Question about Amana ACF4265 Electric Kitchen Range
AMANA ACF4265A not holding temperature
I have an AMANA ACF4265AB electric oven/range. Bake element failed, while replacing it I accidentally caused a surge (forgot to unplug). I have replaced the element, the high-temp limit switch, and the temp probe. The oven will reach the set temperature but then will drop out, also I'm not sure the bottom element is working properly. Any suggestions, need to save Thanksgiving having 25 people over!!
2 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: amana over
as far as the elementy working, if it glows red, its working. if the unit is preheating within 12-15 min, id say the elements are fine. as far as not maintaining temp, thats strange, if the elemnt turns on the control is sendinding power, and its shuttin off so its stopping power, sounds as if a relay is geting stuck on the control board, strange thngs happen when you short things out like that.
Posted on Nov 26, 2008
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
Amana oven will not hold temperature
First check the temperature probe if that checks out good the problem is the bake element is failing. Here is a couple links on checking and replacing these parts
http://appliancehelponline.com/oventempprobe.html
http://appliancehelponline.com/ovenelementvideo.html
Jun 28, 2010 | Amana AER5712AAS Electric Kitchen Range
When set to bake oven does not preheat and tempature does not increase. when set to broil oven heats
Since your oven has a separate element for bake and broil I would bet the bake element is burnt out or burnt electrical connection to the element. Make sure you disconnect all power to the range before checking.
Mar 21, 2010 | Amana AER5844VAD / AER5844VAB / AER5844VAW...
Oven not baking
1. Check that the bake/broil elements are ok. Do they glow red when cycled on?
2. Control board may have failed. We see this as a common failure. We repair control boards at www.fixyourboard.com
Oct 08, 2009 | Amana AER5515QA Electric Kitchen Range
Amana Range, AER5515QAW
could be a bad bake element, bad temperature sensor, or control board problem
what does the oven readout display for temperature? if the readout agrees with the actual oven temperature ... it is probably the element
if the oven readout displays a much higher temperature it may be the temperature sensor (the probe in the oven cavity) or the control board
the temperature sensor can be tested by measuring its resistance with power off and unplugged from the control board, should be about 1100 ohms at 75F
If the sensor is good, then it is probably the control board ... in which case we can repair it for you at www.fixyourboard.com
Jul 20, 2009 | Amana AER5515QA Electric Kitchen Range
Amana over
Nov 25, 2008 | Amana ACF4265 Electric Kitchen Range
Bottom element on range doesn't work
we can check a few things, first off you need to confirm 220v. to unit itself, ill assume you do, the top elements are working correctly.. sounds like a bad electronic control, what youll need to check is on the control itself, there is a wire labeled L1, then there will be a bake terminal, ill also assume L1 has 110v, other\wise the clock wouldnt be liting up, but if you carefully unplug the bake terminal and test terminal for power( it will have 110v, after you select bake andstart oven.
Nov 17, 2008 | Amana AER5515QA Electric Kitchen Range
Range will not hold a consistent temperature
Good chance your bake element is out. Could be the element or a terminal burned off.
When you set to bake, normally it preheats which uses the bake and broil element.
When it reaches "near" temp, the broil goes off and the bake takes over.
If the bake element, (the one in the bottom), is not working, the temp will decline.
Check:
Turn to 450 deg.
Watch the elements, assuming you have a door with a glass, and see if both elements, top and bottom, glow red.
MrBoo aka Gary
Nov 11, 2008 | KitchenAid KERC507 Electric Kitchen Range
Oven will not heat past 220 degrees
Check your bake element, I had the exact same problem and found the bake element had burned in half. The broil element comes on during preheat and kicks off at around 220 degrees.
May 06, 2007 | Amana AER5515QA Electric Kitchen Range
Oven will not heat to requested temperature
Shaffy, When baking only the bake element should heat. When broiling only the broil element (upper) should heat. Your oven is a Kitchenaid, you have a 5 year warranty on any electronic element or control board. You may have a temperature sensor that is not working right. The oven just might need to be calibrated, the instructions would be in your owners manual. Your bake element might be failing, it would have to be ohmed out. You also need to verify that the bake element is getting 240V. when turned on. Catriver...post back
Sep 07, 2006 | KitchenAid KERC507 Electric Kitchen Range
Open Questions:
See all Amana ACF4265 Electric Kitchen Range Questions
Amana ACF4265 Electric Kitchen Range Logo
105 people viewed this question
Top Amana Kitchen Ranges Experts
Sal De
Ismael Rodriguez...
Oloyede Monsuru
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
