My printer will not print and i have installed it the power light is keep flashing and i dont know if that has any think to do with it .
  • 541 Answers
It mean that your printer need to be reset let me no wot printer you have and i will have a look for you
Posted on Nov 25, 2008
WAS HAVING TROUBLE WITH HL 2040 PRINTER , LEARNT HOW TO RESET , FIXED THE PROBLEM. TRIED TO PRINT A WORD DOCUMENT , WOULD NOT PRINT - BUT WOULD PRINT EXCEL DOCUMENTS. WHILST TRYING TO GET STARTED AGAIN...
Hi Ron, I dont think you have a printer problem, i think you have a print driver/computer problem.
To find out unplug it (the usb) from you computer, turn it off so no data remains from previous print commands sent from your pc and run a self test by holding your green go button when you turn it on, keep it held untill toner, drum and paper lights light up, then let it go, then press the go button and the printer will print a self test....
If this works ok then we know your printer is ok. and your issue is as i suspect it is, with your print driver, paper size or tray select settings in Driver or in Word or in Excel or your document.
You can isolate if document problem by doing self test in print driver in control panel..
If self test on printer unpluged works and we have no error lights and are seeing the test ok and no flashing lights then you may want to ensure driver is good by completly unistaling the driver on your pc, do this by unistalling all brother stuff from control panel/programs and features (depends on operation system you are using).
Then with it still not connected, go to brothers web and download the full software and drivers package to suit your operating system, run it and only plug in the usb when instructed.
Let me know if your printer shows an error when not connected or if self test fails and Ill go down that road with you... if paper light on it when not connected, it tells us we have a jam, make sure you check back door and under toner drum and paper is sitting neat in tray
But when you tell me excel works and word doesnt, i dont think printer, it is software.Check your page size settings in word and excel and of your documents as the flashing paper light may be the printer trying to tell you the data sent to it from word is a paper size mis match to what the printer has in its tray and it wants you to feed the correct size paper in the manual feed/bypass slot. You should also check paper size and tray selection in your print driver in printers and faxs under control panel is the same as your document. Here is your manual
and here is where you can download your print driver (unistall old software and unpug usb first)
The more i ponder this, it is page size settings in document/excell/word and printer is asking you to feed paper in manual pass slot (above tray)
CHEERS RON
STEVE ;)
hi
Feb 22, 2012 | Brother HL-2040 Laser Printer
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Epsom stylus c48 - have changed the black ink and no cartridge in printer for colour. The power light keeps flashing and the "ink paper" light is solid, nothing is printing. Dont know what to...
check whether you printer suits your computer operating system ...
in some cases Windows 7 does not seem to support a certain range of printers ....
if you have upgraded your computer try connecting the printer to some other pc ... with a different operating system ....
May 12, 2011 | Office Equipment & Supplies
Printer not able to print?
Printer Keeps flashing green light
Mar 31, 2010 | Canon BJC 250 InkJet Printer
The middle light keeps flashing 7 times then stops then repeats. the other button to change the paper type. i dont think its a ink issue possibly a paper one.
This mean multiple ink tanks of the same color installed or Ink tank in a wrong position.Check your ink tanks.This ink tanks has a memory chip.Sometimes this chip fails.
If the green light blinks with a orange 7 times this mean the waste ink tank is full.Follow this:
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Nov 04, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Installed a lexmark z12 printer but not the power light but the light next to it keeps flashing and it wont print
  1. Turn the power OFF.
  2. Open the front cover.
  3. Turn the power back ON. The print cartridge carrier should move to the install position located in the middle of the printer.
  4. If it does not, close and reopen the cover:
  5. Remove the color print cartridge.
  6. Close the cover.
  7. If there is no error indicated by flashing lights, the color cartridge has short-circuited.
  8. However, if you continue to get an error, repeat steps 1-3, and then go to step 9.
  9. Remove the black print cartridge and reinsert the color cartridge.
  10. If there is no error indicated by flashing lights, the black cartridge has short-circuited.
  11. If you continue to receive an error in both cartridge scenarios, both print cartridges have short-circuited.
Dec 01, 2008 | Lexmark Office Equipment & Supplies
My printer is not working properly. The light on the left (Amber Light, I guess this is what it is called) is blinking, but there is no paper stuck in the printer. How do I get it to stop and keep...
hello!
You will see 3 led lights on the printer. They will blink continously if:
if the print cartridge status light is flashing
-- check if the top cover is open, Close the top cover.
-- there may be a problem with a print cartridge
1. Verify that the correct print cartridges are installed.
2. Check if a print cartridge is low on ink or improperly installed.
if the resume light is flashing
-- the printer may be out of paper
1. Place paper in the In tray.
2. Press the Resume button on the front of
-- the printer may be ready to print the second side of a two-sided document
1. Follow the onscreen instructions for printing the second side.
2. Press the Resume button.
if the power light is flashing
-- the printer is preparing to print
-- The light stops flashing when the printer has received all data.
if all lights are flashing
-- the printer may need to be restarted
1. Press the Power button to turn off the printer, then press the Power button
to restart the printer.Proceed to step 2 if the lights continue to flash.
2. Press the Power button to turn off the printer.
3. Disconnect the printer from the power source.
4. Reconnect the printer to the power source.Press the Power button to turn on the printer.
May 06, 2008 | HP DeskJet 940c InkJet Printer
Epson C60 Stylus Status Monitor Does Not Work On Windows Vista
I ve been having the same problem with my Epson 1290 and Windows Vista! It works fine but I cant get the status info on my ink levels. Its so annoying when u run out of ink the LED on the printer goes on but you dont know whick cartridges to replace! I hope Microsoft and Epson get this sorted out because it so annoying and I end up spending more money on inks than needed! I read someone had similar problem, installed the 1290 M driver (via Vistas set drivers) but it didnt work for me!
any other suggestions?
Apr 18, 2008 | Epson Stylus Photo 1290 InkJet Printer
Brand new Printer lights flashing
You should install driver first, then connect printer when prompted, then install inks, as it needs the driver to tell it there are full inks fitted, refer to the manual.
Dec 20, 2006 | Ricoh Aficio G7500 Printer
41 people viewed this question
jasbo
jasbo
