Question about Refrigerators
WHAT TEMPERATURE DO i SET MY mIELE kfn 8562 FRIDGE /fREEZER.
I purchased from comet a miele fridge/freezer it was reduced in price and i took it as seen. It has arrived today without a manuel. Where can I purchase a manuel from and what temperture do I set the fridge at and the freezer.
5 Suggested Answers
maklean
  • 1665 Answers
SOURCE: MIELE KFN8762SDED (SS/fridge/freezer)
Have a look at page 5 (KFN8767 Miele refrigerator) it may be similar. Exact model number didnt find.
http://www.miele.co.uk/Resources/OperatingInstructions/KFN%208767%20S%20ed-2.pdf
Posted on Sep 19, 2008
SOURCE: Miele refrigerator Model KFN 8993 SDE (I believe)
Similar to this, although I also had a build up of frost in the freezer. Advice from Miele:
"You have a fault on freezer evaporator sensor and will need an engineer to call and repair please contact our office o 01235554466 to arrange a service visit."
Rather than this, which i assumed would be expensive but didn't bother calling, I defrosted the fridge/freezer overnight and turned it back on in morning. Freezer cooled down to -18 in a few hrs and since then all is working fine - it's been a couple of weeks or so now.
Posted on Nov 19, 2008
woodchuck789
  • 4059 Answers
SOURCE: the fridge is cold but the freezer won't freeze
The grill being the condenser coil- The sealed system is low on freon or the compressor isn't working correctly.
Posted on Jul 01, 2009
  • 323 Answers
SOURCE: how is possible to reset the kfn 8762 Sd miele
usually powering down the unit for 5 or six seconds, then repowering is a reset method
Posted on Oct 31, 2009
SOURCE: Fridge Freezer will not maintain fridge temp, but freezer fine
My miele fridge freezer has just come up with a fault code F4 where the temp is... what does this mean and how can we fix it???
Posted on Jan 18, 2010
I have a Miele Kfn 8452 sd who blink 2 leds both in the same time, freezer and super freeze,and i hear the sound alarm, i need to know whats the problem, what is damaged?
Press alarm button once
either left door open too long or temperature too low
adjust fridge to 4 centigrade
freezer to -17 centigrade
Dec 28, 2015 | Miele Refrigerators
How do I fix a F2 Fault on my refrigerator
miele kfn 8462 sd - F2 error message on fridge temperature
www.justanswer.com > Appliance
Question - miele kfn 8462 sd - F2 error message on fridge temperature - NO. ... in the wee hours when I finally have time to ask questions about my Jenn Air.
UK Whitegoods • View topic - Liebherr fridge F2 fault.
ftp.ukwhitegoods.co.uk/forumsphpbb3/viewtopic.php?f=35&t...
Oct 25, 2010 - Hello lads first post here. My mothers liebherr fridge has a fault code up,F2. Liebherr refrigerator. Fault code: F2 Model: KBES 3650. Is that an ...
Frigidaire Range/Stove/Oven Displaying Fault Code F2/F3/F4
www.repairclinic.com/...-/Frigidaire-F2-F3-F4-Oven-temperature-sensor-.
Dec 22, 2015 | Fisher and Paykel Refrigerators
Miele KFN8993SDN Freezer temperature to high
Temperature displays
During normal operation, the temperature display shows the temperature in the middle of the refrigerator section and the temperature in the warmest part of the freezer section.
Aug 20, 2015 | Miele KFN12923 SD-2 Stainless Steel 369 l...
How do I set the temperature for miele fridge freezer pigeon pair kfn 9753 iD?
Wait for it to cool
while it dies you will see flashing bars
wait
it will cool
Feb 24, 2015 | Miele Refrigerators
I have got miele fridge freezer but the fridge keep freezing what can I do
Usually a faulty temp sensor on the fridge evaporator, not an easy repair for most, I would personally recommend Miele's fix priced repairs
Service Repair Miele Support Miele UK
Sep 19, 2014 | Miele KFN12923 SD-2 Fridge Freezer, A...
Fridge light bulb
Not sure how the light socket only has 6V supply? The bulb for this fridge is a pretty standard 15 Watt/230V SES lamp. If you are sure the current lamp is OK I would suggest the door lamp switch has issues. Try pressing and releasing the door switch manually and check that it functions ok without getting stuck or any sluggish movement. This action in itself may fix the problem.
Jan 18, 2014 | Miele KFN8462S Bottom Freezer Refrigerator
I have a KFN 9753 fridge-freezer about over 3 years old. The fridge is not cooling.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 06, 2011 | Miele Refrigerators
Dec 30, 2009 | Miele KFN8762SDED Bottom Freezer...
How is possible to reset the kfn 8762 Sd miele fridge/freezer
Oct 31, 2009 | Miele KFN8762SDED Bottom Freezer...
No problem just use the + and - buttons when you have chosen the temp. you want just let go and that is the temp the fridge or freezer will set at.
Aug 19, 2008 | Miele KFN8762SDED Bottom Freezer...
Refrigerators Logo
94 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
