Question about Samson G-TRACK USB RECORDING MICROPHONE Microphone
I recently purchased a samson g-track usb mic. when I use it with garage band on my imac - I get static. not always, only about 1 time in 10 recordings. I have to diconnect the mic, re-connect then it goes away for awhile. unfortunatly, I don't knot there's static until after I laid down a track - then I need to delete it and do over. any suggestions? my other analog mic works fine as well as an inexpensive usb mic i used to use.
  • mrsimmo Nov 29, 2008
    me too... here i'm using it with logic express on a mac pro, although i get the same problems with skype too. after about 10 mins of use, the noise starts
  • Anonymous Mar 24, 2014
    im getting static through protools with my samson co1u studio condenser mic. its connected to an m audio fast track pro and im running through pro tools 10 hd but it also will not record properly on other daws. I also have a different mic and it has static as well. this is a new desktop and I was having the same prob with my laptop as well.
    Problem Solver:
  • 27 Answers
It seems like this is a problem with certain versions of OS X. You might be able to fix it by downgrading or upgrading. Apple Forums say that it's fixed in 10.5.6.
You can double check that this is the problem by trying it on a Windows computer.
Posted on Mar 01, 2009
It appears to be a problem with USB and the clock sample rate of the mic.  You need to go into your Applications/Utilities folder to find your Audio MIDI Setup.  In there you can choose the device for input and manually set the sample rate (usually 44.1K or 48K).  Keep that window open while you record, and you'll find that the mic will reset itself to another sample rate on its own... don't know why, and Samson's support is pretty non-existent, so I can't get any answers from them.  If you simply reset the sample rate in the Mac's Audio MIDI Setup utility the problem will clear itself up.  But, with Garage Band, you'll then get a very bad latency issue that will force you to restart Garage Band to reestablish a near-zero latency.  It's annoying, but it does work.  (In Soundtrack Pro I can reset it without having to restart the application.)
Posted on Feb 21, 2009
Mic sound muffled static
Buy a better mic! This question reminds me of the musicians who invest in a nice JBL public address system but then use Radio Shack microphones. A good quality mic, not GREAT but just good will cost you a minimum of $100. Quit playing with toys and invest in real recording gear. Computers and hard drive recorders can easily record CD quality audio, and-so why would you use a $70 mic?
Sep 10, 2013 | Samson Samtr Meteor Mic Usb Studio...
Want to copy files from Tascam 788 to IMAC's Garage Band
The problem is thus. You have a multitrack recording saved in a format that your portastudio recognizes and you want to use it on your imac. If you can copy the file to the imac as a file, a translator, if one is available, will make it usable by the mac. You won't be able to play it and record on the imac because maintaining the recording as multitrack would require one output from the portastudio and one input on the imac for each recorded track.
Bummer dude. The kluge method would be to play/record 2 tracks at a time (or however many outputs and inputs are available) and hope for some semblance of time alignment, after which you can fine tune it and then start your editing.
Apr 09, 2009 | Tascam Electronics - Others
Problems with samson g track usb mic
sounds like your recording volume is too high, and its "clipping"
Mar 03, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Many Problems with Samson G-Track or not?
Hi.  I dunno if yur using pc or mac but with a mac yu need to adjust the mic settings on the comp. For the static its probably your set up or as i said in another guys problem, the usb cable given with it is **** so try using another one from a printer or wtv to see if that makes a difference for you. Also if you are recording just through the mic i find that it seems to only work well when the input is on line and not inst/mic. Hope this can be of some help. Its a great piece of kit once you get it working well.. Goodluck
Jan 16, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Static with playback on samson-gtrack with windows xp
i have the same problem with my g-track on a macbook im just going to take the thing back
it works for a feww min when i first start recording the is falls apart
Jan 10, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Imac-samson-gtrack mic compatability
From the Samson Audio website...
"Ideal for the traveling musician or the project studio, the G-Track ships with a desktop mic stand, swivel stand mount, USB cable and all the cables needed to connect any musical instrument with a standard 1/4" or RCA output. The G-Track ships with Cakewalk's Sonar LE and works brilliantly with Apple's GarageBand."
If it states that it works with GarageBand, I would say that it would work on a mac.
Nov 29, 2008 | Apple iMac 24" Desktop
Using m-audio fast track usb with Behringer mixer
Use the taope outs. They're the RCA plugs located in your manual as "20".
Sep 01, 2008 | M-Audio Fast Track USB (FASTTRACK) Audio...
No recording?
The static after several seconds seems like this is a problem with certain versions of OS X. You might be able to fix it by downgrading or upgrading. Apple Forums say that it's fixed in 10.5.6.
Jul 28, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
STATIC!
Hi philltl89
If it has been doing this since new, there is probably something wrong with it. I would return it to the place you purchased it from and get it changed over.
regards
robotek
Jun 18, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
GTrack producing NOISE and not catching audio from even 20cms.
Did you check the record levels on the software you are using.
Sep 14, 2007 | Samson G-TRACK USB RECORDING MICROPHONE...
Samson G-TRACK USB RECORDING MICROPHONE Microphone Logo
282 people viewed this question
Top Samson Audio Players & Recorders Experts
PBandJ
PBandJ
Level 1 Expert
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
