Question about Compaq Presario R3000Z Notebook
Notebook power problem
My notebook (Compaq R3000) wont run with out the battery and when the battery is instaled it dosent seem to charging, the power light (comes on when power cord is plugged in just flashes when the computer is turned on... if the power is off the light stays on untill I try to start the computer.
  • Tim Holm Jan 05, 2007
    Oh and I have replaced both the Battery and power cord
    Novelist:
  • 123 Answers
Make sure the new A/C adaptor and battery are working correctly.then check the charging circuitry or power distribution in the laptop
This can be caused by:
1.The monitor is not connected properly.
2. Bad hardware
Verify that the monitor is properly connected in the back of the monitor as well as to the back of the computer.
If the connections are OK it means that monitor or the video card is probably damaged. To test which component is dameged connect a different monitor to your computer or connect your monitor to a different computer.
If the other monitor works on your computer it means that your monitor is bad and if your monitor works on another computer it means that you probably have a damaged video card.
Let us know how things turn out and don?t forget to rate the posting.
Posted on Jan 27, 2008
  • PRIYABRAT  PATTANAIK
    PRIYABRAT PATTANAIK Jan 27, 2008
    It will surely work
    please go through my solution and rate me
  • 624 Answers
Good evening Arapa, Before I went any further I?d make sure the new A/C adaptor and battery are working correctly. Over the years I?ve had many brand new or refurbish parts wind up not working. Also verify that they are the correct ones for your laptop. The next candidate is the charging circuitry or power distribution in the laptop. Since it involves major disassembly I don?t usually recommend this option to the typical user unless they have experience working with and handling electronics, a good mechanical aptitude and are willing to live with the results of damaging the laptop beyond economic repair. Most times a local factory authorized and trained tech can give you a good estimate of what it will cost and save you the cost of buying test parts you may not need. Let us know how things turn out and don?t forget to rate the posting.
Posted on Jan 05, 2007
My compaq presario r3000 wont charge. its plugged in but when i unplug it it immediatly turns off. the battery life constantly says 0%. it wont drop from that or get any higher. in the bottom right hand...
Sounds like the battery, had similar problems.. if you purchase a new battery make sure you get the right kind there are two types, an 8 cell or 12 cell..
The fix for my pressario involved completely stripping it and soldering 3 pins on the power connector on the mainboard.. not difficult but no mean feat.. now works perfectly (with the inclusion of a 12cell battery)
Dec 28, 2010 | Compaq Presario R3000 Notebook
My r3000 has a tempermental power supply. it
whatabout the lead that plugs into the laptop ? does the plug in the laptop move easily, with the lead in, Sounds like the actual plug in the laptop is breaking away, the solder around the connector. Sadly to fix that you will have to get it repaired for about £50 to £70, maybe more ?? please make sure the lead from power supply is not loose or a bad fitting.
Jun 14, 2009 | Compaq Presario R3000 Notebook
Compaq R3000
r u mention for battery light?if is it true,then the light is blinking because of your laptop want to make sure the power supply charge that battery.if it is in charging condition,the light on.but if the light goes off,that mean, the battery is already full.
But when u use adaptor without battery, the light will goes off because no charging session is in progress which has same behaviour with battery full(during battery full,no charging session occur)
May 12, 2009 | Compaq Presario R3000 Notebook
My Compaq R3000 does not charge up
The problem might be the battery itself. Four years is a long time for rechargeables. Also, check if the error ocurs when the battery is not in the slot.
Oct 27, 2008 | Compaq Presario R3000 Notebook
The power plug won't charge the battery which prevents the computer coming on
There was a recent class settlement agreed to by HP regarding these models. HP failed to notify a ton of its customers and I've contacted Scott Kamber regarding.. (We were consultants for the suit).. Weve repaired a ton of these and you are not alone. Did you buy the machine new and register w/HP? Just curious...
Ken
Aug 02, 2008 | Compaq Presario R3000 Notebook
Battery won't charge
If the battery is not charging, then the charging circuit of the motherboard is bad.
Page 3-22 lists the spare part number for the motherboard. (4 versions depending on options)
Chapter 5 covers disassembly and reassembly
http://www.hp.com/ctg/Manual/c00212209.pdf
May 21, 2008 | Compaq Presario R3000 Notebook
Wont charge
It could be that your battery is defective/worn out. If the computer just shuts off immediately (doesnt try to hibernate/standby) then you're likely looking at replacing the battery. They can suddenly do things like this if a cell shorts out in the battery or due to common wear. But first, here are a couple of things you can try.
1. Try reseating the battery (pull it out and put it back in). Sometimes something that simple can fix the problem.
2. Try to calibrate the battery. Your computer may come with instructions on how to do this, but if not you can do it manually. Turn the computer on but go into BIOS (press F10 at the compaq logo screen). Don't load your operating system
Unplug your computer. If it turns off at this point, your battery is already toasted. Replace it.
If the computer keeps running, let it go until it finally shuts off due to battery drain. Then plug it back in and let it recharge completely. This will let the microchip in the battery learn its charge potential and may allow you to get more life out of it.
Note: Calibrating these batteries is good practice but it shouldn't be done very often. If your calibration doesn't work after 1 or 2 tries, you probably still are looking at a dead battery.
Apr 23, 2008 | Compaq Presario R3000 Notebook
Compaq Presario R3000 series charging/powering problem
Your power jack on the laptop is probably what when bad. you can take it apart and try to install an new one or you can power the laptop through the side docking port. I wired up a custom connector to use with the ac adapter to make it connect to the to wide metal slots in the docking port.
Apr 12, 2008 | Compaq Presario R3000 Notebook
Laptop won't stay on
it might as well be a internal problem related to power or loose contacts with RAM or the power chords internally.
Better to go to the technician in this case.
Your first Battery would have been fine too..
Compaq presario c-300 charging system
that is normal.. you can change that dim setting to power option in control panel.. it really dim when unplug.. but you can change that if you want, so it will not dim.
Dec 26, 2007 | Compaq Presario R3000 Notebook
Compaq Presario R3000Z Notebook Logo
83 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
