Having prob connecting my laptop to a TV via hdmi
Hi, I tried to connect my gateway laptop to the LCD tv using a hdmi cable. The tv didn't response so I restarted the computer and the tv actually showed the same starting screen, but when the vista window kicked in the TV turned blue again and showing "not supporting". The TV is 1080i max. Vista is 32bit.
  • 1 more comment
  • zachschaff Nov 26, 2008
    I have 4 HDMI ports on my tv. I had no problems connecting my laptop to any of them when i frist bought it, now not one of them work. When the first stopped working, i went to the 2nd, when that one stopped i went to the third, and then to the fourth. I have now now run out of HDMI ports and have tried each port with my home theater and had no problems. i have also tried brand new cords. nothing is working any more. My TV shows that it is connected just not getting any signal. My computer makes a little noise everytime i connect it, but will not show that it is connected. Looking for some help solving this problem please.
  • mya76 Jan 01, 2009
    I am trying to connect to Toshiba HDMI (3 ports), but everytime I tried, my laptop will show restart screen. My HDMI packaging shows HDMI male to HDMI male. Is it the cable issue?
  • xlXDEEZXlx Mar 07, 2009
    iv connected my hp pavillion to my pioneer plasma tv using an hdmi cable but i don't know how to select the tv to view the hdmi connection.
    Problem Solver:
  • 11 Answers
Try playing around a bit with the display settings, there are not many laptops that are setup to automatically adjust to the dual screen setup with an lcd tv. Also, iv found that Not using the lcd as a duplicate of the main screen is a good idea, set it up as a separate screen...if you know what i mean, if you do it right you will see only yourbackground on the tv and no start menu bar or icons.... In this configuration you can set the resolution to the max for the best quality possible for your television.
Posted on Nov 26, 2008
Cannot get the hdmi to work
My Tv won't recognize my computer when connected via HDMI [Solved ...
www.tomsguide.com/.../57797-4-recognize-computer-connected-hdmi
4 days ago - 43 posts - ‎36 authors
I too was able to get the HDMI output to work and then later on stop working. ... I'm also experiencing this issue, but still can't make the TV ... Audio over TV problem using HDMI cable
Jun 30, 2015
When I connect my Laptop to my TV thru HDMI cable I ...
Feb 22, 2015
No picture on LCD TV with HDMI cable plugged into ...
Aug 4, 2014
My TV doesn't accept PC HDMI [Solved]
Dec 7, 2012
More results from www.tomsguide.com
TV won't recognize laptop when connected via HDMI ...
Dec 26, 2015 | Televison & Video
Connecting my laptop to my sansui 42" lcd tv via the hdmi cable, i get clear picture but no sound
Does your laptop feed sound through the HDMI connection? You may have to use the HDMI 1 jack on the HDLCD3200. Change the HDMI setting in the audio menu on the tv to DVI and run a seperate audio cord from the laptop to tv. I hope this is helpful
May 17, 2011 | Sansui HDLCD3200 TV
Hi, I have bought LG LCD ld310 . Can I connect my computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable Thanks Jatinder Kumar
Hi Jatinder Kumar ,
Yes you can connect your computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable.
1. Connect to HDMI (DVI) : just plug in HDMI (DVI) out of PC or laptop to HDMI or DVI TV. Than select source from HDMI.
2. Connect to PC : Plug D sub to TV, select PC in.
I hope that will help you.
thanks.
Mar 21, 2011 | LG Televison & Video
How to connect/configure my acer aspire 4736Z to my LCD TV using the HDMI port/cable of my laptop? i tried to connect the HDMI cable but my laptop hangs...please help
for HDMI, I guess you just connect it with HDMI cable to your LCD TV, and use the FN+F5 or F6 to switch display from laptop's LCD to external. I think it should be the same way as using projector.
Sep 30, 2010 | Acer Computers & Internet
I have a Samsung Series 6-650 LCD TV (Model # LN46A650A1F). I am trying to connect my Laptop to use the TV as a monitor and have done everything to make it work, using a VGA/HDMI cable, but the TV refuses...
Why do you use VGA-HDMI cable? This TV works fine with VGA cable - it has VGA plug.
Or if your notebook has DVI output, then you can use DVI/HDMI cable and connect it to the TV to plug named DVI/HDMI (only one HDMI input is marked as DVI on TV).
I suppose that over HDMI the TV supports only some standard resolutions, but over VGA it supports almost every resolution laptops use. You can find supported resolutions for each input in the TV manual. Try setting the same resolution on the laptop.
Feb 28, 2010 | Samsung LN46A650 46 in. LCD HDTV
Gateway notebook goes BLACK when connecting new lcd tv to laptop
try setting the frequency down to 60hz and the resolution before you connect. then if it works you can set it up again with a setting the TV likes
Jan 08, 2010 | Gateway MT3705 Notebook
My LG TV and PS3 don't get along anymore!
Tries change all new HDMI cables,same prob.Tries RCA cable.
Nov 23, 2009 | LG 37LC7D 37 in. LCD HDTV
No image on hdtv
First off, is the tv set to use the hdmi input? if not, change tv to hdmi input and try again. If still no good, you likely need to tell the laptop to use the hdmi connector. Try this:
  1. connect hdmi from laptop to tv and select hdmi input on tv.
  1. while holding the blue fn key (bottom left side of kbd) press and release the F5 key. This will toggle the laptop between the laptop lcd display, external connectors (vga/hdmi), or both simultaneously. Let me know if this works or not.....
Aug 08, 2009 | Acer Aspire 6930-6455 Notebook PC
Connect lcd LE10 32'' model to laptop
connect them via HDMI. Audio and video from your laptop will go the TV. You need an HDMI cable for that connection.
cheers!
Jul 11, 2009 | Panasonic Viera TC-32LZ800 32 in. LCD HDTV
Computers & Internet Logo
2,715 people viewed this question
David Payne
David Payne
