Question about Alesis MasterLink ML-9600
Right channel hum/buzz/distortion in record mode
I was recording when I heard a hum in my right channel via headphones. I thought it was a bad cord. I put it in record mode freestanding with nothing plugged into it and it still hummed. So at least I know it is internal which is not good news. Both the CD and hardrive play fine. The problem is ONLY in the record mode. HELP!!!!! Where do I go to get this repaired in the S. Florida area. I bought it at Guitar Center in Hallandale Florida.
  • googler too May 11, 2010
    Does the hum appear on a finished CD? It may just be a fault in the headphone amp, in which case it won't appear at the audio outputs, the digital output, or on any CDs you make with the unit.
    Try plugging audio out into another unit, such as an amp with headphone facility, monitor it there and see if hum still present.
5 Suggested Answers
  • 4 Answers
SOURCE: In play mode the sr 16 goes beserk. It makes a
The SR-16 uses an external transformer as the power supply which provides 9 volts AC. This ac power is converted to DC positive and negative voltages for the digital and analog portions of the circuit. Although the unit has been reliable generally, this symptoms sounds like of of the main filter capacitors in the DC converter circuit(rectifier, filters and voltage regulator) has broken loose or is defective. This will affect both channel equally. If the problem is in one channel, a broken shield on a cable or the output jack ground connection might have broken on that one channel.
Posted on Jan 22, 2011
  • 5603 Answers
SOURCE: I record a podcast with
What is the source of the input signals? These need to be balanced lines and the sources need to be balanced. If you happen to be using condenser mics, you probably haven't turned on the Phantom Power in the mixer. If you are recording from a sound card in the PC, those have a lot of noise and are unbalanced and you have to use DI's with ground lift ahead of this mixer.
Posted on Feb 08, 2011
kevinmunn
SOURCE: clip signal on Alesis multimix 12 USB - no inputs!
What capacitors?
Posted on Sep 28, 2011
jadiazq
  • 2878 Answers
SOURCE: Won't Record From Shotgun Mic.
Adjust Recording Levels.
Win 7Start > Control Panel > Hardware and Sound > Sound > Microphone >Properties > Level.
Posted on Oct 05, 2012
Loud buzz on both channels with new turntable and phono
The ground wire needs to be attached. The hum is a result of a bad ground.
Jul 12, 2014 | Audio Players & Recorders
How do I attach and play a technics record deck to a technics DV250 amplifyer?
The problem you are facing is that the record player audio outputs has a left channel, a right channel and an earth or grounding cable. If this grounding cable isn't attached, you are likely to get a hum sound. I would suggest buying a record player RCA (Ground simulating) cable or you will have to buy an inexpensive mixer that supports record players through which you can channel this record player. Once you have all these, just follow the white and red color coding to attache the right channel to the right socket.
May 10, 2014 | Technics SC-DV290 System
How I solve the channel overlapping?
This is down to the head alignment. Once that is corrected the sound will recorded normally and playback normally too. However any tapes recorded during the fault will not play right.
The head alignment can be corrected, using two adjusting screws located either side of the head. To get at them the door cover has to be removed. To align you play a pre-recorded good quality tape. You adjust the screws till the sound is bright and clear and only the sound recorded on that side of the tape can be heard. Best done with headphones. If you can use a commercial music tape. If you use the decks own recordings it might not be right.
If there is any damage to the head mounting you will not be able to get the alignment right.
PS use the right screwdriver for the head screws. These are very small and easily wear away. If you wear the screw head away you might have a job getting a new small screw that will fit.
May 01, 2014 | Nakamichi Audio Players & Recorders
Speaker produces noice/static/buzzing sound when it is off
That means that if too much power is going to the speaker or extraneous signals are being picked up by the wiring, it can come through the speakers as static. Stopping static requires finding and eliminating that extra electricity from transmitting through your speakers.
If you're still hearing distortion, turn down the volume on your amplifier until the distortion goes away. If the volume is too low to be easily heard, the problem may be that your amplifier produces too much power for your speakers to handle or that your amp and speakers have different impedance ratings.
Apr 04, 2017 | Boston Acoustics Duo-i Horizon Clock Radio
I have a pair of Stanton T62s which I got about a year ago. I moved from SF to LA and now I can only hear static from my right turntable through my headphones. I don't have speakers yet and I thought...
Disconnect the wires to the cartridge on the turntable that has trouble. Then put your headphones and with it powered up. Touch each cable end of the loose wires of the cartridge one at a time with your finger. On two you should hear a buzz, one on each channel. On the other two wires you might get a slight buzz or a crackle, but don't expect anything. If you get a buzz on both channels. Then the cartridge is faulty. If you do not get a buzz on either channel then there is something wrong either inside the deck or the wiring to that deck.
Jun 22, 2017 | Stanton T62 Turntable
Low sound and buzz from speakers / Hum noise from sub-woofer
Select Start > (right click) My Computer > Manage
In the Management window select > Device Manager
Next to Sound, Video and Game Controllers click the + sign
A yellow triangle will signify a problem so if one is present, right-click that device and select Properties
You can then choose to update the driver
For more details check Dell Xps 420 Manual.
Dell Xps 420 Manual
Apr 14, 2017 | Dell A525 Computer Speakers
Hum on right channel
It doesn't really sound like this tech knew what he was doing. He probably connected the ground wire incorrectly. I would also suggest opening up the tonearm base section, and checking to see the work he did. Perhaps he did not solder the RCA leads correctly.
If all is good, then there are only 2 other things which may cause this... 1) Tonearm, 2) Cartridge. You'll have to check those 2 out.
FYI, I work on 1200s for a living, so I know these machines inside out.
- Davis
DIGITAL ANALOG THERAPY
www.REPAIRNYC.com
www.1200s.com
Jul 11, 2008 | Technics SL-1200 Turntable
Philips CDR775
Bad earth / failed capacitor on the PSU board. I sell replacements via ebay or can email a service manual for you to get fixed locally. Fluffcat1
Oct 24, 2007 | Teac CD-RW880 CD Player / Recorder
Alesis MasterLink ML-9600 Logo
79 people viewed this question
Top Alesis Televison & Video Experts
Marvin
Marvin
Are you an Alesis Televison and Video Expert? Answer questions, earn points and help others
