don't forget that if you can smell smoke or burning then there are likely to be components(esp transistors) that have been damaged by the fault.
I had a Luxman unit that destroyed 5 transistors in the output stage that was due to an open .5W resistor in the driver stage.
Good luck.
Posted on Mar 29, 2009
cjackHD
  • 71 Answers
SOURCE: Audio glitch on Marantz SR-19
It's probably not heat due to the Marantz' large frame and heat-synchs.
This could simply be a mismatch of impedance. The amp is 120w per channel, so make sure the speakers can handle this. Check the impedance (ohms) of the speakers and the amp as well. Clipping can be caused by overpowering the speakers, which could damage the speakers in the long-run.
If this is only from 1 source- (i.e.- Blu-ray player or cable) then it could be digital clipping.. This Marantz can decode 96kHz PCM or normal Dolby Digital & DTS. If this is a Blu-ray it may be streaming 192kHz PCM... (but most likely the Marantz will not even attempt to play that audio)
I hope this helps.
Posted on May 31, 2009
SOURCE: Hi there. I have a Marantz SR-82 Receiver that
Hi, try to turn down the input balance knob, I think you have overloadet it.
Posted on Mar 19, 2010
freetek
  • 5569 Answers
SOURCE: A few seconds after pressing
The clicking is probably from a relay that is protecting from an overload either misinterpreted or real. Overload circuits can also fail or you have a component that is intermittently shorting causing a momentary overload.
Posted on Mar 27, 2011
Delete freeze
Depress the power button for a few seconds till the computer turns off. Wait a few seconds and restart.
Where does it freeze, during startup, or once within Windows? If you make it somewhere into the Windows operating system, restart, and during startup, peck on F8 key till you get to the B/W Startup options. Cursor down to "Safe Mode with Networking", and press the Enter key. If it makes it to Safe Mode, use "System Restore" (SR) to back up to a date before the problem occurred. If SR isn't available, or doesn't work, enter Safe Mode again, use your IE, Firefox, Google Chrome, or Opera browser to go to www.download.com. In the right-hand column of Most Popular Downloads, you'll find Malwarebytes. Download and run that program to see if the problem came from a malware infection. Follow the instructions to scan, and afterwards to remove the infections, then restart the computer.
Oct 31, 2013 | Computers & Internet
BUSH 42" plasma no picture or sound?
You have a power supply problem, replace the Module.
What you ear is a click relay No juice to activate the relay
Some cups may be dried.
Nov 01, 2012 | Bush Furniture Bush My Space Rhea 42 in....
Receiver will not turn on and is making a clicking sound TX-NR 609
This is the same problem i've had with my POS nr609. I will never buy Onkyo again.. Everyone warned me about the poor quality.. This thing worked for a year and a half, blew the amp., replaced and now another year and a half, f'd again. Save your time, buy a Denon or a Harmon Kardon. Better quality, same features.. Boat anchor here
May 15, 2012 | Onkyo TX-NR609
What is a 19 error code on the Ibm printer 4224
Attachment Card Failed Power on Tests.
1. Switch Power off (O).
2. Wait 20 seconds and switch power on(I).
3. If the printer displays (19) again then call for service.
May 14, 2012 | IBM 4224 Model 101 Matrix Printer
HP Touchsmart IQ526- Black Screen and Amber LED please help! No display. Is this a hard drive issue?
Also had this issue on the Touchsmart IQ526. Removed the CMOS battery, waited some minutes, then powered on. The power button remained blue and had video again. Reinserted the CMOS battery and put the unit back together. Note - the battery was on the mainboard.
Mar 24, 2012 | HP TOUCHSMART IQ526 PC PC Desktop
Reset linksys router
General Linksys has a reset button on the back on the unit. Its really small and recessed into the unit. To cause the reset to happen do the following:
1 Get a pen/paperclip something small and pointy and hold down the reset button
2 after 20-30 seconds of holding button down you will notice a change in the lights in the front once you see this unplug the unit and wait 5 seconds.
3 Plug unit back in and you should be good to go
On some units if you enter into a web browser 192.168.1.1 you can enter into the admin controls and do a restore to factory defaults and worse case if you need to you can flash the unit (this will also update the system to its latest firmware)
Dec 30, 2009 | Computers & Internet
KTC-H2A1 satellite receiver has lost its audio output
Hi
Check the settings on your unit maybve you are in mute mode.
Thanks
Likha
Oct 01, 2008 | Kenwood Audio Players & Recorders
My bluetooh wnt turn off on my mobile
Hi Sean89,
Try re booting your phone (power it off, wait a few seconds, and power it back on), if the bluetooth device is truly off, all should be well with your phone once again. And, when you power up your bluetooth device again, it should connect as usual.
Good luck.
Mar 18, 2008 | Samsung SGH-D600 Cellular Phone
No Sound
well, if it powers up, youve still have hope// check and see if you can see a fuse holder at back of stereo... or go to a radio shack or electronis place and get whats called 'contact cleaner' ( may go by a different name, make SURE you know that the salesperson knows what your talking about..PS.you dont have to buy the pricey stuff, but dont get the cheapest either.) then UNPLUG stereo, make sure its not hot ( dont have it on for a long time before working on it) then pull out the knobs on the front ( the volume,left/right,etc) spray a LITTLE bit into the stereo where the plugs go.dont drench it, a little goes a long way) after spreying it in, turn the knob back and forth so it gets to all the points.... make SURE its dry before plugging it back in, you can tell if you see any moisture where you sprayed.( another reason, not to spray much) i usually let my stereo and tvs dry over night before trying them.while your waiting, may as well take a cloth and clean the face, get any cruddies off... good luck
Mar 12, 2007 | Kenwood VR-405 Receiver
Marantz SR-19 Receiver Logo
77 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
