Hooking up a Klipsch
I just bought a pioneer VSX 1018 ahx reciever I also hooked up a Klipsch sub woofer. when I went thru the system set up and checked all the speakers work properly except for the subwoofer. There is a dedicated out for a subwoofer, i am using a Rockfish cable 15' cable.
So here is my headache all speakers except the sub work, I pulled the cable out of the back of the sub, I can make the sub humm by just laying the cable at the input port on the back of the sub but when i plug the cable all the way in the sub will not produce sound when i watch a movie or listen to music. Please any help will be greatly appreacieated.
  • loves_enterp Nov 26, 2008
    Thank you for your response.
    What do i look for on the package to verifie it is the right cable.
    I am at owrk right now so I need to do this late tonight when i get home.
    Again thanks
    Ps if it turns out I have the right cable what should i check next
Need to confirm that you have a subwoofer cable which is a coax cable. I have seen this sort of issue when using a standard RCA cable. If you need a cable you can order it at monoprice.com
Good luck..
KGS
Posted on Nov 25, 2008
I have a Pioneer VSX 823 - K, and when I hook up my Klipsch HG-12 300 watt subwoofer to it, the receiver is prone to overheating or just shutting off with too much bass. Is there a fix to this?
This is receiver thermal going in protect issue and has no bearing to your sub, The sub has its own power amp and not supplied by the receiver. Thermal module may be bad. See a tech.
Mar 06, 2014 | Pioneer VSX-823-K
Psw111 hook up to vsx-522 subwoofer
Just use one of those jacks. Then turn the frequency select dial all the way up. This will work just as well.
Apr 21, 2013 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Pioneer VSX-822-k Subwoofer problem
Go to manual setup, selct the subwoofer and set it to Pus.
Jul 29, 2012 | Pioneer Vsx-822-k 5.1-channel 3d-ready...
Power sub woofer is not working on my pioneer vsx-81txv everything is working all the speakers except the power sub connection at the back all i can hear is the hissing sound when i try to connect the sub...
Hissing? How loud? A sub isn't even capable of making high frequency sounds at normal volumes.
The Pioneer manual would tell you how to enable and test the subwoofer output.
Page 17 and the MACCV procedures on Page 33 (auto) or 43 (manual)
Jun 13, 2011 | Pioneer VSX-81TXV Receiver
Sub Woofer works but it won't when hooked up to the receiver
Yes, go to your menu then setup then speakers then subwoofer, it's probably in "LFE" it should give you the option of Sub, LFE, or Both. that should do the trick. Also check the crossover point and season to taste. While your at it; there should also be a setting for speaker level, toggle down to sub and adjust the sub out level, it's probably at it's minimum setting. Hope this helps
Jun 23, 2009 | Pioneer VSX-D409
Sub won't work
if using a sub out cable to a powered sub,you have to go into the reciever menu and turn the sub out on
May 17, 2009 | Pioneer VSX-406 Receiver
Need wiring assistance
Just need to register, login and you can download manual from here.
It will take only two minutes.
Hope this helps.
Apr 26, 2009 | Bose Acoustimass 10 III System
Subwoofer amplifier
Here's how I'd do it... connect the subwoofer pre-out to one of the unused analog inputs (CD or CD-R perhaps?). Turn on Zone 2 by pressing the MULTI-ZONE ON/OFF button. The MULTI-ZONE indicator will light.
Press CONTROL. (Zone 2 should display) Use the INPUT SELECTOR dial to select the source for the zone you have selected. In my example, CD or CD-R.
Of course, you'll need the sub hooked up to the Surround back speaker terminals.
Here's a link to the manual online:
Pioneer VSX-1018 Manual
Things to keep in mind:
The Surround Back setting must be set to ZONE 2. See page 41 of the manual.
The volume level going to the sub will probably need some tweaking. Check out page 7 to see how to manually adjust volume levels, or get it close by adjusting the Master Volume while in Zone 2 control.
I'm not sure if the auto setup function (with the included microphone) will work properly with this setup. And, of course, this is not a "suggested" setup by Pioneer, so please use caution when hooking everything up.
Apr 21, 2009 | Audio Players & Recorders
SPEAKER CONNECTION
problem with connection
Jan 07, 2008 | Audio Players & Recorders
Connecting a sub-woofer to Pioneer VSX-453 surround reciever
I got the same issue. But, I go ahead hooked it up two banana plugs on teh VCR outlet. It works fine on my Cerwin Vega Sub.
Nov 08, 2007 | Pioneer VSX-453 Receiver
178 people viewed this question
 Grubhead
Grubhead
