Question about Tablets & eReaders
Gateway CX2610- Broken Screen swivel
I need to replace a broken screen swivel/hinge on my Gateway CX2610 Tablet. I have found a couple of sources for the part, but I need to find some instructions on how to replace it.
  • 1 more comment
  • ladylee371 Dec 21, 2008
    While looking up this information myself, I found the information below. It has to do with tightening the screws on the hinge but once it's opened it should not be hard to figure out to change the hinge if that is the problem.
    Hope this info helps us both.
    I haven't purchased the swivel hinge yet but will soon.
    SOURCE: http://mobilepcwiki.org/mpc/index.php?ti...
    Screen Wobble / Loose Hinge 1. Remove the black and silver plastic "strip" above the keyboard. (Use a small flat screwdriver to pry underneath the DEL key (on the right hand side of the keyboard) - be careful, it should require very little effort!)
    2. Pull gently upward and toward you on the plastic strip until you get it removed. Once removed, turn your screen around so the back of it is facing you. This will make removing the hinge cover much easier.
    3. Carefully pry upward on the hinge cover. If you look closely, you will notice that the back side of the hinge has a small half-circle piece of plastic. Pry this off carefully. It might require a slight amount of effort.
    4. After you have removed the half circle, turn the screen around so that the LCD is facing you. Now you will need to pry the larger half of the hinge cover off. (this is the side with the small oval window and arrow)
    5. Once removed, the cables connecting the tablet to the LCD should be visible. Carefully move these cables to the side and tighten all four of the screws holding the screen to the hinge.
    6. FINISHED! Re-assemble in reverse order.
  • lwhite1960 Jan 05, 2009
    Where did you find replacement hinges? I need one for a CX200X
  • mobile125 Jan 06, 2009
    Mine just finally gave out as well...where did you purchase your hinge from?
2 Suggested Answers
SOURCE: Broken swivel hinge on Gateway m280e laptop.
not sure about documentation - but for parts you might try dakotapcwarehouse.com - my company has found parts for a lot of its older gateway laptops there
Posted on Sep 08, 2010
Lenova x230 tablet swivel hinge repair
It is possible to replace the hinge, but it is a couple hours of tricky work. If you are not comfortable completely dismantling your computer, I would take it to a repair shop. You can usually find the hinge on ebay. Just search for "thinkpad x230 tablet swivel hinge part".
I replaced the hinge on my x61 tablet without any trouble, but I am very comfortable with repairing computers. Take lots of pictures to make sure you get it back together correctly, and keep track of where the screws go, there are a lot of them. Good luck!
Here is the repair manual for the x230:
https://download.lenovo.com/pccbbs/mobiles_pdf/x230t_x230it_hmm_en_0b48730_02.pdf
Jul 10, 2014 | Lenovo ThinkPad X61 Tablet PC
Jun 03, 2010 | Gateway M280E
I am having a problem with a broken screen on my tablet gateway notebook the screen broke can it be replaced
you can replace the glass by taking it too the nearest glass store as long as the screen still works
Dec 02, 2009 | Gateway M275 Tablet PC
Fixint the swivel hinge
The following website should help you out - if the problem is just a loose hinge.  Maybe you've already seen this webpage, but here it is again anyway.
http://www.insidemylaptop.com/tighten-loose-display-hinges-toshiba-tecra-m4-satellite-r15-tablet-pc/
Your problem may be just a couplI used the directions to take off my screen and then found out my hinge was broken.
Good Luck
Apr 30, 2009 | Toshiba Satellite R15-S822 Tablet PC
BROKEN HINGE GATEWAY LAPTOP TB120
search "gateway e-155c lcd swivel assembly" on google or any other search engine and you will find the part that you need.
You will need to do your own replacement, but that is the part that will fix your problem
Mar 28, 2009 | Tablets & eReaders
Replacement swivel hinge
www.mundocorp.com sells parts for the laptop model we have
Jan 05, 2009 | Gateway CX200X Tablet PC
Can not reinstall on my gateway cx2610 laptop tablet edition
refix your ram and harddisk then detect your hardddisk in bios.
Jan 02, 2009 | Fujitsu LIFEBOOK P1510D Tablet PC
Broken screen hinge/collar
You can purchase replacement hinges and hinge covers here: http://www.mundocorp.com/m275.html They may be a bit of work to replace. But short of replacing the hinge assembly, it doesn't sound like that is going to move.
Aug 28, 2007 | Gateway M275 Tablet PC
Tablets & eReaders Logo
791 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
