Question about Viking VMOR205SS Microwave Oven
Will not heat on one touch mode but will heat on convection made
If you just in insert food , add time on the display and push start the food will not heat. If you do as the service call check suggests and add five minutes on convection cook mode the plastic turntable is warm.
  • mrlandscape Nov 25, 2008
    Can I order a magnetron which I was qouted from viking as being under $100.00 and replace it myself. I can get around mechanical things pretty well
  • 446 Answers
Your microwave magnetron part is probably broken you need to send this to a shop im afraid, might cost you 40- 60 $
Posted on Nov 25, 2008
  • ariel santos
    ariel santos Nov 25, 2008
    yes its not  that difficult goodluck
My kitchenaid microwave will not heat in microwave mode. In fact the turntable starts and stops and the display blinks intermittenly. In convection oven mode everything works fine - It heats, turntabl
The magnetron is the main part that gives out microwaves to heat the food. As the convection bit is working this points towards the microwave bits.
The magnetron has a main diode, fuse and transformer to run the microwave bit, any of these could be faulty. A word of warning though, there are extremely high voltages inside microwaves, even when unplugged in the main capacitor. Also to repair this section you will need to be a fully qualified engineer to even order parts for this.
Find a microwave technician who can repair for you
Nov 04, 2014 | Microwave Ovens
Difference between a convection oven and a conventional oven
<span>A convection oven is equipped with a fan to speed the circulation of heat around the food, thus cooking it faster and more evenly than conventional ovens. <br /><br />Conventional ovens rely on radiant heat that rises from the bottom up to the top of the oven. Convection ovens cook foods approximately 25% faster than conventional ovens, and the oven temperature can be reduced by 25&deg;F for most foods. <br /><br />No special cookware is required. Just like conventional ovens, convection ovens can be gas- or electrically-heated. As with any major appliance, it is always best to carefully read the manufacturer's guidelines and instructions for operating the oven.</span>
on Apr 04, 2011 | Microwave Ovens
On our new microwave there is 2 buttons for defrost. what is the difference? it does not mention defrost in the booklet we got with the unit.the mdl.# is GMH5205XVB
Using the Auto Defrost feature on my microwave oven
How do I use the Auto Defrost feature on my microwave oven?
To use the Auto Defrost feature on your microwave oven, please do the following:
  1. Unwrap food, place on the turntable, and close the door.
  2. Touch Defrost.
  3. Select food by entering 1 for Meat, 2 for Poultry or 3 for Fish, or touch Defrost repeatedly to scroll through the food selections.
  4. Enter the weight in pounds:
    Meats and Poultry can be set from 0.2 to 6.6 lb (90 g to 3 kg).
    Fish can be set from 0.2 to 4.4 lb (90 g to 2 kg).
    Doneness may be adjusted at this time by touching Cook Time.
  5. Touch Start. The display will count down the defrost time. When the cycle ends, "End" will appear in the display, and the end-of-cycle tones will sound, followed by reminder tones.
  6. Touch Cancel Off or open the door to clear the display and/or stop reminder tones.
The Defrost system has 3 categories: Meat, Poultry and Fish. It should not be used for food left outside the freezer more than 20 minutes and frozen ready-made food. Use the following chart as a guide.
Here is your owners manual:
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 05, 2011 | Whirlpool Microwave Ovens
My ge profile advantium microwave and convection oven started heating by it self. we were home and smelled smoke. it had melted the food cover to the glass turntable plate. We unplugged it and later...
That I can't answer! But I would replace your microwave/convection oven, it is completely unsafe and a major fire hazard, and I would get in touch with GE and lodge a formal complaint about their product, if there is a flaw in the design it needs to be brought to the table to warn others that have same item so they are not affected in the same way.
Feb 19, 2011 | GE Advantium 120 Convection/Microwave Oven
Small amount of white smoke coming out of kenmore convection microwave in oven mode
That is usually caused by a build up of fat from microwave cooking on the heating element. It will clear under normal conditions and return if one cooks foods like bacon etc, un covered to prevent splashing of the food that is being cooked.
Hope that helps.
Oct 31, 2010 | Kenmore 63793 Convection / Microwave Oven
I inherited a 1986 J.C. Penney Microwave and can't figure out how to program most of the features. I need an operating manual or a gnome.
The clock must be set before you can use the microwave. When you plug it in, it should read all zeros. Enter the time, and press "Clock Set." Time is in 12-hour format. There is no daylight saving time.
For basic microwave use:
1. Press "Power."
2. Press the keypad corresponding to the desired amount of power, e.g., "High," or "Defrost." (The numbers on the keypad have little words on them, like "Warm," "Med," and "High".)
