Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Kenmore refrigerator model 596.75932400
It runs but dont get cold
SOURCE: Kenmor frig not getting cold
same problem then suddenly would not shut off, kept running. found out it was the thermo couple as well as the timer.
Posted on Aug 12, 2008
  • 306 Answers
SOURCE: Kenmore side by side refrigerator is not cooling or freezing
Sure sounds like a PTC relay bad. Take the relay off and shake it to see if you can hear a rattling sound.
The clicking sound is a relay called PTC relay. You need to replace it. First be sure to unplug frig. Remove the cardboard cover that covers most backs of the frig units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
Posted on Feb 04, 2009
rpbuice
  • 161 Answers
SOURCE: Kenmore Coldspot Side by Side Model 51559101
Unplug the Ref for 15-20 min., plug it back in and listen for the compressor to start. You will need to be behind the Ref so you can tell if the compressor or the fan is running. It will help to take the cover off so you can see the compressor.
Compressor not running but you hear a clicking noise. The relay needs to be replaced.
Compressor runs but not cooling. Low on coolant
Posted on Feb 11, 2009
kram26
  • 544 Answers
SOURCE: My Kenmore fridge, Model 596-58692890
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Posted on Mar 24, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Compressor stop running on Kenmore
Hi and welcome to FixYa. I am Kelly
Is the compressor HOT to the touch? If so unplug the unit for at least 30 minutes and plug it back in.
If the compresor is cold then it may be stuck in the auto defrosting mode. When this happens usually either the 60 Deg F Bi-metal thermosat or a thermistor has failed. Items 30 and 31 this link: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Refrigerator-Parts/Model-59675523400/0583/0161000/M0705003/00010?blt=06&prst=&shdMod=
(Evaporator
If that checks out then we start replacing the PTC relay and thermal overload on the compressor IF there is power to the compressor. Otherwise we start looking at temp controllers and themal fuses.
Items 10 and 11 this link:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Refrigerator-Parts/Model-59675523400/0583/0161000/M0705003/00011?blt=06&prst=&shdMod=
You make have to access the links above via this page http://www.searspartsdirect.com
Then enter your model number as 596.75523400 under find it fast / model search.
The other possibility is the electronic control item 5 under "controls":
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Refrigerator-Parts/Model-59675523400/0583/0161000/M0705003/00006?blt=06&prst=&shdMod=
The only way to find out is to read out the circuits with a meter.
Thanks for choosing FixYa
Kelly
Posted on Oct 08, 2010
We have a Kenmore Bottom Mount Refrigerator. The freezer cold but the refrigerator part is warm. Model Number is 596.6998. How do we fix it. We have removed the grille and vacummed it.
Is the fan that blows cold air from freezer to refrigerator running? And is the mechanism that controls the doorway allowing air into refrigerator working properly?
Jan 11, 2017 | Kenmore Refrigerators
Kenmore 10653703202
dont have the solution but the same problem....i would also like to know how to test these parts, i already changed the thermostat, that wasnt it... the model number is 10653703202
Aug 03, 2012 | Kenmore 53642 / 53644 Side by Side...
Kenmore refrigerator-model#106.74254400 freezer is working fine, refrig. will not get cold. Any ideas?
the damper vent door between the 2 compartments is not opening to let cold air in from freezer to refrige,also make sure fan is also running to push cold air through this door,a lot of times its either frozen shut from moisture or the door shaft breaks and it jams shut or the damper door motor goes bad,its a 106.xxxxxxxx model so whirlpool produced it for kenmore
Apr 11, 2011 | Kenmore Refrigerators
I have a side by side kenmore coldspot model 52259100. The Refrigerator is not cold but the freeze is cold. Help!
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 28, 2010 | Kenmore Refrigerators
Mar 16, 2008 | Kenmore 60721 Refrigerator
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
53 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
