Question about Car Audio & Video
I have a zeus 26000 2x300 watt amplifier. yesterday, the twelve inch subs that the amp supports are not working. The amplifier power light is not lit and the protect light is. There is power going from the battery to the amplifier, and and the ground wires and the rest of the wires are intact and in place. What could be my problem, and is this a common problem with this amplifier.
Try and get a new one probaply has a shortage in it
Posted on Nov 25, 2008
Planet Audio PX1500M Amplifier Problem
Check the FUSE to ensure that current is not cut off.
Jul 16, 2013 | Planet Audio PX1500M - 1500W MOSFET...
2 12" subs + 600W amp. Turn on, goes boom once, then red light
Is your gain all the way up? If it done this before, sounds like your over working the amp. Make sure your subs ohm load is capable with the amp load to. If they are 1 ohm and your amp is only 2 ohm stable, it would beat for a lil bit then go into protection mode to. Check your wires too.
May 13, 2010 | Insignia 600W Bridgeable Amplifier with...
Hello. My Kicker kx200.4 is acting funny. The red display light on front/top of the amp is turning on for a second and then turning off, repeatedly. The light on the side (power) is also turning on, red...
the amp is a 200 Watt by 4 im guessing and its doing that because its going into protection mode unhook the subs if it stops then 1 you have a bad sub or 2 the subs are too much for the amp if an amp is rated 200w per chanel its 200 max about 75 rms or 75 normal constant power
Feb 05, 2010 | Kicker KX200.4 Car Audio Amplifier
I have a twelve hundred watt sony explod amp and a couple twelve inch subs i killed a deer awhile back and put it in the back of my suv every since then my amp will power on light up everything it should...
Does the amp power up? Did you knock the fuse loose with a deer hoof? Sorry couldn't resist that. Check all of your wiring with an ohm meter especially your speaker cables. Check for DV voltage at the power input to the amp and also the remote turn on. If you get voltage there try turning the amp on and measuring the AC output voltage of your amp from plus to minus. (crank the volume up) That will also tell you if your amp is functioning. Verify signal to the amp. If you have a portable stereo with aux inputs drag it out to your car and plug your RCA into it. If you get sound to your portable stereo you have signal. You can't reliably measure the AC voltage with a meter because it is so low, if you had a scope that would work. Test your subs on your home stereo, (verify impedance first). These are just some ways to divide and conquer good luck man!
Dec 21, 2009 | Sony XM-2150GSX Car Audio Amplifier
I have two zeus 1000 watts amps four rockford fosgate phase 2 15 inch woofers why my protect light keep coming on when i turn up my radio up
The power draw may be eccessive, try placing a capacitor (or a bigger one ) on the lines to the amps.
Message for the expert bobdunhay: You are not allowed to share your address.
Thanks.
Sep 10, 2009 | Hifonics Zeus Z1000D Car Audio Amplifier
I have 3 hifonics zeus Size: 12 inch Impedance: Single 4 Ohms Peak Power Handling: 800 watts RMS Power Handling: 400 watts Sensitivity: 89.9 dB Aluminum Cast Basket American Spider For Reliable Performance...
Hello king3132,
Three 4 ohm subs can be wired parallel for a 1.34 ohm final load or series for a 12 ohm load. If you have the channels of the amp bridged, I hope that the subs are connected in series because the Sony XM-2200GTX is NOT rated for or stable at 1.34 ohms. It's only stable down to 4 ohms.
You definitely will not get the maximum potential of the subs from that amp. They can handle 400 watts RMS each (total 1,200 watts) and the amp is only capable of 500 watts RMS into 4 ohms (less at higher impedance), so each sub could only be getting a maximum of 166.6 watts RMS.
Hope this helps.
Jul 20, 2009 | Digital Audio Car Audio & Video
Make the sub pop and hum and no rca wire are hooked in?
first off nice choice on the amp check ur power and ground connections make sure the main battery to bady ground is good if questionable add a new one cant hurt to have extra grounds from the batt to the body make sure the amp ground is as short as u can make it make sure its grounded to bare metal if any of these dont work u may have a prob inside ur amp
May 06, 2009 | Hifonics XX-Zeus Car Audio Amplifier
Amplifier Problem
never ask geeksquad about amps lol check your ground wire connection and push on sub do you feel scratching if so its blown sub also never turn an amp up all the way it starts pushin dc voltage witch a 200 watt amp can blow a 800 watt sub dc voltage is not good for subs also up all the way can burn out the internal battery in the amp lets hope thats not it just make sure ground is good protection light means that the amp has power but a connection is not bien made sum where to complete the circut
Apr 12, 2009 | AudioBahn DUB Mag Audio DUB1002 Car Audio...
Ma audio hk 4000d
you have definately blown a output channel, or power supply. Send it in for warranty.
Jan 09, 2009 | MA Audio HK4000D Car Audio Amplifier
Subwoofers
This will depend on the amplifiers capabilities.
I will give 2 different scenarios.
#1 Stereo configuration
If the amplifier supports an RMS power output close to the RMS input power of the subwoofers then run the amplifier in stereo mode. For example 150 watts RMS X 4 channels driven at 20-20khz. (If you can provide a model # for the subs and the amp your looking at I can help you further with this decision.
Wiring for this is easy and simply involves matching the connectors for 2 of the channels (Front or Rear) to each of the subwoofers.
#2 Mono Bridged mode.
If the amplifier is lower power but mono bridgable you can bridge two Pairs of channels and power each of the subwoofers this way.
Generally speaking a 2 channel bridgable amplifier will be able to at least combine the wattage of each channel into a single monural channel and in many cases its actually higher.
So you would bridge the front 2 channels into a single bridged mode for one subwoofer. and then you could bridge the read 2 channels into another bridged mono channel for your other sub woofer.
For example if you had bridgable amplifier thats 50 watts RMS X 4 you coudl very likely (Generalization based on quality of amplifier) send 150 watts RMS to each subwoofer.
Again I would need to know what amp you're refering to to provide specific wiring instructions. Many Bridging amplifiers either have a single switch that will send them to bridged mode or you would use the positive + terminal from one channel and the negative - terminal from the other channel or a combination of both.
Sep 17, 2008 | Kenwood 12" 4-Ohm Single-Voice-Coil...
Car Audio & Video Logo
50 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
