Question about Logitech Cordless Mouse
Light not working
I just replaced the batteries, but the light is not working
  • Anonymous Nov 29, 2008
    I just replaced the batteries, but the light is not working.
    Thank you,
    Carol
    lallycarol@gmail.com
  • Anonymous Dec 07, 2008
    i have the same problem and the batteries are in right way.
    when the new batteries are put the cordless mouse does not work. the red light doe not come up if you press the button
  • 341 Answers
Stupid question,but are they in the right way? Some have a button that you push yo turn it on as well.
Posted on Dec 06, 2008
MH-25 is not charging the battery
Check the cords and make sure to disconnect and then reconnect the cords. Try the charger if nothing then try replacing the battery. If the battery is bad the charger will not work. If the battery is replaced and will not charge then replace the charger.
Mar 26, 2013 | Nikon MH-25 Charger NIKON
Replaced the batteries, now it doesn't work.
Not working?
This unit should have a light at the tip to indicate it's sending a signal. After battery replacement ..is the light working?
If no light..do the battery thing again and check the contacts and test the batteries etc.
If the light is working strong, you may have lost the programing and will need to re-enter into your system.
Aug 22, 2011 | DSC Ws4939 4-button Keyfob 433mhz Key...
Anyone know about 1996 polaris sportsman 400 - none of the lights are working - headlights, tail lights, not even the neutral light or reverse lights work - have looked for for broken wires and can not...
I also have a 96 Sportsman 400...local dealer told me if these bikes are operated with a low\bad battery the electrical system is designed such that the light bulbs will blow. I and a bad battery and non of my lights worked when I got the bike started. So, I replaced the battery and headlight bulbs and they now work. I would recommend replacing your battery if it's questionable and then your bulbs...worked for me!
Nov 08, 2010 | Polaris ATV
Vectorlite 1.5 candlepower shines a dim light instead of a bright white light.
Either the battery is not fully charged or it is time to replace it. Try charging the battery. If that doesn't work you will need to dissemble the light to obtain the replacement battery numbers. It should take (2) Model CA645 Batteries. They are 6 volt 4.5 amp hr.
Jul 16, 2010 | Camping, Backpacking & Hiking
Replaced battery, light is still on
The battery light is usually an indication that the battery is not charging. This could mean your alternator is bad but sure to check the alternator belt tension carefully. If it is loose, it can make the alternator appear bad.
Jan 24, 2010 | 2004 Mazda RX-8
Batter Light On, Ford Explorer
Does the alternator work? Does the light go out if you unplug the plug in on the alternator?
May 16, 2009 | 2003 Ford Explorer
Battery light comes on but alternator and battery work fine after
THE RED LIGHT SHOWS WHEN ITS NOT CHARGING I WOULD GET THE VOLTAGE CHECKED SHOULD BE PUSHING 13 TO 13.5 VOLTS WHEN CAHRGING
Apr 08, 2009 | 1998 Lincoln Town Car
Replaced the battery all instruments work but the van wont crank
sounds like the alternator / it will keep draining the battery have it check at any auto parts store
Jan 24, 2009 | 1997 Oldsmobile Silhouette
Light won't work
I suggest you have to check your battery first. It may be underpowered. Replace it with the new one and then check light again.
Dec 19, 2008 | Polar F6 Wrist Watch
Logitech Cordless Mouse Logo
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
