Question about Kenmore 24902 Top Load Washer
Need to replace belt on agitator
Already have the belt but don't know whether to go from top or bottom to install
  • Kenmore Master
  • 5,568 Answers
Actually, neither, if it is like most top-loaders, you will need to remove the rear sheet metal panel. To do this is pretty easy; there may be 6-8 screws around the edges and possibly a couple more somewhere in the middle that tie the back panel to an internal brace to prevent rattling of the sheet metal. Some machines may have the hose attachment point (actually the input to a temperature adjusting divertor valve) that goes through the sheet metal making it necessary to remove the water supply hoses. The sides and front are normally joined from the inside and the top may be attched inside as well. The whole housing, with the exception of the back panel, is dropped as a unit over the innards of the machine.
Posted on Nov 25, 2008
    Genius:
  • 2,920 Answers
Through the bottom
    Sergeant:
    Champion:
  • 291 Answers
Go in from bottom to replace a belt.
The agitatae doesn't seem to be cycling the
The agitator is made in two parts. Upper and lower. The bottom part does the actual agitating.
The upper part is supposed to be loosely fitted. It just screws down the clothes to contact
the bottom agitator slowly.
The top part turns one way, and slips the other way. By the action of what is called "Dogs" inside
the top part. These dogs are probably worn and need to be replaced
Take the top off the agitator and there is one bolt in the middle of the agitator. use a long extension
to reach the bolt and remove it.
Pull off top agitator (keep it straight up so you don't lose the dogs_
Go to local Appliance store and ask for Agitator Dogs.
Replace Dogs exactly as they came out
When you re-assemble the top it will be loose. This is normal.
Good Luck!
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 24, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore washing machine agitates slow.
Hello & Welcome to FixYa
I don't think it has to do with any sort of belt instead it seems that something is stuck under agitator or the agitator needs replacement. You can view this video if you want to replace it yourself:
Please get back to me if you have any other questions.
Kevin
Jun 21, 2011 | Washing Machines
My daughters GE same model washer will not agitate. Stop agitating after just a few months after being purchased. I believe this is a trait from this type of washer. Perhaps GE needs to recall them all...
Premature failure usually is a reuslt of overloading and/or not enough water. So, there is a rubber drive component that fails and some models have agitator pawls, or dogs that fail. Both are fairly easy to change, and not pricey, except for labor..
Feb 07, 2011 | GE WBSR3140DW Top Load Washer
The washer runs through the cycle, but does not fully agitate.
if no visible adjustment nut, then you need to replace new belt may be it already wornout and not capable pulling.
Mar 31, 2010 | Maytag Atlantis MAV5000
The agitator does not rotate in any way. I do not know how to remove the agitator to determine if there is a problem with a belt or anything like that.
Remove the knurled knob on top of agitator and undo the nut this releases the agitator from the shaft. However you don;t gain much by doing this, firstly check these options....
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley. Transmission The transmission could have either of these problems: Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all. The transmission may have a worn or broken gear, or some other internal problem. If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair
Please rate my help++++Thanks for using FIXYA
Nov 28, 2009 | Cameras
Top part of agitator appears to becoming disconnected from bottom part. bottom is attached to motor and is working.
Hello Friend, Your problem is easily solved. You need to replace the agitator dogs. To replace all you have to do is pop the top cover off of agitator and remove bolt. Pull up on agitator and remove from washer. Next remove upper agitator from lower agitator. Inside the upper agitator top piece you will see a mechanism that has 4 little ratcheting teeth, these are called agitator dogs. Just replace them with new ones and re-install agitator. This should solve your problem. Happy to help, Tim.
Jun 25, 2009 | Washing Machines
Agitator spins in one direction
The purpose of the upper portion of the agitator is to push the clothes in a downward motion. As the agitator moves the dogs grab and on the backward srtroke the top portion rotates a quarter turn. In the spin mose the agitator only goes in one direction or your clothes would be torn to shreads.As the washer rotates back and forth, the dogs grab the inner walls of the upper agitator and that forces the clothes into a downward movement to the bottom of the tub. These dogs will wear out. To test whether or not these are bad just grab the agitator while in wash mode. The dogs should advance the top portion easily. If not then they are worn out. To replace them you must remove the agitator and sit it on the floor. Hold the base down with your feet and yank the top upwards. After seperating the 2 pieces you simply install the new dogs and line up the bottom with the top being careful not to break the little tabs on the bottom agitator that hold the top in place.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 22, 2008 | Kenmore 22422 Top Load Washer
Top Agitator is not moving
This washer has a set of cheap plastic dogs that grab the inside wall of the upper agitator to move the clothes downward and help them get a better cleaning. The older style These dogs will wear out. To test whether or not these are bad just grab the agitator while in wash mode. The dogs should advance the top portion easily. If not then they are worn out. To replace them you must remove the agitator and sit it on the floor. Hold the base down with your feet and yank the top upwards. After seperating the 2 pieces you simply install the new dogs and line up the bottom with the top being careful not to break the little tabs on the bottom agitator that hold the top in place. The newer style you simply pop the cover of the agitator and use a 3/4 drive extention to unscrew the upper agitator. replace the dogs and put the top back on. Nothing could be easier.
Jul 30, 2008 | Estate TAWS800JQ Top Load Washer
Kenmore 24902 Top Load Washer Logo
47 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
