Question about Microwave Ovens
Kenmore MW run away exhaust fan
Looking for diy fix for Kenmore 721.62642200 - exhaust fan strats on its own and will not stop - control board? thermostat? can i fix this - looking for directions and source for parts.
  • Microwave Ovens Master
  • 9,098 Answers
It may be that your hood fan thermostat (if so equipped) has failed.
This is usually located on the floor of the chassis, not to be confused with the thermostat mounted on the magnetron.
Otherwise, you may have a shorted relay on the control board.
You can find exploded views and order parts by entering your model number at the Sears parts site.
There may also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
We regularly repair such control units / control boards for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Nov 27, 2008
When cooking the fan doesn't run anymore. When I start cooking food the fan used to start right away, now it runs for a few seconds then stops but the food is still being heated.
The fan, a door switch, or control board relay may be causing the fan issue. Running the MW without a fan will not only cause steam buildup inside the cavity, it will cause the magnetron to overheat. If the MW has a thermal protector on the mangetron, it should shut the oven off when the temperature gets too high.
Nov 08, 2017 | Microwave Ovens
LIGHT, turntable, and fan don't come on
follow this test and fix it. God bless you
  1. Exhaust fan motor If your exhaust fan motor is not running, there are a couple of things that you can check involving the motor to locate the problem. After removing the fan motor, you can manually attempt to turn the fan blades with your hand. If the fan motor is working properly, the blades should spin effortlessly. If this does not occur and the blades are taught, the motor will need to be replaced. Secondly, the fan motor itself can burn out due to time and usage. Using an ohm meter, the exhaust fan motor should read open for continuity. If it does not, then the fan motor has expired and will need to be replaced.
  2. Thermostat Another part that could cause the microwave exhaust fan to not work is a faulty thermostat. A thermostat gauges the air temperature, which activates the exhaust fan when required. If this part becomes flawed, the exhaust fan will not energize and the thermostat will need to be replaced.
  3. Main control board If your exhaust fan is still not working and the microwave fan motor, wiring, and thermostat are operating accurately, the root cause could be with the main control board. Replace the main control board.
Dec 09, 2013 | GE CVM2072SMSS Microwave Oven
Why does the fan keep running on a kenmore spacemaster 300?
Check those 3 micro switches in the door latch assembly. A bad microswitch can blow the main fuse. This usually ruins the microswitch.
Nov 13, 2017 | Kenmore Microwave Ovens
Fan running when door open
measure this test and use the multimeter for fix it. GOD BLESS YOU
  1. Exhaust fan motorIf your exhaust fan motor is not running, there are a couple of things that you can check involving the motor to locate the problem. After removing the fan motor, you can manually attempt to turn the fan blades with your hand. If the fan motor is working properly, the blades should spin effortlessly. If this does not occur and the blades are taught, the motor will need to be replaced. Secondly, the fan motor itself can burn out due to time and usage. Using an ohm meter, the exhaust fan motor should read open for continuity. If it does not, then the fan motor has expired and will need to be replaced.
  2. ThermostatAnother part that could cause the microwave exhaust fan to not work is a faulty thermostat. A thermostat gauges the air temperature, which activates the exhaust fan when required. If this part becomes flawed, the exhaust fan will not energize and the thermostat will need to be replaced.
  3. Main control boardIf your exhaust fan is still not working and the microwave fan motor, wiring, and thermostat are operating accurately, the root cause could be with the main control board. Replace the main control board.
Nov 08, 2013 | GE JVM2070 Microwave Oven
When Exhaust button pressed, vent fans not working, but microwave running for 30 seconds.
test the components and fix it. God bless you
Oct 24, 2013 | Frigidaire Microwave Ovens
My 900 em do oven keeps over heating and switching off
follow thes steps and fix it.God bless you
Exhaust Fan Motor
If the exhaust fan does not run the fan motor might be bad. Remove the fan motor from the microwave oven and see if the blades can be turned by hand. They should turn very freely, if they're stiff the fan motor will need to be replaced. The fan motor can also burn out. To test this use an Ohm meter. The motor should have continuity. If it doesn't, replace it.
Thermostat
If the microwave exhaust fan is not working the thermostat might be defective. The thermostat senses the air temperature and turns on the fan as needed, if it's defective it won't turn on the fan. Watch our video on testing thermostats.
Main Control Board
If the microwave exhaust fan is not working check the exhaust fan motor and wiring. If they are good the main control board might be defective.1_24_2013_5_50_54_pm.gif1_24_2013_5_53_00_pm.jpg
Jan 24, 2013 | Microwave Ovens
We have a kenmore ultra wave microwave and the fan has stopped working and now the microwave won't operate. Any suggestions?
see this causes and fix it .God bless you
Exhaust Fan Motor If the exhaust fan does not run the fan motor might be bad. Remove the fan motor from the microwave oven and see if the blades can be turned by hand. They should turn very freely, if they're stiff the fan motor will need to be replaced. The fan motor can also burn out. To test this use an Ohm meter. The motor should have continuity. If it does
Thermostat If the microwave exhaust fan is not working the thermostat might be defective. The thermostat senses the air temperature and turns on the fan as needed, if it's defective it won't turn on the fan. Watch our video on testing thermostats.
Main Control Board If the microwave exhaust fan is not working check the exhaust fan motor and wiring. If they are good the main control board might be defective.
Oct 02, 2012 | Microwave Ovens
Why won't my kenmore microwave's exhaust fan turn off?
It is more than likely one of the door switches has malfunctioned, or there is a problem with the keypad control board.
Apr 19, 2012 | Kenmore Microwave Ovens
Whirlpool model MH7100XYQ microwave, exhaust fan
sometimes the control board will short out and not let the fan or cook top light work.
if you want to try and remove the control board, look on the back of the board for any burnt off tracers. those are the wiring connections on the board that move power from a wire to a relay.
it is usually easy to see the burnt out piece, and if you can solder a new wire across where the burnt out part is, then it should work ok again.
if you cant solder, then a new control board will cost about 125-150 bucks.
Jan 30, 2009 | Whirlpool GH7208XR Convection / Microwave...
Fan and light constantly on
which fan? the exhaust fan or the control board cooling fan? the cooling fan is controlled by a thermostat just behind the control panel. it turns the fan to protect the board from overheating.
Feb 18, 2008 | GE JVM1440 Microwave Oven
Microwave Ovens Logo
77 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
