Question about Logitech Cordless Mouse
Red light is not working
I just replaced the batter Duracell alkaline with Panasonic
    President:
  • 8,637 Answers
Normal 0 Press the Receiver button a(and the lights will start flashing, then if its the Keyboard that isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver..
If its the MOUSE do the same except push the small RESET?CONNECT button on the back of the mouse to connect. Then they should work properly. Hope this helps. Bud
Posted on Jan 17, 2009
Where can I get batteries for Citizen model CH-433B BP monitor In India/Hyderabad?
You must ensure that batteries are properly arranged or not.
Sep 01, 2016 | Panasonic Cameras
Duracell d4 alkaline life expectancy
According to Duracell the shelf life of MN batteries is very good... It is dependent on temperature.... At say 20 deg Celcius LESS than 4% per year and at human body temperature (38 degrees) is still LESS than 10% ... But actual life may depend on the physical corrosion of the casing and be dependend on storage....
Dec 10, 2014 | Duracell D-Size Alkaline Battery Pack -...
Do watch batteries leak?
And destroy the watch? Yes, but not as much as regular batteries do. The old alkaline batteries in flashlights are notorious for leaking, I have seen a couple times when the little batteries leak, One of my calculators leaked, but I caught it just in time. Cleaned up the contacts, and it works fine. If the battery did leak, send the whole watch and battery back to the manufacturer, they should replace it. Duracell has sent me a dozen flashlights and numerous battery coupons for leaking batteries. Hope this helps.
Feb 26, 2011 | Panasonic CR2016 Lithium Coin Battery
Only a few hours after inserting a new battery (tried two different packs of NEW batteries) into my Microsoft 6000 wireless mouse, the red light on top comes on.
I use rechargeable batteries rated at 3200MAh and have been operating for 2 months now.
If you can't get hold of them, try fresh Alkaline batteries like Duracell.
pls. vote for better service... thank you
Nov 14, 2010 | Microsoft Wireless Laser Mouse 6000 v2.0
I can't seem to get the correct batteries for my Texas Instruments TI-84 Plus Calculator...can any AAA 1.5v battery use in it? I tried some duracell of that same type and they didn't work
All the AAA batteries whether non-rechargeable alkaline (Duracell, Energizer, Rayovac, Varta, Maxell, Panasonic, Sony, Sanyo, etc) will do. Each of these types of batteries has a voltage of 1.5V
You can also use rechargeable NiCd (Nickel-Cadmium) or NiMH (Nickel-Metal Hydride) 1.2V AAA. However TI Instruments say that under no circumstances should one use rechargeable batteries.
The trivial possible reasons why the the Duracell did not work are:
  1. The lot was depleted.--Replace with fresh ones
  2. The electrical terminals may be broken or dirty or corroded by a previous acid leak.---Clean the terminal even if they appear shiny. The eraser tip of a pencil should be good to rub away any dirt.
  3. You did not place them correctly: Wrong polarity. This is a very common mistake (I know from my own experience).
Sep 12, 2010 | Texas Instruments TI-84 Plus Calculator
Replaced batteries, fires once, red light stays on. Turn off, restart, same pattern.
Hi Larry,
Change all four batteries, I think one or more were not 1.25 or more voltages.
atdlee@netzero.com
Jan 11, 2010 | Vivitar 285HV Flash
When I insert some batteries the red light begins blinking. I also have some Duracells that appear to be charging but when I place them in the appliance they are dead.
All chargers cannot charge all types of batteries. Are your Duracell batteries NiMH or Alkaline? These indications generally happen when you insert a battery type that is not rechargeable.
Dec 13, 2009 | Duracell AA/AAA NiMH Battery Charger with...
Batteries keep dying
hi
wat batteries are u using?
I have the same model, have been using rechargeable batteries as well as duracell. works good
dun buy those cheap batteries, $1.00 types, they are not enough to sustain the power requirement
Dec 04, 2008 | Canon PowerShot A720 IS Digital Camera
LED Light on or off indicator
on my charger the red lights are only to tell there is power connecting especially when you have two battery's behind each other on the bottom of my charger there is a guide as to how long you should charge each battery as to size which are aaa 7hours max
aa 24hours
c 24hours
d 24hours
9v 24hours
hope this helps glenn............
Nov 20, 2008 | Duracell AAA NiMH Battery Charger with 4...
Batteries
i suggest by 4 NIMH and a charger and look to capacities of above 2500 MAH (anything higher is better) this camera is power hungry all the time , i do not recommend duracell penlights (alkaline) they are draint in 3-5 shots even the high power alkaline cells (aa) of duracell
Feb 27, 2007 | Nikon Coolpix 7600 Digital Camera
Logitech Cordless Mouse Logo
56 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
