Question about Senco Air Tools & Compressors
SENCO SN-IV LB3500 Seal leaks air
This gun has a seal at the bottom of the piston which is about 2 1'' in diameter. the old seal was wax and was probably installed by heating it. the new seal is nylon. since this seal must pass over a lip that exceeds its diameter, do I heat this ''nylon'' seal or do I physically
stretch it to install it.
    President:
  • Senco Master
  • 1,388 Answers
The old seal was origionally the same as the new one, a white nylon, however over time the seal breaks down and looks like hard wax. The new seal may be installed by heating with hot air gun till plyable and gently streach over lip. While the gun is open, lube with nail gun oil. the piston should not slide down the cylinder under its own weight, if it does, replace the piston oring. Diagram available at senco.com
Posted on Nov 27, 2008
OK, second shot at this: About 65% of the time my SFN30 Senco finish nail gun only shoots a nail every OTHER pull of the trigger. All the O-Rings are good and the driver blade is perfectly straight.
There are 4 main causes usually with this tool:
1) Check the seal in the bottom of the cylinder (under the bumper) #BF0070 (#12 on the breakdown) If this seal is missing or worn the piston will not always return fully.
2) The pusher spring #GD0253 in the magazine is not moving the nails forward
2) The driver is bent or the tip is worn / chipped
3) The check valve ring #LB0077 on the cylinder is not sealing properly
Let me know if this helps Senco SFN30 15 Ga Finish Nailer Parts
Feb 26, 2017 | Senco Air Tools & Compressors
SN IV shoots nail fine but loses air out the top
Exhaust seal insite the top on top or gasket ?
Feb 14, 2014 | Senco Air Tools & Compressors
Driver blade not returning to top dead center
Several things to check. Piston ring /oring should not be too tight or too loose. Should be easy to push driver back up but not so easy that it drops back down if no nails in gun. If piston /oring ok then check for air leaking past driver seal at the nose of the gun. If there is too much gap between the driver blade and lower seal, air pressure will be lost down the nose of the gun. Finally, check if your nailer has a check band or oring check around the cylinder covering a series of pin holes (usually found on the lower part of the cylinder). This check band causes the driver to be pushed up with force. Good luck
Jan 14, 2014 | Senco Tools & Hardware - Others
My senco frame nail gun isn`t working
First get an exploded view of gun and parts list and numbers from senco.com,,take nail gun apart,,,take a good look at the rubber bumper stop to see if it is broken,,look at the driver nut to see if it is tight,,,,you can go to juldan.com once you have gotten a list of the worn parts,,,juldan sells complete o ring kits along with nearly all parts needed for your repair
Jan 18, 2013 | Senco Air Tools & Compressors
Wont shoot nail every time pin wont return all the way up
Some reasons the driver/piston assembly won't retract fully:
- damage to the o-ring (LB1003) around the piston
- cylinder (BA0165) is scored badly
- driver (EA0167) is bent, twisted or warped
- o-ring (LB1023) around bottom of cylinder (in groves & covering small holes) is stretched out or out of place.
- Seal (BC0492) at bottom of cylinder & under bumper is damaged or gone
Aug 11, 2012 | Senco 1Y0013N FP35 1 1/4 Inch To 2 1/2...
Sns 41 as soon as i connect air hose, driver goes down and air comes out exhaust
May need cylinder seal # bc0438. When this seal fits loose or is cracked, air will leak past and push piston down to bottom of the cylinder. If the seal fits snuggly and looks in good order, suspect headvalve orings and cylinder spacer orings leaking. Order oring kit and seal. Use silicone paste lube on all the orings. Look carefully at the surfaces where orings make contact and remove scratches with 300 grit sandpaper(fine scratches will allow air to leak past new orings). To make the gun work with poor fitting orings. Clean inside of gun with diesel and apply plenty of silicone paste to orings (using same orings if not cut or broken). If gun works as normal, the silicone paste is temporarly sealing the orings. It may continue to work for a while untill you get new parts. Good luck with repair.
Aug 13, 2011 | Senco SNS41 16Ga Stapler 1" 2"
Just replaced o rings and piston bumper, but gun still leaks air (out of nozzle) and wont fire at all
Air leaking thru nozzle (where nail exits ) can be caused by two issues. Air leaking past valve rubber at top of cylinder where headvalve seals when under pressure. If leaking at valve rubber seal the piston will usually be pushed down if there are no nails in gun. If the driver stays up while leaking then problem is at cylinder plate. This plate has two orings that seal air pressure. On seals against the body of gun and the other seals against cylinder. Leaks can occur if body of gun is worn, warped or has scratches where oring makes contact. Also look closely at the plate for crackes. Replace parts as needed. Good luck
Feb 27, 2011 | Hitachi NR90AD 3 - 1/2'' Clipped Head...
Finish Pro 32 is Leaking air out of the exhaust cap
You have worn or broked o-rings/seals inside the gun. The Finish Pro 32 is one of Senco's older guns and they no longer offer a repair kit for this gun. You have to go to a site like www.senco.com or www.ereplacementparts.com, find a breakdown of your gun and order each part you need. If you are going to rebuild the gun order all the o-rings/seals (Senco parts that start with LB) and any other parts that may be damaged like the piston stop, springs, etc. Lubricate the o-rings with light grease as you put them in and make sure to oil the gun regularly when you are using it to make your work last.
Jan 27, 2011 | Senco FINISHPRO32 ProSeries 16 Gauge...
I have a SCN40R gun that doesn't advance the nails in the coil part. What could be the problem. The part that is suppose to advance the next nail doesn't move.
The feed pawl is moved by a piston that extends from a cylinder on the lower side of the guide body. There are a couple seals inside the cylinder that if damaged will not hold enough air to activate the piston and advance the next nail. The two seals are Senco part number LB0828 & LB0845. Better yet get a Senco YK0369 repair kit and replace all of your o-rings, you'll have a like new gun for around $60.
Jan 06, 2011 | Senco Air Tools & Compressors
I just rebuilt my Senco SN4 nail gun because it leaked air.
I think that you are referring to the firing valve and no it should not be split. I suggest going to Senco.com and typing in your model number fora breakdown for this tool. They offer different kits for various failures. Let me know if you need more help
Nov 23, 2009 | Tools & Hardware - Others
Air Tools & Compressors Logo
796 people viewed this question
Top Senco Air Tools & Compressors Experts
John Trevino
yoopertech
Mike
Are you a Senco Air Tool and Compressor Expert? Answer questions, earn points and help others
