Question about Toshiba Satellite A100-S8111TD Notebook
REPLACING HEADS FROM LAPTOP HARD DRIVE
How can I get the heads for the hard drive? or the manual for instructions? I want to replace the heads in order to recover the data.
    Problem Solver:
  • 13 Answers
You will first need a 100% clean room and one of those white jumpsuits. Honestly you will definitely ruin your data if you try it yourself. Usually certified places charge 1000$ to 2000$ to do it. I know Ontrack Data Recovery is pretty reputable business if you want to get it done.
Posted on Nov 25, 2008
Dropped hard drive worked for awhile downloading photos now my laptop and pc will not identify it?
Most likely the heads are damaged...at least one of them are. When drives are dropped it's pretty common for them to damage the heads. If Head 0 is still able to read, the drive may calibrate and even be readable to a certain extent. Eventually the damaged heads can make it to where the drive is inaccessible.
Jan 20, 2013 | Western Digital My Book Essential Edition...
SMART failure predicted on Hard disk 4 Toshiba: MK2035GSS-(S1)
It means pretty well what it says.
That the hard disk is failing, and you need to back up all of your data from it and get the drive replaced.
You'll need to refer to your manufacturer or manual to check what type of hard disk it needs.
I cannot stress that this is incredibly serious however, backup your data immediately
SMART is a tool that checks for hardware errors. it will detect when there is a Higher power consumption or temperature than usual.
Those things predict a hard drive crash, however it could take months for the drive to fail
(or it could be the next minute).
since it's a hardware problem the drive is going to die on you and you will have to replace it.
Since smart is sometimes triggered by the read heads of the drive that stick to the surface of the drive during boot up (witch results in Higher temp and power rates) you could:
open the laptop
get the drive out
'gently' tap the center a few times
reinsert and check for the smart message again sometimes there is a little dirt on the heads that cause the sticking problem
but, realistically, you're drive is failing and you should back up your data and start shopping for a replacement drive.
hope this helps
Oct 08, 2012 | Toshiba Satellite A215-S4747 Laptop AC...
I have a fujitsu mhu2100at, ca06499-b11000c1. my hp laptop quit working and gave this error : PXE-E61: media test failure PXE-M0F: exiting PXE ROM. i removed the hard drive and tried hooking it up to...
The PXE error is not from your harddrive. the computer has failed to reccognise the HDD and so moved to the next bootable option being network, the PXE error is telling you that it cannot boot from network
I would only replace the board on the hard disk with another (same model) if you realy need the data on there. it is possible that the drive is failing because the heads have locked and so replacing the board will not fix, but if you have access to an identical drive its worth a try.
if you dont realy need the data, replace with another compatible drive and reinstall.
Mar 28, 2011 | Fujitsu Computers & Internet
I have a WD1600BEVS - 60RSTO 2.5 inch HDD that came with my HP Laptop. It wasnt booting and since it was old, i took it to a friend of mine who said he'd try to repair it. I already had a 250GB replacement...
Hi.
If the hard disk been opened unfortunately you lost your data. You can try to send it to a data recovery company but it will cost few thousand bucks to get your data out of the disk plates.
Opening a hard drive to check it out is 99.99% chances of fail because of dust. If you can fix what was wrong and put everything back together and plug it the head will hit the dust at 7200 RPM and it's like a plane crashing on a mountain.
Good luck anyways.
Vince
Feb 22, 2011 | Western Digital Scorpio WD1600BEVS 160 GB...
My WD external does not connect well to my laptop.
sounds like the drive heads are broken or out of line the unit you have does require a power cord its the data cord that it doesn't need , suggestion is to remove the driver heads and replace them with new ones from a matching Drive , its all you can do to save your vital files , if you are willing to replace your heads I can assist you however its not an easy task
Jan 11, 2010 | Western Digital My Book Essential Edition...
I am replacing the hard drive in my gateway 5220
Just buy a IDE cable longer than the one you have got
Jan 10, 2010 | Gateway GT5220 PC Desktop
No hard drive
the hard drive heads have failed you will need to replace the hard drive,, ebays the cheapest to be honest but only search compatable with you dell,, any make hasnt got to be Hitachi
Apr 27, 2009 | Dell Inspiron 1501 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
80 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
