Question about Plustek OpticFilm 7200i Film Scanner
Plustek OF 7200i: Scanning assembly can move one way only.
When I try to run the unit without case it appears the scanning assembly will make a valid pass (rear-to-front) only if previously moved back manually (it's driven by a single motor via a worm screw). So it's either the motor is not engaging in reverse when it should or the circuitry misdetects the assembly's position thinking it's in the rear when in fact it's not.
4 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: problems with installing a plustek 7200i film scanner
Delete the software. restart computer Come off line. Disable the anti virus software and fire wall. Now reinstall the software. Check out that is runs before reinstating A/V and firewall.
Posted on Jul 24, 2007
  • 256 Answers
SOURCE: negatives scan as negatives and not as pictures with the plustek 7300
In the Twain driver for your intellscan, there should be a selection for the type of scan. It should be set to "black & White Negative" or "Color Negative". The program you use to edit the scanned file should be able to change it to a positive if the scanned result is still negative. Programs such as Photoshop, Paint shop Pro etc can use Twain to have the scanner scan directly into them. There the phot (negative) can be edited and saved.
Posted on May 30, 2009
Tauqeer
  • 496 Answers
SOURCE: I have a Plustek OpticFilm
It is quite possible that there is another piece of software that is clashing with your Plustek OpticFilm scanner. It is hard to tell which software is having a clash. If you remove that software from your system you will obtain the desired results. I suspect the SP3 of Windows XP may be responsible for this because Microsoft has indicated that Windows XP SP3 is not for everyone. If you install Windows XP SP2 uninstalling XP SP3 your problem can definitely be rectified.
Good Luck!
Posted on Mar 10, 2011
Grey and blue strips appearing when scanning slides
This scanner does not work properly with Windows 7 and there is no fix yet that I know. Also, if you have another scanner installed, such as an all-in-one printer, it will cause conflicts. Having both Windows 7 and another scanner installed would cause this problem. Sorry it's not a fix, but without knowing your operating system (it takes a beefy computer to run) and your setup I can't be more specific.
Mar 27, 2015 | Plustek Opticfilm Office Equipment &...
I haven't used my Optic Fil 7200i (plustek) since upgrading to Windows7. Also, I have moved and my software disk didn't make it in the move! Is there a way to get one mailed to me: Bailey...
You can purchase the software disk from this link:
http://plustek.com/usa/buy-parts-and-accessories.html
Alternately, you can download the installation software/driver free of cost from the manufacturer's download website by clicking this link
On the page which opens, enter OpticFilm 7200i in the Serach box under "Option 1: Search By Product Name" and click the Search button (See attached image)
Then select OpticFilm 7200i from the results window. Download the driver in .zip format from the list which opens. After the download completes, extract the .zip file to open the driver file.
Here is the direct link to the driver file.
Hope this solves your problem. Thanks for using FixYa.
Jan 21, 2011 | Plustek OpticFilm 7200i Film Scanner
No drivers for Plustek Film Scanner
You may have to uninstall the old software and then go ahead and download the software again. It has the windows 7 drivers in there then install it by running the setup file. You can also go into the device manager and right click on the device in there and manually update the drivers in there by telling it the folder that the drivers are located in.
May 01, 2010 | Plustek OpticFilm 7200i Film Scanner
Lost CD
Go to http://www.plustek.com/support/download.asp fill out the form and it will list what you need to set it up again.
May 30, 2009 | Plustek OpticFilm 7200i Film Scanner
Need AC Power Supply Adapter for Plustek OpticFilm 7200 Scanner
I revisited the Plustek website and found a page where I could send an email to customer service describing my problem. About 24 hours later I received a reply which included an attached order form with the price and the appropriate shipping and tax filled out for the item I needed. The order form instructs one to fill out your particulars and fax the form to Plustek. I have no fax capability so, after a phone call, I was instructed to send the form as an attachment to an email to the customer rep. I received confirmation of my order so, I presume that my order is in the pipeline.
Feb 10, 2009 | Plustek OpticFilm 7200i Film Scanner
Hunting negative holder tray for Plustek 7200, can't find one anywhere
Plustek Tech support gave me the following website for parts:
http://www.plustek.com/usa/part/main.asp
You have to print the form & fax it.
Oct 02, 2008 | Plustek OpticFilm 7200i Film Scanner
Computer
If the Scanner was plugged into the computer before the software was installed, the computer does not know what to make of the unknown device, (which it cannot identify). This is why it is recommended that the software is installed before connecting a camera scanner or printer. If you check in "Device manager" you may find unknown devices listed under "Other devices" if you remove these and then disconect and reconnect your scanner, it should then detect the scanner correctly.
Aug 13, 2007 | Plustek OpticFilm 7200i Film Scanner
Problems with installing a plustek 7200i film scanner
Jul 24, 2007 | Plustek OpticFilm 7200i Film Scanner
Software hangs
Tell Plustec this seems a common problem- perhaps there is a patch
Jun 22, 2007 | Plustek OpticFilm 7200i Film Scanner
Open Questions:
Plustek OpticFilm 7200i Film Scanner Logo
43 people viewed this question
Top Plustek Office Equipment & Supplies Experts
Gareth Cockram
Gareth Cockram
john1959ny
john1959ny
Are you a Plustek Office Equipment and Supply Expert? Answer questions, earn points and help others
