Question about Hitachi CP-X430 Multimedia Projector
Hitachi CP-X430. Image turns purple after a while.
We have two of these projectors, same model-same problem.  The image from the projector turns purple after a while, and it happens on all inputs.  Turning the power off, then back on, solves the issue most of the time, albeit temporarily.  Perhaps some component in this model has exceeded it's lifespan?  I'm curious to know if anyone else is having this problem as well.
  • estepechito Mar 10, 2009
    the top right hand corner is doing the same on one of mine as well. I dont know either. But i like to take the bulb out and blow the unit out with a can of air and wipe what I can then do the same to the other and switch bulbs and rotate the units because I have only one bulb and 2 units as well. there is also a place called that will get you a new one for 250 or that they redo the bulb with a longer garanty because they use a better filament.
  • 752 Answers
SOURCE: No input detected on projector
it sounds like the A/V reciever does not upconvert the component signal to HDMI. Not many do. The Marantz recievers will (SR6001, SR8001, etc..). Also bear in mind that HDMI cables are finicky and may require amplification over a few meters long.
Posted on Dec 04, 2007
  • 5 Answers
SOURCE: hitachi cp-x430?
My projector is not Hitachi but I had a similar problem. My manual suggested checking under "signal" to make sure that "auto" was "on". The thing is, there were two places where "signal" came up on the menu. I had to go under "set-up" to "signal" and then I was able to correct it by setting "auto" to "on". I hope this helps.
Posted on Jan 06, 2008
  • 563 Answers
SOURCE: Hitachi CP R555 Multimedia LCD Projector
Hi there
In your Menu options there is a subfolder where it either reads lamp or lamp timer.
Scroll down to it and hold down you right or left arrow key on the Projector for a couple of seconds.
Posted on Mar 26, 2008
  • 51 Answers
SOURCE: Hitachi CP-X250 LCD Projector
clean filter and reset the filter timer by advanced options filter timer and hold reset till menu shows then arrow up and it will zero out.
Posted on Dec 08, 2008
  • 41 Answers
SOURCE: hitachi cp-s235 projector- red lights and projector turns off
There is a small tab on the lamp cover that should press into an "L" shaped slot on the lamp housing. This tab may break off, and not press into slot far enough to make the lamp dectection switch click. When the lamp heats up, the plastics expand and the detection switch opens. The projector quits as if no lamp is installed. The fix is to make an extension for the tab. I cut a small piece of sheet metal and crazy-glued it to what was left of the plasic tab.
Posted on Feb 04, 2009
Go to Settings/Advanced Settings/Setup/Mirror and change to NORMAL. It'll probably be set to H:INVERT.
Sep 10, 2012 | Hitachi Gst Hitachi CP-X2011 Projector
I have a Hitachi CP-RS56/CP-RX61/CP-RS57 projector that we just ceiling mounted. My tech spec is in the hospital and can't help me out. How do I flip the image that is projected?
ok the onboard menu built into the projector accessable via the remote or button on the projector... go through this menu carefully and read everything you will find the way to flip the image in there :) hope this was helpful.. thnx
Feb 25, 2011 | Hitachi CP-X345 Multimedia Projector
Flip image on Hitachi CP S240
The setting you are looking for is called mirror. If you go into your menu, you should be able to find it. I'm not fmailiar with that exact model, but Hitachi is very good about keeping their projectors consistent where the menu/options are concerned. Once you find the mirror section, cycle through the options (there will be 3 or 4) until you find the one you need. If your projector is hanging upside down from the ceiling, select the ceiling option.
Feb 08, 2011 | Hitachi CP-S240 Multimedia Projector
Upside down image
These projectors are designed to be mounted upside down. Think of a projector that is ceiling mounted in a classroom. Change this setting in Menu - Advanced Menu - Setup - Mirror.
Jun 09, 2009 | Hitachi CP-X445 LCD Projector
MacBook connected Hitachi CP x301 Icons do not appear
Ok what's happening is that you have it set up as an extension of your desktop, you need to mirror the displays. when your projector is plugged in and it is showing only the desktop background, open "System Preferences," click "Displays," click "Positioning" and check the box that says "Mirror Displays." This should do the trick.
Mar 28, 2009 | Hitachi CP-X301 Projector
Hitachi projector cp - s210
hi there,
I have just done the exact same thing today. Press menu button on projector. Scroll (navigate) to the mirror option. This give you the options to mirror image left to right or up and down.
This should fix any of your problems.
Feb 03, 2008 | Hitachi CP-S210 Multimedia Projector
Green backround on the image
My projector is not a Hitachi but I think the menus are similar. You might try finding "signal" under "setup" in your menu and check to see if it is on or off. You want it "on". I hope this helps.
Jan 06, 2008 | Hitachi CP-S210 Multimedia Projector
Hitachi cp-x430?
Nov 01, 2007 | Hitachi CP-S210 Multimedia Projector
Hitachi CP-X430 Multimedia Projector Logo
133 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
Chris Goulet
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
