Question about GE Spacemaker JVM1640SJ Microwave Oven
EVERY THING WORKS, BUT IT HAS NO HEAT. IT FELT VERY WARM BEFORE IT QUIT
I have a similar model. Mine is a GE Profile built in 1995. The model is J VM 260WV 001. I have read some of the tips for repair, so I removed the key pad panel ( 1 screw ) and found that my unit has 3 switches in the door that all appear the same. The top one is used to work the light. The middle one I am not sure of however it has the heavy wiring. The bottom one works the fan. I figure that the middle one would be my problem. So, I unhooked the wires and plugged them into the switch for the light. What happened was the fan came on as did the oven, I still however did not get any heat. I saw a fuse with 2 terminals, I unplugged it and the oven light went out. Any ideas? It is old and may just need to be tossed, I just do not have to change the entire unit. Thanks for the help. Rod
  • rod gunsell Jan 05, 2007
    I read the text listed @ doorsw.txt and all of
    my switchs seem to fuction properly.
  • GE Master
  • 9,150 Answers
The top switch is not just for the light and the bottom one is not just for the fan. It is not safe to swap wires around. It's a wonder you didn't blow the fuse. All GEs come with an envelope inside that contains a wiring diagram. If the fuse is blown, the entire unit would be dead. If all the switches audibly click, they may be okay, but you also need to check for signs of melting or arcing on the terminals. If the switches are okay then the most liekly possibilites are the magnetron or a loose connection on the magnetron. I will not advise you to work in that area of the microwave. The voltages inside the microwave can be instantly lethal.
Posted on Jan 05, 2007
My Kenmore elite built in microwave oven model 790 488 03100 has stoppped heating what can i do
It may be a bad fuse or capicitor. I have had a time in the past with something similar. I contacted Repair Clinic.com. They were very helpful with their advice and even followed up to make sure I got things fixed okay.
Dec 09, 2014 | Kenmore Microwave Ovens
My GE Profile JVM3670SK02 microwave stopped heating. Can it be fixed?
Anything can be fixed, it all depends on how much it will cost to repair. Sometimes it just pays to buy another microwave oven they have come down in price quite a bit
Good luck
Feb 27, 2014 | GE Microwave Ovens
May Spacemaker XL1800 stop heating food. Was working fine. Then just stop
Is this an over the stove type unit? I have had a few problems with my over the range spacesaver. I think the heat from cooking gets up into the microwave and damages it. The steam from me boiling things on the stove had mine quit heating and I purchased a new one. The parts to replace the faulty ones can be quite expensive over $150.00, so its better to purchase a new microwave.
Feb 24, 2013 | GE Microwave Ovens
My GE Profile Jvm1870sk03 microwave built oven does not work. There is power, the clock, timer works. If I press the button to heat the clock shows it's going on but there is no heating process go
Most likely door switches. Companies these days use switches with small 3/16 terminals and they tend to get hot and make the switch go bad. When I replace them I put in a 20 amp rated switch with 1/4 inch terminals, and a short section of better wire to the switch. If you make better connections it stops the wires from getting hot and the switch will last a long time.
Aug 24, 2017 | GE Microwave Ovens
GE Profile XL 1800 Microwave overheating?
ge spacemaker XL1800 (JVM 1870BF02) doesn't heat, lights, turntable works.
Mar 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
MY microwave just stopped heating things
therrmal resistor bad . Mine quite working and I found one of two resistors bad. Seemes to be a common problem.
Feb 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No more heating, GE Profile Microwave JVM 1870CF02
I think its the mag tube, mine went out the same way. GE will provide the mag tube for free just call them...have a local ge certified tech out to put it in.
Aug 31, 2008 | GE JVM1850 1000 Watts Microwave Oven
Turntable repair? GE Profile model JVM1660BB
IF EVERYTHING IN THE OVEN IS WORKING BUT THE TURNTABLE YOU HAVE TO TAKE THE BOTTOM COVER OFF THE OVEN THE MOTOR HAS TWO WIRES ON IT, BE CAREFULL
WHEN YOU TEST IT AS THERE IS 110V ON THE WIRES.IF THE 110V IS THERE BUT THE MOTOR ISN,T RUNNING TAKE THE
TWO WIRES OFF,AND TAKE THE MOTOR OUT AND BUY A NEW ONE. YOU CAN DO THIS BUT DO BE CAREFULL.. YOU
MAY HAVE TO PULL ON IT A LITTLE TO PULL IT APART FROM THE PEACE INSIDE THAT TURNS THE GLASS TRY NOT TO BREAK IT!
Jan 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
272 people viewed this question
Top GE Microwave Ovens Experts
vince
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