3. Press "Time."
4. Enter the desired cooking time, e.g., "1-0-0" will be 1 minute; you could also do "6-0" for 60 seconds. You can do as little as 1 second, up to 99 hours 59 minutes. "1-0-0-0" would be 10 minutes. "2-0-1-2" would be 20 minutes 12 seconds.
5. Press "Start."
NEVER operate the microwave when it is empty. Put at least a glass of water in it. Never put a glass in it empty; make sure the glass has something in it, like water. Be careful when taking out a glass of water that's been heated; the water has been known, in rare instances, to "explode" and severely scald people.
It is okay to use the approved metal rack (it's coated with ceramic to prevent arcing) when using the microwave in microwave mode. Of course, the metal rack is also fine for use in the convection/combination mode.
"Defrost" cycles between microwave and nothing, microwave and nothing, microwave and nothing. You can hear the cycles. If defrost takes too long, try "Low." Try to avoid using "High," as it kills most nutrients in the food. Opt for "Medium" for slightly longer time; it'll be more evenly heated and healthier. Some things, like popcorn, require "high" power.
To stop the microwave in the middle of cooking, simply open the door. (There's no such thing as microwaves escaping the oven and bouncing around the kitchen and zapping you. I have a microwave tester, and the moment you open the door, all microwaves dissipate; the reading at the door is "Zero" once it's opened.) Or, press "Cancel." If you open the door, you may test the food, and if it needs further cooking, you may close the door and press "Start," and it will resume where it left off. If you're all done, just press "Cancel."
There is no way to disable the 5 beeps at the end of the cycle. If the baby is sleeping and you don't want to hear the beeps, simply open the door right before the beeps when the countdown is at zero. Pressing "Cancel" will give you one beep.
If you have the Combination feature, that cycles between microwave and convection heat, giving the best of both worlds (cooking inside with microwaves and outside with convection), for things such as a whole meats.
To use Combination:
1. Press "Combination."
2. Consult the chart on the microwave (below the keypad) and choose a number from 1 to 4, depending on what type of food you're preparing (i.e., lamb, pork, etc.).
3. Press "Time."
4. Enter the desired time, using the method described above.
5. Press "Start."
The Convection feature simply blows hot air across the food, at the temperature and duration that you set. It's a great way to toast slices of bread for the whole family at once, or bake a pizza.
To use the Convection feature:
1. Press "Convection."
2. Choose the temperature (the degrees are printed on the keypad, such as "350 degrees."
3. Press "Time."
4. Enter the length of cook time, using the method described above.
5. Press "Start."
Be sure to cover foods (with a paper towel or suitable plastic cover) that are prone to splattering. Don't let foods explode and get up into the motor. Clean the inside regularly with a soft sponge and mild detergent, NOT harsh or abrasive chemicals like Comet. Then rinse the soap off with a clean sponge.
Be sure to close the door firmly before cooking, but don't slam it. Slamming it will wear out the latching part, but being too gentle in closing the door may cause the safety switch to not engage, and the microwave won't work (it'll count down and the light will turn on but the motor won't run).
Note: the Convection feature uses more wattage than the microwave counterpart. The volts and amps are listed in the door jamb; multiply them together and you get total watts (although the actual amount will vary depending on your "power" settings).
Aug 07, 2010 | Microwave Ovens
Sharp carousel convection/grill/microwave maybe R990
Hello :
This happens because of a bad door switch . The plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door .
Check also the turntable . It could be out of it's right place .
1:Don't slam your microwave door because this may cause the fuse to blow and this is the reason of bad door switch problem .
2: A microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
Jun 03, 2010 | Panasonic NN-S254BF Microwave Oven
GE Profile Performance Convection/Microwave Problem Heating
Either magnetron, capacitor, diode pack or transformer has failed causing a fuse to blow.
Jul 13, 2017 | General Electric Microwave Oven
Convection oven problem
Most of the time the magnetron is defective if the food is not heating up.
In some cases there is a defective low power transformer or other componenents associated with the magnetron.
I would suggest to check the owners manual under the warranty section. Sometimes the magnetron has 5 years warranty.
Good Luck.
Feb 15, 2008 | GE JVM1490 Convection/Microwave Oven
Viking VMOR205SS Microwave Oven Logo
530 people viewed this question
Top Viking Microwave Ovens Experts
William Miller
William Miller
Colin Stickland
Colin Stickland
Craig Butler
Craig Butler
Are you a Viking Microwave Oven Expert? Answer questions, earn points and help others
