Question about Refrigerators
White Westinghouse freezer MFU14M2FW0 Dial settings from 1 to 7 .. What is the standard setting?
    Sergeant:
    Champion:
  • 291 Answers
Set the control on 4 / Larry
Posted on Nov 25, 2008
  • Red Moon Nov 03, 2010
    Thanks I wondered the same, so is the higher number colder?
Have lost manual what are the settings for a westinghouse 2 door fridge model rj5325r ?
usually they start mid range on the dial perhaps 4 then adjust as required later on
Nov 13, 2017 | Westinghouse Refrigerators
How does thetemperature dial on upright phillips freezer work
Usually 6 would be the higher (colder) setting.
Aug 14, 2014 | Refrigerators
Need mamual model FFU11FKODWO upright Freezer
temperature is set by dial #1 being the warmest and 9 being the coldest the numbers on the dial are only for reference they do not reperesent a certain temperature you will need a thermometer to figure out what number is what temp but they do recommend starting in the middle
Jul 26, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Setting tempture
Turn the temperature control in the direction furthest away from the off setting.
Nov 19, 2013 | Magic Chef Freezer. 8.8 cu. ft. Upright...
I have tried changing the settings on my westinghouse side by side fridge freezer from 3 up to another setting of 5 but it keeps defaulting to 3 and food continues to freeze ,how do I save the new setting?
I found this link to a manual at http://manuals.appliancesonline.com.au/wtm3000pbrh/wtm3000pbrh.pdf . If it was me. The first thing I would do is to unplug the refrigerator for 15 minutes and then plug it back in. I would do this to reset the control board. If you are changing the temperatures and they reset to factory setting then you might have a problem with the control board. Try unpluging it and see if that works first. Refrigerator repair can be difficult and if that does not work you may have to contact a repairman in your area to come out and diagnose it. If I can help you please contact me HERE.
Apr 19, 2013 | White-Westinghouse WRSS25V5GW Side-by-Side...
Analog white-westinghouse tv has blue screen and no sound. Connected to digital converter. screen does not change and after 5 minutes the tv shuts off
the glitches could have fried part of the tvs main chip
i have had it happen to me a few times and or it was a fuse
Aug 06, 2012 | Televison & Video
My Westinghouse RS662V fridge is not cold at all. I have turned the dial to full cold but it has made no difference. The freezer seems to be working OK. Could it be the thermostat in the fridge?
Yes you need to adjust the thermostst located inside the fridge compartment to change the temp. setting of the fridge.
Regards.
PLZ. dont forget to rate my suggestion.
Jul 19, 2011 | Frigidaire FRT18G4A Top Freezer...
My d300 has a blueish contrast in all non flash shots Can't get normal color
Here are the possible causes and the solutions for each:
Cause 1: The most common cause of the tint in the images is White Balance. It is possible that you have set the wrong White Balance. Since you are getting a blue tint, you might have set the white balance to 'Incandescent' (Tungsten) or 'Flash'. Changing the white balance to Auto. Most White Balance problems get eliminated by this. For this, press WB on the mode dial and use the command dial to change the values.
Cause 2: The unwanted casts could also be due to the in-camera processing. To check this, Select 'Set Picture Controls' from the Shooting menu. From the four options, select one that gives the minimum processing-- that is, either Neutral (which gives minimal processing) or Standard (It gives slight enhancements, but the tones will be balanced).
Cause 3: It is also possible that the White Balance of your camera has been tweaked. So if the above steps do not solve the issue, try tweaking the white balance to your liking. For this, press WB and use the sub command dial (the dial in front of the camera near the Shutter Release button). Check the result each time you change the value until you are satisfied with the result. As a guide, the ideal values of different settings are: Daylight (direct sunlight): 5200; Incandescent: 3000; Flash: 5400; Cloudy: 6000; Shade: 8000 etc...
Aug 26, 2010 | Nikon D300 Digital Camera with 18-200mm...
What is the best temperature for the bottom freezer and refrig?
Set both dials in the middle.
If you have a nearly full freezer, add 1 dial unit.
If you have a nearly full refrigerator, add 1 dial unit.
If your freezer is less than half full, step down 1 dial unit
Refrigerator should not be less than mid-point on dial (it gets open more often).
This is a good starting point, adjust in a month or so.
Sep 21, 2009 | GE Monogram ZICS360NRRH C... Bottom...
My son got into my fridge lastnight-left open, now won't cool
evaporator coils is probably frosted from condinsation.shut door set at normal setting and give some time.
Jul 26, 2009 | Frigidaire Freezer Refrigeration White...
Refrigerators Logo
376 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
